Forum Topic - Can I reduce the TIME_WAIT interval for closed sockets?: (3 Items)
I've got a client reusing a collection of 10 TCP sockets to connect/send data/close to a TCP server I'm running in
Neutrino (6.4, so it's the io-pkt stuff)... If the client tries to reuse a socket that has already been used before some
 time interval expires (I'm assuming it's TIME_WAIT), the client's connection is refused...
The interval to reuse a socket *seems* like it's on the order of a minute or so...
Thoughts? Can I just bump the TIME_WAIT interval down to something lower? Is there any way to avoid TIME_WAIT altogether
 and close immediately?
MikeZ
RE: Can I reduce the TIME_WAIT interval for closed sockets?
Hi Mike:
Can you use the SO_REUSEADDR socket option?
(e.g. http://www.unixguide.net/network/socketfaq/4.5.shtml )
	R.
From: Mike Zinni [mailto:community-noreply@qnx.com]
Sent: Thursday, November 20, 2008 3:09 PM
To: technology-networking
Subject: Can I reduce the TIME_WAIT interval for closed sockets?
data/close to a TCP server I'm running in Neutrino (6.4, so it's the
been used before some time interval expires (I'm assuming it's
minute or so...
lower? Is there any way to avoid TIME_WAIT altogether and close
immediately?
MikeZ
Technology
http://community.qnx.com/sf/go/post17004
Re: RE: Can I reduce the TIME_WAIT interval for closed sockets?
Turns out that this was an issue with the client utility that's used to test our server's functionality. It reuses a set
 of 10 ports, but doesn't have the ability to set the SO_REUSEADDR option (LabVIEW is great, isn't it?!)...
So, combine that with my unfortunate choice to use a short interval between connections, and you've got the recipe for
hunting a non-issue for a day or two...
Thanks for the help regardless...
MikeZ
