Forum Topic - Identify ppp processses running on machine: (6 Items)
Hi
The system for which i am working needs multiple ppp interfaces for respective serial port, and to control (activate /
deactivate PPP links) depending on command received by system.
I am activating each link throguh program by
system("pppd/dev/ser1 proxyarp 115200 192.168.0.40:192.168.0.50");
sleep(2);
system("pppd/dev/ser2 proxyarp 115200 192.168.0.40:192.168.0.50");
through which i am able to activate two ppp links.
what should i do to deactivate any single interface among ppp0, ppp1....i had seen that ppp interface(pid) information
will be there in /var/run/pppn.pid but my target doesnt have full fleged file system, it doesnt have /var ... so through
 what command i can know the existance of ppp interface and deactiavte(terminate/kill) the interface.
Ravi
Re: Identify ppp processses running on machine
> Hi
>  serial port, and to control (activate /deactivate PPP links) depending on
> sleep(2);
> seen that ppp interface(pid) information will be there in /var/run/pppn.pid
> through what command i can know the existance of ppp interface and deactiavte(
> Thanks
> Ravi
Hmm does
#pidin -p pppd fd
provide You with enough infos ?
Jeevan
Hi Jeevan
It works fine ... it lists all ppp interfaces, i also serached and tried getting simialr information through ifaddrs ..
which is a linked list that maintians all netwrok interface related stuff. The command given by you is lisitng
pidin -p pppd fd
   pid name
618531 usr/sbin/pppd
         0  139279 rw        0 /dev/ser1
         1  106512
         2  106512 rw        0 I4UDP  *.*                   *.*
         3  106512 rw        0 I4UDP  *.*                   *.*
         4    8200 rw    10940 /var/run/pppd.tdb
         5  106512 rw        0 I4UDP  *.*                   *.*
         0s      1
i am bit confused on interpreting " 0 139279 rw 0 /dev/ser1" - can you help me in this.
Now if we want to activate or deactivate the ppp interface
- one way is to store informtion of pidin -p pppd fd into one file, filter pid number, and use...... system("kill pid").
- what i am looking at is something like system("ppp0 SIGTERM") which should terminate ppp0 interface, instead of
reading from file - is this possible.
Thnaks
Ravi
> > Hi
> respective
> > sleep(2);
> had
> so
> deactiavte(
> > Thanks
> > Ravi
> Hmm does
> #pidin -p pppd fd
> Jeevan
> Hi Jeevan
> getting simialr information through ifaddrs ..which is a linked list that
> lisitng
> pidin -p pppd fd
>    pid name
pppd's stdin is directed to Your serial driver (139279 is pid from Your serial driver) with having rw perms on /dev/ser1
 with offset 0.
>          1  106512
pppd's stderr is connected to the udp socket without having a connection ... (to be honest I am not realy sure, so
hopeping for external clearence :-))
>          0s      1
>  in this.
> terminate ppp0 interface, instead of reading from file - is this possible.
Try to learn from pidin....
http://community.qnx.com/integration/viewcvs/viewcvs.cgi/trunk/utils/p/pidin/?root=coreos_pub&system=exsy1001
especially Coids(...) function with pidin_proc.c .
Or hope that somebody else here has some shortcut for You or completely other suitable way.
Hope this helps anyway.
> Thnaks
> Ravi
Jeevan
Hi Jeevan
Thansk for link it gave good insight, what i understand is the structure shared_info will holds all data related to
process. So any info of process can be derived from this. Unfortunatly when i copied pidin.h as it is from Revision:
205640
http://community.qnx.com/integration/viewcvs/viewcvs.cgi/trunk/utils/p/pidin/pidin.h?root=coreos_pub&system=exsy1001&view=markup
and build the project it is throwing out some errors
- parse errors before procfs_channel...... in pidin.h
- include <backtrace.h> not
found ... in pidin_proc.c
I dont see any probelm with semicolons missing any where - not really able to figure out the probelm as of now.
Ravi
> > Hi Jeevan
> > lisitng
> > pidin -p pppd fd
> >    pid name
>  driver) with having rw perms on /dev/ser1 with offset 0.
> >          1  106512
> to be honest I am not realy sure, so hopeping for external clearence :-))
> >          0s      1
> me
> >  in this.
> pid
> suitable way.
> > Thnaks
> > Ravi
> Regards,
> Jeevan
> Hi Jeevan
> shared_info will holds all data related to process. So any info of process can
> Revision: 205640
> - include <backtrace.h> not found ... in pidin_proc.c
> Thanks
> Ravi
Hi Ravi,
What kind of DEV host are You using ?
The only thing I can think of is that you run in some kind of prb like me here:
http://community.qnx.com/sf/discussion/do/listPosts/projects.core_os/discussion.buildbugs.topc1359
textto the files.
Hope this helps.
Jeevan
