Forum Topic - Receiving RSVP Packets and IP Header problem: (3 Items)
I am looking at a strange problem while receiving RSVP packets. In our system, we send and receive RSVP packets using
RAW sockets. The problem we are seeing is this:
Packets are sent properly from the source node and the packets reach the destination. Correctly. We verified that the
packet received in our example had totlen field on IP header as 264. However, when we receive the packets through
recvfrom interface along with the IP header, the totlen field is now 244 instead of 264. Rest of the header looks good.
The only layer between the point where tcp dump sniffs packet and the application is the iopkt layer. Can someone shed
some light on what might be happening here?
Santosh
Re: Receiving RSVP Packets and IP Header problem
On Sat, Nov 01, 2008 at 08:05:11AM -0400, Santosh Kumar wrote:
> Thanks,
> Santosh
See this section of code in rip_input().
  * XXX Compatibility: programs using raw IP expect ip_len
  * XXX to have the header length subtracted, and in host order.
  * XXX ip_off is also expected to be host order.
 ip->ip_len = ntohs(ip->ip_len) - (ip->ip_hl << 2);
 NTOHS(ip->ip_off);
Hi Sean,
Thanks for the information. I did some digging too and did find this....for anyone who's new to BSD flavored stacks.
    raw socket with IP_HDRINCL uses different network byteorder for some
        of the IP header fields (ip_off and ip_len).  i think the behavior
        is confusing, and the culprit is 4.[34]BSD. (4.[34]BSD should have
        cleaned it up before supplying this API to users)
        - openbsd:
                rip_input: host byteorder, ip_len is payload length
                rip_output: network byteorder, ip_len is for the whole packet
        - netbsd:
                rip_output: host byteorder, ip_len is for the whole packet
                (same as 4.4BSD, but internally we use network byteorder all
                the way throughout the IPv4 code)
        - freebsd:
                (same as 4.4BSD)
        i think both case should be network byteorder, and ip_len field
        should reflect the length of the whole packet instead of the payload
        length.
-Santosh
> > Hi,
> system, we send and receive RSVP packets using RAW sockets. The problem we are
>  seeing is this:
> destination. Correctly. We verified that the packet received in our example
> through recvfrom interface along with the IP header, the totlen field is now
> application is the iopkt layer. Can someone shed some light on what might be
> happening here?
> > Thanks,
> > Santosh
> -seanb
>  NTOHS(ip->ip_off);
