Forum Topic - io-pkt and route cache?: (6 Items)
We implemented some API's to Add/delete and flush routes. The code is based along the same lines as route application.
But Im seeing a strange behavior. When our system comes up, it programmatically configures an ethernet interface using
ioctl calls followed by adding a default route. The routing table reflects the right setting. So far so good. However if
 I try to ping the gateway, it doesnt work.
If I then delete the route using route delete command and then add the same route back, things start working.
Is there some sort of a route cache that needs to be flushed before we begin adding/removing entries from the routing
table?
Help please!
Santosh
Re: io-pkt and route cache?
> along the same lines as route application. But Im seeing a strange behavior.
>  using ioctl calls followed by adding a default route. The routing table
> reflects the right setting. So far so good. However if I try to ping the
> adding/removing entries from the routing table?
> Help please!
> Thanks,
> Santosh
Santosh,
As a shot into the dark from my side:
Try flushig ARP cache
arp -d -a
Hope this helps.
Jeevan
I will first agree with Jeevan.
Could you show your routing table and your arp table first when you can not reach your gateway?
And please show your routing table and arp table when you can reach your gateway.
take a look at what nestat shows will help too, for example: icmp layer, ip layer.
In all stacks they all have routing cache, in your case you are sending out so in its inpcb it will keep a route cache
too then it doesn't need to lookup routing table everytime but hard to tell where is wrong.
In Linux you can show routing cache too but for bsd I didn't find it yet.
If I were you I will use a hub and tcpdump to monitor whether the icmp packets is out or not and whether the dest mac is
 right too, then we can know whether stack is wrong.
Hi Jeevan,
This doesnt work.
-Santosh
> > Hi,
> interface
> > Help please!
> > Thanks,
> > Santosh
> Santosh,
> arp -d -a
> Hope this helps.
> Jeevan
Hi Santosh,
As said it was just shot in the into the dark.
I have no Idea but for me tables are tables however they are decorated.
As Yao said You might want to show the relevant route tables and once it works once it doesn't work.
Maybe the others can help once You provide the parts of Your source  where You decorate Your table . Maybe this is just
a decoration problem.  Another thought : Is this happening with all test hw setup or just with one special test-env.
again and again?
-Dono-Jeevan
> Hi Jeevan,
> This doesnt work.
> -Santosh
I can't really think off hand what might be happening.
Does it matter which driver is running?  The only
thing I can think of is to post your app and I could
give it a quick whirl here.
