Forum Topic - Capturing PPP packets with out port number:
Hi
We have network consisting of three systems.
A - source
B - acting as router
C - destination
Between A-B we have UDP running over ethernet. Between B-C we need PPP over serail port.
Once ppp server and client are estbalished between B and C the IP address of C will be sent to A. which means all three
systems have defined IP, B will have 2 one on ehternet port and another for Serail port.
Now task is
1. when A trasmit packet with destiantion IP address of C, B should capture that and channel it through Serail port over
 PPP protocol - for this we are planning to edit routing table of A so that for packets destianted toward C, B will act
as router. i.e from A the next hop for packets realted to C will be B - let me your comments
2. C is a third party system we dont have any control on it expect assignning IP, Initially we thought we will use
socket progamming to tranmsit and receive paskets between B and C, but we dont have any data of port number of C.
please let me know is there any way where i can capture raw packets destainted to an IP irrespective of port number.
simialrly how to send a packets to an Ip with out using scoket program and Port number.
thanks
Ravi
Re: Capturing PPP packets with out port number
PPP already have this feature to help you, it called "proxyarp". :)
When B assign IP address to C, maker sure it assign an IP in same network of A and B. B also need "proxyarp" option for
it's PPPD command line.
It woks like this.
When A try to talk to C, since the IP is on same network, A will ARP. B will see this ARP, and even though it is not B's
 IP, B will response. This way, A will send all it's C destination packet to B, B will then forward it.
Of cause you need to make sure forwarding is enabled on B.
-xtang
----- Original Message -----
To: technology-networking <post16061@community.qnx.com>
Sent: Thu Nov 06 07:20:04 2008
Subject: Capturing PPP packets with out port number
Hi
A - source
C - destination
Now task is
thanks
Ravi
Technology
http://community.qnx.com/sf/go/post16061
Hi Xtang
thanks for quick reponse, here is update for you
ip address of A : 192.168.0.51,B: 192.168.0.31, B: is running on VMware virtaul machine where card Ip is 192.168.0.11.
and on On B i executed follwoing command:
pppd/dev/ser1 proxyarp 115200 192.168.0.35:192.168.0.45
On C: pppd /dev/ser1 115200 ..after this B and C got IP'S confgiured for PPP. The rotuing table of B has follwoing
entries.
# route -v show
Routing tables
Internet:
Destination       Gateway            Flags
localhost.localdo 127.0.0.1          UH
192.168.0.0       link#2             U
192.168.0.11      00:80:ad:83:92:a6  UH
192.168.0.35      192.168.0.35       UH
192.168.0.45      192.168.0.35       UH
192.168.0.45      00:0c:29:ea:f4:a4  UH
after doing this i tried to ping from A to C - but it didnt happened, what i need to enable forwarding on B.
Also let me know
thanks
Ravi
>  and B. B also need "proxyarp" option for it's PPPD command line.
> It woks like this.
> see this ARP, and even though it is not B's IP, B will response. This way, A
> -xtang
> From: ravi varma <community-noreply@qnx.com>
> Hi
> A - source
> C - destination
> serail port.
>  will be sent to A. which means all three systems have defined IP, B will have
> Now task is
> that and channel it through Serail port over PPP protocol - for this we are
>  will act as router. i.e from A the next hop for packets realted to C will be
> IP, Initially we thought we will use socket progamming to tranmsit and receive
>  to an IP irrespective of port number. simialrly how to send a packets to an
> thanks
> Ravi
> Technology
RE: Capturing PPP packets with out port number
First, after failed to ping C, do a "arp -na" on A see if it find the
mac address of C (actually B). If not, we have problem in "proxyarp", we
need to fix this first.
If A do have C in its ARP entry, then:
The C need to be started as:
	pppd /dev/ser1 115200 defaultroute
This way, C will always sent return packet to B.
For forwarding, try "sysctl -w net.inet.ip.forwarding=1".
-xtang
> From: ravi varma [mailto:community-noreply@qnx.com]
> Sent: Thursday, November 06, 2008 9:35 AM
> Subject: Re: Capturing PPP packets with out port number
> Hi Xtang
> thanks for quick reponse, here is update for you ip address
> confgiured for PPP. The rotuing table of B has follwoing entries.
> # route -v show
> Routing tables
> Internet:
> Also let me know
> thanks
> Ravi
> > network of A  and B. B also need "proxyarp" option for it's
> PPPD command line.
> > It woks like this.
> will ARP.
> > B will see this ARP, and even though it is not B's IP, B will
> > -xtang
> > Hi
> > A - source
> > C - destination
> we need PPP
> > over serail port.
> > address of C  will be sent to A. which means all three systems have
> > Now task is
> > capture that and channel it through Serail port over PPP protocol -
> > packets destianted toward C, B  will act as router. i.e from A the
> > assignning IP, Initially we thought we will use socket
> progamming to
> > tranmsit and receive  paskets between B and C, but we dont...
Re: RE: Capturing PPP packets with out port number
Hi Xtang
thanks for your comment. Its working now i am able to ping from A to C. By doing arp -na i am able to see mac adddrss of
 B for both ip's.
192.168.0.31
192.168.0.45 ...
Coming on to my second question in actual system configuration C is a third party system we dont have any control on it
Normally i use socket program to send and receive packets from/to Ip which need specific port number.
Since we made default route in C as PPP, i can think that C might accept packet when send with any port number. But how
cna i receive packet from C with a scoket program running in A, i dont have any clue of which port number to attach to
socket.
thanks
Ravi
> -xtang
> > Hi Xtang
> > # route -v show
> > Routing tables
> > Internet:
> > Also let me know
> > thanks
> > Ravi
> > PPPD command line.
> > > It woks like this.
> > will ARP.
> > > -xtang
> > > Hi
> > > A - source
RE: RE: Capturing PPP packets with out port number
Hi Ravi,
I am not sure I follow you.
"port number" is a UDP/TCP thing, "routing" is an IP thing.
By setting "defaultroute" on C, you tell C that "to reach A (or to reach
anybody), send the packet to B".  So when you ping, telnet, ... from A
to C, the "return packet" that C want  to send back to A, will all goes
to B. And of cause, B knows how to route it back to A.
"defaultroute" is a very normal option on ppp. Because from C's point of
view, B is his only way to get to internet.
If you really don't have any control of C, and C is not setting up any
proper routing table to allow A to access it. You have other options:
1) If both A and B are QNX, then there is QNET
2) if only B is QNX, then you need NAT (network address translate).
-xtang
> Sent: Friday, November 07, 2008 6:40 AM
> Subject: Re: RE: Capturing PPP packets with out port number
> Hi Xtang
> B for both ip's.
> 192.168.0.31
> 192.168.0.45 ...
> A, i dont have any clue of which port number to attach to socket.
> thanks
> Ravi
> it find the
> "proxyarp", we
> > -xtang
> > > Hi Xtang
> > > # route -v show
> > > Routing tables
> > > Internet:
> > > after doing this i tried to ping from A to C - but it didnt...
Re: RE: RE: Capturing PPP packets with out port number
Hi
Sorry if it confused you, what i am aksing is from program point of view.
See A will be sending messages some of which are specific to B and some are specific to C. So i will enable forwarding
in B so that all messages related to C will be forwarded to C.
My question is : Now from A point of view if i need to receive or transmit messages to C through a socket program, how
can i do that with out knowing port number of C. Since in socket program we require port number to sent or receive UDP
frames.
Is there any approcah to send/Receive packets at raw level where Port number will not come into picture.
Ravi
> Hi Ravi,
> Regards,
> -xtang
> > Hi Xtang
> > B for both ip's.
> > 192.168.0.31
> > 192.168.0.45 ...
> > thanks
> > Ravi
> > it find the
> > "proxyarp", we
> > > -xtang
> > > > Hi Xtang
RE: RE: RE: Capturing PPP packets with out port number
I think that you're asking a very different question here.  This is
solely at the application level and is at your discretion.  The "normal"
mechanism for doing this is to use a "well known" port for your service
(that is, you pick a port that both the server and client use).  You
could use raw IP but that bypasses all of the advantages of using the
higher layer protocols.
	R.
Sent: Monday, November 10, 2008 2:02 AM
Subject: Re: RE: RE: Capturing PPP packets with out port number
Hi
view.
are specific to C. So i will enable forwarding in B so that all messages
transmit messages to C through a socket program, how can i do that with
number to sent or receive UDP frames.
Ravi
> Hi Ravi,
reach
goes
of
> Regards,
> -xtang
> > Hi Xtang
> > B for both ip's.
> > 192.168.0.31
> > 192.168.0.45 ...
> > thanks
> > Ravi
> > it find the
> > "proxyarp", we
Re: RE: RE: RE: Capturing PPP packets with out port number
Hi
thanks, i got the solution. since B is transparently passing messages among A and C, this is fine for me. of late i came
 to know that vendor will support sofware in A which will communciate with C, so internally they might be fixing the
port number to be same on both sides.
Thnaks for your support.
Ravi
> 	R.
> Hi
> view.
> Thanks
> Ravi
> > Hi Ravi,
> reach
> goes
> of
> > Regards,
> > -xtang
> > > Hi Xtang
> > > B for both ip's.
> > > 192.168.0.31
> > > 192.168.0.45 ...
> > > cna i receive packet from C...
Hi
i am facing probelm with port forwarding. As discussed in earlier post
We have network consisting of three systems. A - source, B - acting as router, C - destination.
A ip: 192.168.0.31, B IP:192.168.0.51
we need PPP over serail port. i used
pppd/dev/ser1 proxyarp 115200 192.168.0.61:192.168.0.62 between B and C. and on C :
pppd/dev/ser1 proxyarp 115200 defaultroute
and i also enabled port forwarding by sysctl -w net.inet.ip.forwarding=1
Earlier i was able to do ftp from A to C, but suddenly i am not sure what happened i am not even able to ping from A to
C, when i checked
arp -na on A i am able to see entry of C as
? (192.168.0.62) ar 00:12:3f:2d:31:2c on en0 ... the MAc addr shown is that of B's ethernet port, which is hope is
correct.
route table in B has entry
dest                  Gateway                     flags
192.168.0.65     00:12:3f:2d:31:2c        UH
it is same MAC addr of ethernet port.
I also observed by doing ping -r 192.168.0.62 from A for which i am getting:
36 bytes  from 192.168.0.51: Time to Live exceeded for icmp_seq=0..
which is making me to think that forwarding is done properly... is there any thing that i need to do ?, or any other way
i tried traceroute etc but it was abel to trace from A tol B, moreover i am not sure it is applicale to ppp over serial
link.
thanks
Ravi
> > > > and C the IP
> > > > systems have
> > > > > > > Now task is
> Hi
> and C, this is fine for me. of late i came to know that vendor will support
>  the port number to be same on both sides.
> Ravi
> > 	R.
> > Hi
> > view.
> > Thanks
> > Ravi
> > > Hi Ravi,
RE: RE: RE: RE: Capturing PPP packets with out port number
What do you're routing tables look like for each host?
(route show)
 	Robert.
Sent: Monday, December 01, 2008 8:11 AM
Subject: Re: RE: RE: RE: Capturing PPP packets with out port number
Hi
and on C :
what happened i am not even able to ping from A to C, when i checked arp
that of B's ethernet port, which is hope is correct.
dest                  Gateway                     flags
getting:
any thing that i need to do ?, or any other way.
am not sure it is applicale to ppp over serial link.
thanks
Ravi
> > > > and C the IP
> > > > systems have
> > > > > > > Now task is
> Hi
> among A and C, this is fine for me. of late i came to know that vendor
> they might be fixing  the port number to be same on both sides.
> Ravi
"normal"
> > service (that is, you pick a port that both the server and client
> > use).  You could use raw IP but that bypasses all of the advantages
> > of using the higher layer protocols.
> > 	R.
> > Hi
> > view.
> > some are specific to C. So i will enable forwarding in B so that all
> > with out knowing port number of C. Since in...
Can you "ping -n 192.168.0.62" from B ?
C is standalone, and do not have other Ethernet connection does it?
To find out the detail, we probably need "netstat -ni" and "netstat -nr" output from all 3 machines.
-xtang
> Hi
>  C - destination.
> on C :
> dest                  Gateway                     flags
> thanks
> Ravi
Hi
I added new route in routing table of C, i observed even though i am enabling C as  pppd/dev/ser1 proxyarp 115200
defaultroute the default route chosen is for some other ip address than A, so i added new route
route add ipA ipb  , ip b is ip of serail port ruuning on PPP..it is working now..but thanks for suggesting "netstat -ni
" and "netstat -nr" they were helpful in debugging
Ravi
> -xtang
> > Hi
> router,
> >  C - destination.
> > on C :
> of
> > dest                  Gateway                     flags
> > thanks
> > Ravi
