Forum Topic - Port forwarding not permanent with proxyarp & net.inet.ip.forwarding flag: (2 Items)
Hi
We have network consisting of three systems.
A - source
B - acting as router
C - destination
Between A-B we have UDP running over ethernet. Between B-C we need PPP over serail port.
and on On B i executed follwoing command:
pppd/dev/ser1 proxyarp 115200 192.168.0.35:192.168.0.45
this is to enable port frowarding so that A can directly send data on IP adress of C.
Also did sysctl -w net.inet.ip.forwarding=1.
But i am observing that port forwarding is working fine, but after some time it is automatically loosing.
After i restart pppd and enabling port forwarding again  then it is resuming. But in actaul system
there is no feassibility to do the same. What should i do to ensure relaible connection.
Ravi
RE: Port forwarding not permanent with proxyarp & net.inet.ip.forwarding flag
You may use the option "persist".
Weijie
From: ravi varma [mailto:community-noreply@qnx.com]
Sent: November 21, 2008 8:36 AM
To: technology-networking
Subject: Port forwarding not permanent with proxyarp &
Hi
A - source
C - destination
over serail port.
adress of C.
Ravi
Technology
http://community.qnx.com/sf/go/post17051
