08/22/2008 4:28 PM
post12299
Hi Sean/Robert,
I am guessing that you have heard from Yao regarding the io-pkt crash issue. I would like to provide you a brief
background of the code and whats loaded on it.
1. All modifications that I did on io-pkt are commented with "Santosh Added/Modifed/removed" tags surrounding the code.
a simple grep would tell you all files that I have touched. I have a cleaner implementation in mind but havent gotten
around to making that yet.
2. Following modules are loaded when io-pkt is running:
a. lsm-qnet
b. pq2fads-ppc8260 driver (QNX provided)
c. Broadcom BCM5691Driver
d. lsm-tipc (ported TIPC software)
3. io-pkt doesnt crash right away. It usually crashes after around 2-3 hours of operation. When running CPU utilization
remains normal (used hogs to check).
I have provided the source code of io-pkt but havent provided for TIPC or Broadcom. Let me know what I can do.
Santosh
08/25/2008 9:13 AM
post12341
> io-pkt ... crashes after around 2-3 hours
Ensure that dumper is running. Examine the
core dump with gdb, which will tell you what
code caused the crash.
If you're not sure how to do this, no problem.
Create a tar file with your io-pkt executable
and core file and all loaded dll .so files,
which are listed by:
# pidin -p io-pkt-v4 mem
Once you figure out which dll is causing the
crash, re-compile it with "-g -O0", get another
core dump, and gdb will tell you exactly which
line of code you crashed on, which variable was
being accessed, etc. At this point the problem
should be pretty self-evident.
Easily reproducible core dumps are generally
pretty low-hanging fruit.
aboyd
08/25/2008 10:19 AM
post12356
Hi Andrew,
I've already done the first part and the code consistently seems to crash in one specific area. I have passed on the
core, binary and source of it to support and got a response that some thread if crashing the stack itself.
With so many .so loaded, how do I figure out which specific dll casued this (assuming it is dll which is causing it).
I've been advised to run io-pkt with dll's included with all symbols and let things run till crash occurs and then
hopefully the stack trace would tell me whats happening. I will be trying this today.
If there is a easier method to know which dll is causing the problem, let me know. Maybe I should run the test with only
a specific dll loaded at a time assuming the culprit bring one of our internally developed drivers/module. I could do
that simultaneously.
Thank you for your advise.
Santosh
> From: Santosh Kumar
> aboyd
08/25/2008 10:24 AM
post12359
Where?
The backtrace in gdb (of the core dump) will tell you in which
function (of which dll) that the crash occurred.
If you then compile that dll debug (-g -O0) then the next
core file you get, gdb will tell you which exact line and
variable access caused the crash.
aboyd
08/25/2008 10:33 AM
post12361
Hi Santosh:
We're in a difficult position because the core dump that you
sent us doesn't seem to be of much use for some reason. We also don't
have the capability of reproducing your set up given the driver / stack
mods / new protocol that are part of your setup. While the stack is in
the section of the code that is related to io-pkt directly, without a
backtrace, there isn't really much that we can do to diagnose the root
cause of the issue. My recommendation is to build a full debug version
of the stack, drivers and protocols and set things up to run everything
in GDB. As long as you've got multiple interfaces, you can have one
instantiation of the stack set up to interface with your host and GDB
which then runs the second instance of the stack with all of the
protocols to reproduce the crash.
I can walk you through this if you like...
Robert.
From: Santosh Kumar [mailto:community-noreply@qnx.com]
Sent: Monday, August 25, 2008 10:20 AM
To: technology-networking
Subject: Re: RE: io-pkt Crash
Hi Andrew,
crash in one specific area. I have passed on the core, binary and source
stack itself.
this (assuming it is dll which is causing it). I've been advised to run
crash occurs and then hopefully the stack trace would tell me whats
let me know. Maybe I should run the test with only a specific dll loaded
drivers/module. I could do that simultaneously.
Santosh
> From: Santosh Kumar
> aboyd
Technology
http://community.qnx.com/sf/go/post12356
08/25/2008 12:38 PM
post12374
Hi Robert,
I got what needs to be done. Ill set it up and when I get the crash Ill report back.
Santosh
> Hi Santosh:
> Robert.
> Hi Andrew,
> stack itself.
> Regards,
> Santosh
> > From: Santosh Kumar
> > aboyd
> Technology
08/25/2008 10:47 AM
post12363
As a side note, io-pkt has a SIGSEGV handler in it that may be causing
the confusing backtraces that we're seeing.
The SIGSEGV handler is needed to gracefully bring down drivers that may
try to DMA data into areas of memory that are no longer "owned" by the
stack after the process has died.
To make it easy, you can just comment out the lines in trunk/sys/main.c
(around line 300... sigdelset(&signals, SIGSEGV) / signal(SIGSEGV,
segv_handler)) so that the SIGSEGV comes directly from the code instead
of the signal handler.
Robert.
Sent: Monday, August 25, 2008 10:34 AM
To: 'post12356@community.qnx.com'
Subject: RE: RE: io-pkt Crash
Hi Santosh:
Robert.
Hi Andrew,
stack itself.
Santosh
> From: Santosh Kumar
> aboyd
Technology
08/25/2008 10:51 AM
post12364
If you update your gdb, it will
do the "right thing" and backtrace
through the SIGSEGV hander to the
real culprit. 6.7 seems to do the
trick.
I am a real fan of the sigsegv
handler, because the hardware is
squelched, and doesn't continue
writing into memory that the OS
thinks is free.
aboyd
08/25/2008 1:24 PM
post12377
I typically debug using the Momentics IDE. You mentioned I need to update the gdb. You mean ntoppc-gdb needs to be
updated? What version do you recommend and where can I find the binaries for it if any?
Santosh
> From: Robert Craig
> trick.
> thinks is free.
> aboyd
08/25/2008 1:30 PM
post12378
> You mean ntoppc-gdb needs to be updated?
right - that's what I used, to examine a
core dump.
6.7
I can give you a URL to an internal server, but that's
not going to help you any! I can email you an x86
binary of ntoppc-gdb if that helps.
aboyd
Re: RE: RE: RE: io-pkt Crash
08/25/2008 1:39 PM
post12380
Yes please can you email it to me? I seem to have version 5.2. Thanks!
-Santosh
08/25/2008 1:41 PM
post12381
The command-line tools project has downloads...
http://community.qnx.com/sf/projects/toolchain
> -Santosh
> Technology
> http://community.qnx.com/sf/go/post12380
cburgess@qnx.com
08/25/2008 1:37 PM
post12379
Hi Santosh:
That's a tricky one. I THINK that you'll be OK as long as you don't
try and backtrace through the signal handler (which is why I suggested
removing registering the signal handler for your debug version). I'm
not sure how you'd go about updating the GDB binaries on your host and
still have everything play nicely together with the IDE. The other
possibility is to try using the 6.4.0 pre-release since it's got updated
everything in it.
Robert.
Sent: Monday, August 25, 2008 1:25 PM
Subject: Re: RE: RE: io-pkt Crash
update the gdb. You mean ntoppc-gdb needs to be updated? What version do
Santosh
> From: Robert Craig
> trick.
> thinks is free.
> aboyd
Technology
http://community.qnx.com/sf/go/post12377
08/25/2008 1:44 PM
post12382
> I'm not sure how you'd go about updating the GDB binaries on your host and
> everything in it.
I intend to take a backup of my existing version and then use the x86 binary Andrew would email me. Since IDE invokes
ntoppc-gdb internally, it should take up the new one unless there are some dynamic libraries that it depends on which I
wouldnt have with my 6.3.2 installation. Upgrading to 6.4.0 pre-release would take a lot of time wouldnt it? Im doing
several things in parallel. Anyway let me know. Otherwise, I would simple comment out the lines you recommended and use
existing gdb version 5.2
Santosh
RE: RE: RE: RE: io-pkt Crash
08/25/2008 1:58 PM
post12383
Let's give Andrew's binary a try. If that doesn't work, comment out the
SIGSEGV handler and if THAT doesn't work, trying the 6.4.0 pre-release
would be the last option.
R.
Sent: Monday, August 25, 2008 1:45 PM
Subject: Re: RE: RE: RE: io-pkt Crash
and
updated
> everything in it.
binary Andrew would email me. Since IDE invokes ntoppc-gdb internally,
that it depends on which I wouldnt have with my 6.3.2 installation.
doing several things in parallel. Anyway let me know. Otherwise, I would
simple comment out the lines you recommended and use existing gdb
version 5.2
Santosh
Technology
http://community.qnx.com/sf/go/post12382
Re: RE: RE: RE: RE: io-pkt Crash
08/25/2008 3:30 PM
post12398
> R.
Right now, I have setup a system with debugger attached to it. Im using gdb 5.2 with no signal handler for SIGSEGV.
If that doesnt help or I see something weird then Ill try Andrew's binary followed by 6.4.0 release option.
Will post the results as soon as I get the crash.
Santosh
08/25/2008 6:45 PM
post12409
I was unable to reproduce the crash, There was one difference between the current setup and the previous one.
In order to perform remote debug, I started io-net with prefix=/home/alt and then started io-pkt. Loaded all modules as
usual excepting one Ethernet interface (using devn-pq2fads-ppc8260.so) and lsm-qnet module. In the origninal setup that
crashed, I was bring up io-pkt with the BSP and no io-net at all.
What can I now do to attach/start the debugger and try to reproduce the same problem? Do you guys have native ppc gdb?
-Santosh
08/25/2008 9:20 PM
post12411
If you have a serial port you can run pdebug over that...
(target)
# pdebug /dev/ser1,57600
(host)
(gdb) set remotebaudrate 57600
(gdb) target qnx /dev/ser1
Then you don't need the extra io-net
as usual excepting one Ethernet interface (using devn-pq2fads-ppc8260.so) and lsm-qnet module. In the origninal setup
that crashed, I was bring up io-pkt with the BSP and no io-net at all.
> -Santosh
> Technology
> http://community.qnx.com/sf/go/post12409
cburgess@qnx.com
08/25/2008 11:05 PM
post12412
> (target)
> (host)
Thanks I will try this. However, I am connected to the system via serial port through a terminal server. Is it possible
to configure pdebug to use that? Let me know, if not, I will hook it up to my machine overnight today.
Santosh
> > Hi,
> then started io-pkt. Loaded all modules as usual excepting one Ethernet
> origninal setup that crashed, I was bring up io-pkt with the BSP and no io-net
> at all.
> > -Santosh
> > Technology
> cburgess@qnx.com
08/25/2008 11:31 PM
post12413
or just let it crash and get core if you have the sigv_handler commented out.
08/25/2008 11:45 PM
post12414
As long as the terminal server is 8 bit clean I think it would work...
>> (target)
>> (host)
possible to configure pdebug to use that? Let me know, if not, I will hook it up to my machine overnight today.
> Thanks,
> Santosh
>>> Hi,
>> at all.
>>> -Santosh
>>> Technology
>> cburgess@qnx.com
> Technology
> http://community.qnx.com/sf/go/post12412
cburgess@qnx.com
RE: RE: RE: RE: RE: io-pkt Crash
08/26/2008 10:29 AM
post12430
Hi Santosh:
The OTHER possibility is that by compiling everything with a
different optimization level, you've changed the behaviour such that
things no longer crash. Can you reproduce the crash using the new
binaries without changing anything else?
Robert.
Sent: Monday, August 25, 2008 6:46 PM
Subject: Re: RE: RE: RE: RE: io-pkt Crash
and then started io-pkt. Loaded all modules as usual excepting one
In the origninal setup that crashed, I was bring up io-pkt with the BSP
-Santosh
Technology
Re: RE: RE: RE: RE: RE: io-pkt Crash
08/26/2008 11:32 AM
post12442
I am still using Santosh's old core dump:
NowI knew we have a segv_handler in io-pkt then the disassembly in core file makes sense and looks like executable is
relocated, that is why ntoppc-gdb can't figure out the correct backtrace with correct function name.
My analysis below:
r0 0x480864fc 1208509692
r1 0x47fbeb00 1207692032
r2 0x480d5610 1208833552
r3 0x0 0
r4 0xfe36dea0 4265008800
r5 0x4 4
r6 0x3ff 1023
r7 0x9 9
r8 0xfe377e38 4265049656
r9 0x0 0
r10 0xfe36e0b8 4265009336
r11 0x0 0
r12 0x48681038 1214779448
r13 0x480d9a48 1208851016
r14 0x0 0
r15 0x0 0
r16 0x0 0
r17 0x2 2
r18 0x79ef506e 2045726830
r19 0x110f6584 286221700
r20 0x0 0
r21 0x0 0
r22 0x14 20
r23 0x4862d900 1214437632
r24 0x10 16
r25 0x480d6d58 1208839512
r26 0x47fbee24 1207692836
r27 0xc0a80a5a 3232238170
r28 0xfffffffc 4294967292
r29 0x48681010 1214779408
r30 0x47fbeb20 1207692064
r31 0x47fbeb98 1207692184
pc 0x48086510 1208509712
cr 0x2000003f 536870975
lr 0x480864fc 1208509692
ctr 0xfe37bcb0 4265065648
xer 0x0 0
(gdb) x/128 0x47fbeb00-32
0x47fbeae0: 0x47fbeb00 0x48081b94 0x00000000 0x480f0e58
0x47fbeaf0: 0x47fbeb20 0x480f1d90 0xfe380aa8 0x47fbeb98
0x47fbeb00: 0x47fbeb10 0x480864fc 0x00000000 0x480f0e58
0x47fbeb10: 0x47fbeb20 0xfe31b540 0x48635c00 0x480e88c0
0x47fbeb20: 0x0000000b 0x00000001 0x00000000 0x0000000b
0x47fbeb30: 0x4807ed2c 0xc0a80a5a 0x00000000 0x00000000
0x47fbeb40: 0x00000000 0x00000000 0x480864e0 0x47fbeb80
0x47fbeb50: 0xffbffafd 0xffffffff 0x00000000 0x84000000
0x47fbeb60: 0x47fbeb90 0xfe37c194 0x00000000 0x00000000
0x47fbeb70: 0x47fbeb90 0x00000000 0x00000044 0x00000001
0x47fbeb80: 0x00000000 0x00000000 0x00000000 0x00000000
0x47fbeb90: 0x00000000 0x00000000 0x00000024 0x47fbed50
0x47fbeba0: 0x480d5610 0x48635c00 0x4862fc6c 0x47fbee24
0x47fbebb0: 0x00000400 0x00000000 0x4862d900 0x00000000
0x47fbebc0: 0x00000001 0x4862fc6c 0x48681038 0x480d9a48
0x47fbebd0: 0x00000000 0x00000000 0x00000000 0x00000002
0x47fbebe0: 0x79ef506e 0x110f6584 0x00000000 0x00000000
0x47fbebf0: 0x00000014 0x4862d900 0x00000010 0x480d6d58
0x47fbec00: 0x47fbee24 0xc0a80a5a 0xfffffffc 0x48681010
0x47fbec10: 0x00000000 0x48635c00 0x00000000 0x4807dd60
0x47fbec20: 0x800ab932 0x4807ed2c 0x84000034 0x00000000
0x47fbec30: 0x47fbec40 0xfe339f88 0x00000014 0x00000000
0x47fbec40: 0x000005dc 0x00000000 0x00000000 0x00000002
0x47fbec50: 0x00000044 0x480e88c0 0x00000000 0x480ef6c0
0x47fbec60: 0x47fbec90 0x48059c98 0x00000000 0x480f0e58
0x47fbec70: 0x47fbec90 0x00000000 0x48635c00 0x480e88c0
0x47fbec80: 0x47fbeca0 0x480ef6c0 0x480dd320 0x000000ff
0x47fbec90: 0x47fbecf0 0x4805cb78 0x48635c5c 0x486657bc
0x47fbeca0: 0x47fbecd0 0x480a6f14 0xfe380aa8 0x4816c8e0
0x47fbecb0: 0x00000020 0x00000014 0x4862da00 0x00000000
0x47fbecc0: 0x486657bc ...
08/26/2008 1:21 PM
post12446
> Hi Santosh:
> Robert.
Hi Robert,
I think you might be right. I ran the same binaries without signal handler overnight and it still hasnt crashed. What is
the default optimization level of the non-debug version? Maybe I can simple set the CCOPTS flag with -O0 but without
the -g option and then run the whole thing again. I have seen strange behaviors with optimization all the time. So
wouldnt be surprised. What do you suggest?
Santosh
> -Santosh
> Technology
08/26/2008 1:36 PM
post12448
Hi Santosh:
These problems can be pretty tricky to track down and suggest
either a compiler optimization bug or code assumptions that are
incorrect (usually something like multi-threading where a "volatile"
keyword has been forgotten). In any case, until you know for sure, you
might just be narrowing a timing window for the fault as opposed to
removing it altogether, so it can come back and bite you later.
This could take a bit of time, but I'd suggest trying to get to the root
cause. Compiling everything without optimizations is going to have a
significant performance penalty. Figure out which of the binaries
(driver, io-pkt, protocol) is causing the problem and then try and work
it down to the source file (that isn't going to be easy). I'd also
recommend keeping out the SIGSEGV handler so that you can get a
backtrace. That'll give you more information about which source files
you should try compiling un-optimized....
Robert.
Sent: Tuesday, August 26, 2008 1:22 PM
Subject: Re: RE: RE: RE: RE: RE: io-pkt Crash
> Hi Santosh:
> Robert.
Hi Robert,
handler overnight and it still hasnt crashed. What is the default
CCOPTS flag with -O0 but without the -g option and then run the whole
time. So wouldnt be surprised. What do you suggest?
Santosh
prefix=/home/alt
module.
BSP
the
> -Santosh
> Technology
Technology
http://community.qnx.com/sf/go/post12446
08/26/2008 1:51 PM
post12452
Hi Robert,
Thanks for the advice. Ill try various combinations and reproduce this.
-Santosh
> Hi Santosh:
> Robert.
> > Hi Santosh:
> > Robert.
> Hi Robert,
> Thanks,
> Santosh
> > Hi,
> prefix=/home/alt
> module.
> BSP
> the
> > -Santosh
> > Technology
> Technology
08/27/2008 3:26 PM
post12501
I finally got lucky with a crash and got a good core dump. I found the bug too. It was because of the changes I made for
supporting sending packets through a specific interface.
I had to change io_output function to handle the special ancillary messages passed in by the application (this is how
ipv6 code handles). This required me to pass in a new parameter to ip_output function. For Raw and UDP, I handled the
ip_output appropriate. When it came to TCP, I simply updated at the obvious place in tcp_output.c and tcp_input.c. Once
I made those changes, everything seemed to work well so I didnt bother looking at other places in the netinet code. Big
mistake.
The crash was actually occurring in tcp_subr.c where the ip_output function was being invoked. I hadn't updated that
file. ip_output function originally accepted 6 parameters and uses va_arg functions to access the parameters(the ipv6
code doesn't use va_arg). With my changed ip_output function, I had to pass in a NULL at the proper place. Use of the
va_arg didnt help either since the compiler was always happy.
I still dont know why it took so long to crash though. Maybe things just continued till a lot of memory was overwritten
and then finally it crashed.
So, I identified all files in the netinet directory that calls ip_output function and updated each one of them.
I am wondering what would be the best way to do this without needing to change the interface. I could either have a
special ip_output function for UDP and RAW packets (which are the only ones that I use the sending out on specific
interface for) OR I could pass in the argument as a last parameter to ip_output (feel quite stupid about not doing that
instead of passing it as the second parameter. I guess was initially trying to just make it work and then never had
time for cleanup) OR maybe some other ideas that some of you could recommend OR maybe it might be a good idea to make
the ip_output interface more like ip6_output interface. That way, if changes are made to the interface, the compiler
would catch it.
I added in my fix and ran two systems, one with debug io-pkt and the other one was build using normal compilation. I ran
the test overnight. Checked it this morning and no crash. So far so good.
Please pass me suggestions on improving this implementation.
Santosh
> Hi Santosh:
> Robert.
> > Hi Santosh:
