Forum Topic - sockaddr_in: (5 Items)
sockaddr_in
Is the layout and size of the sockaddr_in some sort of standard.
We bought the source for adriver that implement a communication protocol.  In this protocol the sockaddr_in is sent as
had into the stream.  One of the requirement of this protocol is the endianess of sin_family.    The code does
sin_familly = htnos ( AF_INET ).  On QNX this breaks because sin_familly is a char.  I checked on other OSes and in all
of them sin_familly is a short.
Is the maker of that driver wrong to assume the layout of sockaddr_in?
Re: sockaddr_in
all of them sin_familly is a short.
POSIX says it's an unsigned int so uint8_t is confirmant.
I checked linux and *BSD.  On linux it's an unsigned short
and on the BSD's it's a uint8_t.  I think on linux it's
supposed to be in host order as this field doesn't go out
on the wire so the htons is probably a bug.  Is the driver
being brought over from a big endian environment?
Re: sockaddr_in
> In this protocol the sockaddr_in is sent as had into the stream.  One of the
> a char.  I checked on other OSes and in all of them sin_familly is a short.
No but the protocol requires a sockaddr_in like structure to be send over the wire and it must be big endian.  Maybe the
 protocol comes from a big endian environment that I don't know.
> -seanb
Re: sockaddr_in
> wire and it must be big endian.  Maybe the protocol comes from a big endian
If that's the case the protocol should define a
private struct, not use sockaddr_in.  I'd assumed
you were talking about a sockaddr_in being passed
to bind(), connect() etc in which case I bet the htons()
would break on little endian linux.
Re: sockaddr_in
> the
The make of that driver agreed their code is broken and will use their own private flavor of sockaddr_in.
Thanks!
> -seanb
