Forum Topic - BPF promiscuous mode: (6 Items)
hi,
I am working on a BPF device which i create as /dev/bf0
using the following call
bff = open(bpf_dev, O_RDWR))
but when i try to set it in promiscuous mode using ioctl
ioctl (bff, BIOCPROMISC, &set) == 0)
it returns a ERROR.
I am currently working on QNX 6.4.0 x86pc.
is this mode not supported currently ?
Re: BPF promiscuous mode
Did you try to bind the interface before the ioctl?
struct ifreq reader_if;
char if_name[128];
  strcpy( if_name, "en0" );
  // bind interface
  strcpy( reader_if.ifr_name, if_name );
  if ( ioctl( bpffd, BIOCSETIF, &reader_if ) )
    printf( "error: bpf setif ioctl error %d\n", errno );
    close( bpffd );
    return -2;
  if ( opt_promiscuous )
	  if ( ioctl( bpffd, BIOCPROMISC, NULL ) == -1 )
	    printf( "error: bpf promiscuous ioctl error %d\n", errno );
	    close( bpffd );
	    return -3;
hi ,
yeah i m binding the interface en0.
the earlier call to ioctl using parameters BIOCSETIF and BIOCIMMEDIATE returns a success.
but the next call using BIOCPROMISC as one of the parameters fails.
RE: BPF promiscuous mode
On another note, we've just recently updated the wiki pages / docs to
indicate that you should use "ioctl_socket" instead of "ioctl" when
using BPF.  The support for the ioctl is included with the stack (see
the bpf.c:bpf_ioctl in trunk/sys/net/bpf.c).
	Robert.
From: Dennis Kellly [mailto:community-noreply@qnx.com]
Sent: Tuesday, January 27, 2009 9:40 AM
To: technology-networking
Subject: Re: BPF promiscuous mode
char if_name[128];
  // bind interface
    close( bpffd );
    return -2;
	    close( bpffd );
	    return -3;
Technology
http://community.qnx.com/sf/go/post20838
Re: RE: BPF promiscuous mode
made that change to setting all ioctl to ioctl_socket ..
but things don't seem to work here.
lemme execute something more simpler n check ..
nope nothing works i have given up ...
the only work around is to slay the io-pkt and reload it along with the
"-dpcnet promiscuous  " options.
nicinfo confirms that promiscuous mode comes up then.
