Sending and receiving broadcast messages via the same interface
12/16/2008 3:24 PM
post18759
We are would like to be able to send and recieve a broadcast message via the same Ethernet interface.
We can successfully broadcast both a limited IP broadcast (255.255.255.255) and a subnet-directed IP boardcast (e.g. 192
.168.146.255, subnet mask 255.255.255.0) to another component on the local subnet. We are also able to receive broadcast
messages sent from another component.
However, we'd like to be able to send and receive a broadcast message from the same interface. We see that the
IFF_SIMPLEX flag is set for interface "en0". There's not a lot of documentation about this flag but from the comments in
the include files we suppose it implies this is not possible. We tried changing this via the ioctl() interface using
SIOCSIFFLAGS. However, the socket call passes (no error) but when we retrieve the flag's value it is was set implying
the ioctl() call has no effect.
Is there some way we can do this?
Thanks in advance...
RE: Sending and receiving broadcast messages via the same interface
12/16/2008 3:27 PM
post18760
Hi Paul:
I'm not sure I understand this... Do you have two network
interfaces connected to the same subnet? What does your topology look
like?
Is this with io-net or io-pkt?
Robert.
Sent: Tuesday, December 16, 2008 3:25 PM
To: technology-networking
Subject: Sending and receiving broadcast messages via the same interface
192.168.146.255, subnet mask 255.255.255.0) to another component on the
local subnet. We are also able to receive broadcast messages sent from
another component.
from the same interface. We see that the IFF_SIMPLEX flag is set for
from the comments in the include files we suppose it implies this is not
retrieve the flag's value it is was set implying the ioctl() call has no
effect.
Technology
http://community.qnx.com/sf/go/post18759
Re: RE: Sending and receiving broadcast messages via the same interface
12/16/2008 3:51 PM
post18766
Hi Robert,
The final network topology will be a little complicated. However, for purposes of discussion, let's assume the following
The subnet is 10.0.0.0 with subnet mask of 255.255.255.0. There are two boards running QNX on this subnet. Each of the
two boards has one Ethernet interface one with address 10.0.0.100 and the other with address 10.0.0.200. Our software
will communicate using a proprietary protocol over UDP.
We are able to send broadcast messages from one board to another. However they are on separate boards and have different
IP addresses. We'd also like to be able to receive broadcast messages sent from the same board. Ideally, we'd like to
be able to send a broadcast out from 10.0.0.100:4000 and receive it via a socket bound to that address (actually the
same socket). Alternatively we'd be happy to receive a broadcast message sent from 10.0.0.100:4000 and receive it via a
different socket bound to 10.0.0.100:4001.
However, it appears we cannot receive broadcast messages from the same Ethernet interface. Hence my question about the
simplex flag which appears to be set for "en0".
Our code runs on both QNX and Windows and this works on Windows. However, I realize that the network stacks and even the
sockets implementations are vastly different.
--Paul
RE: RE: Sending and receiving broadcast messages via the same interface
12/16/2008 4:10 PM
post18768
Hi Paul:
This doesn't sound like it's supported in our stack. There are
a few ways that I could see this working. Having the driver listening
while it transmits (i.e. wholly in hardware), having the driver
recognize a broadcast packet and send it back up the stack in addition
to transmitting it and finally having the stack somehow loop back
certain packets before they hit the driver. The stack option seems very
difficult to manage, so I'd guess that it would be something in the
driver or hardware. Our drivers (and I would have thought most
hardware) don't support a "listen to what I transmit" scenario.
Do you have to do something special to Windows to make this happen or is
it a default behaviour?
Robet.
Sent: Tuesday, December 16, 2008 3:52 PM
Subject: Re: RE: Sending and receiving broadcast messages via the same
interface
Hi Robert,
purposes of discussion, let's assume the following:
boards running QNX on this subnet. Each of the two boards has one
address 10.0.0.200. Our software will communicate using a proprietary
protocol over UDP.
However they are on separate boards and have different IP addresses.
same board. Ideally, we'd like to be able to send a broadcast out from
(actually the same socket). Alternatively we'd be happy to receive a
Ethernet interface. Hence my question about the simplex flag which
However, I realize that the network stacks and even the sockets
--Paul
Technology
http://community.qnx.com/sf/go/post18766
interface
12/16/2008 4:13 PM
post18769
interface
How about using a switch to "re-route" the broadcast packet. Does that make sense ...
> From: Robert Craig [mailto:community-noreply@qnx.com]
> Sent: December-16-08 4:10 PM
> Subject: RE: RE: Sending and receiving broadcast messages via the same
> interface
> Hi Paul:
> very
> is
> Robet.
> From: Paul Kahn [mailto:community-noreply@qnx.com]
> interface
> Hi Robert,
> protocol over UDP.
> Thanks,
> --Paul
> Technology
> Technology
> http://community.qnx.com/sf/go/post18768
12/16/2008 4:14 PM
post18770
Oooohhh... You'd have to put a loop back in the switch. Can you say
broadcast storm? :->>
Robert.
Sent: Tuesday, December 16, 2008 4:14 PM
interface
make sense ...
> interface
> Hi Paul:
a few
> ways that I could see this working. Having the driver listening while
> it transmits (i.e. wholly in hardware), having the driver recognize a
> broadcast packet and send it back up the stack in addition to
> transmitting it and finally having the stack somehow loop back certain
> is it a default behaviour?
> Robet.
> interface
> Hi Robert,
> two boards running QNX on this subnet. Each of the two boards has one
> protocol over UDP.
> Thanks,
> --Paul
> Technology
> Technology
Technology
http://community.qnx.com/sf/go/post18769
interface
12/16/2008 4:16 PM
post18771
interface
Them Cisco switch are quite capable beast!
> Sent: December-16-08 4:15 PM
> interface
> Robert.
> interface
> make sense ...
> same
> > interface
> > Hi Paul:
> a few
> while
> certain
> > Robet.
> same
> > interface
> > Hi Robert,
> > protocol over UDP.
> from
> same
12/16/2008 4:16 PM
post18772
As a side note, we can check into the stack implementation to verify
this. Which stack are you using (io-net or io-pkt)?
Robert.
Sent: Tuesday, December 16, 2008 4:10 PM
To: 'post18766@community.qnx.com'
interface
Hi Paul:
Robet.
interface
Hi Robert,
protocol over UDP.
--Paul
Technology
12/16/2008 4:51 PM
post18778
Does it help if you use multicast rather than broadcast? Multicast
would provide much the same capabilities as broadcast though also does
explicitly allow looping back to the transmitting host (or so I
believe).
12/17/2008 9:36 AM
post18817
On Tue, Dec 16, 2008 at 03:51:45PM -0500, Paul Kahn wrote:
> Hi Robert,
following:
different IP addresses. We'd also like to be able to receive broadcast messages sent from the same board. Ideally, we'd
like to be able to send a broadcast out from 10.0.0.100:4000 and receive it via a socket bound to that address (actually
the same socket). Alternatively we'd be happy to receive a broadcast message sent from 10.0.0.100:4000 and receive it
via a different socket bound to 10.0.0.100:4001.
the sockets implementations are vastly different.
We do loop a copy of broadcast packets sent on ethernet back
on loopback. If you can receive any broadcast packets you
should also get the ones you send. You can check the 'netstat -in'
counts to see if the localhost counts increase on receive.
'netstat -pudp' has a dropped broadcast count as well.
12/16/2008 3:55 PM
post18767
Hi Robert,
protocol over UDP.
--Paul
Sent: Tuesday, December 16, 2008 12:27 PM
Subject: RE: Sending and receiving broadcast messages via the same
interface
Hi Paul:
like?
Robert.
another component.
effect.
Technology
Technology
http://community.qnx.com/sf/go/post18760
12/16/2008 4:49 PM
post18777
I'm rather new to QNX. I don't know which stack I'm using: io-net vs io-pkt. Is there an easy way to tell?
Are the sources for these on SourceForge? Are are these proprietary? I can take a look into this. It'd be good to know
if this restriction was at the NIC level or higher up in the stack.
Thanks...
12/16/2008 4:54 PM
post18779
Which version of the OS are you running (6.3.2 or 6.4.0)? You can also
type "pidin" and see if io-net or io-pkt-v4-hc is running.
Just to let you know, there's a flurry of e-mails going on about
expected behaviour, so the situation isn't as clear cut as I first
thought.
Robert.
Sent: Tuesday, December 16, 2008 4:50 PM
interface
can take a look into this. It'd be good to know if this restriction was
Thanks...
Technology
http://community.qnx.com/sf/go/post18777
Re: RE: RE: Sending and receiving broadcast messages via the same interface
12/16/2008 5:15 PM
post18781
Well pidin shows io-pkt-v4. And we are currently using 6.4.0.
12/16/2008 5:21 PM
post18782
"Does it help if you use multicast rather than broadcast? Multicast
believe)."
Good point, I'll look into this Roger -- thanks!
