Forum Topic - Multicast routing question: (5 Items)
I have (what I believe to be) a routing question related to multicasting.
If I run my software on a QNX system that obtains it's IP address via DHCP multicasting works. However, if I run it on a
 QNX system that has a fixed IP address, it does not work.
I suspect this is because the system has no defined gateway. There effectively is no gateway in that configuratation as
there are two computers on a subnet using fixed IP addresses.
The network configuration is pretty much the default except that I've assigned a static IP address.
What would I need to do to make this work?
Thanks in advance ....
RE: Multicast routing question
Can you post the output from
ifconfig
/sbin/route show
for the two set ups?
	Thanks!
		Robert.
Sent: Friday, January 16, 2009 1:08 PM
To: technology-networking
Subject: Multicast routing question
multicasting.
DHCP multicasting works. However, if I run it on a QNX system that has a
effectively is no gateway in that configuratation as there are two
Technology
http://community.qnx.com/sf/go/post20238
Re: RE: Multicast routing question
Sean/Robert, thanks both for your replies.
Here are the two tables:
1) DHCP (Windows DHCP server)
Internet:
Destination       Gateway            Flags
default           192.168.50.1       UG
localhost.localdo 127.0.0.1          UH
192.168.50.0      link#2             U
192.168.50.1      00:40:10:13:dd:f5  UH
2) Fixed IP Address
Routing tables
Internet:
10.0.0.0          link#2             U
I understand I can add a route in the fixed IP configuration. If I have a physical subnet with two computers that use
fixed IP addresses; what do I set for the gateway? The stack appears to need one to register for mutlicast packets.
Thanks...
> Internet:
> 2) Fixed IP Address
> Routing tables
> Internet:
> 10.0.0.0          link#2             U
When sending multicast packets the stack has to know
which iface to send it out.  You can use the IP_MULTICAST_IF
socket opt like:
	struct in_addr          addr;
	const char		*iface = "10.0.0.1"  /* address of your local iface */
	memset(&addr, 0, sizeof(addr));
	addr.s_addr = inet_addr(argv[1]);
	setsockopt(s, IPPROTO_IP, IP_MULTICAST_IF, &addr, sizeof(addr));
Or add a route.  You can add one for the specific address
you're sending to, or a default:
# route add 225.0.0.40 10.0.0.2
or
# route add default 10.0.0.2
Where 10.0.0.2 is another machine on your 10.0.0.x subnet.
Re: Multicast routing question
On Fri, Jan 16, 2009 at 01:08:07PM -0500, Paul Kahn wrote:
 a QNX system that has a fixed IP address, it does not work.
as there are two computers on a subnet using fixed IP addresses.
You do need a route to the multicast dst.  When in doubt add a
default route:
# route add default <dst>
