Forum Topic - Hung system while performing a ping flood on parent and its VLAN interface.: (4 Items)
I have got a hung system when trying to perform a ping flood on the parent and its VLAN interfaces at the same time.
When performing it individually, system is stable. This is not a blocking issue. What information would be useful to
provide. Please let me know.
This is QNX 6.3.2 with Networking revision 400 and I have modified io-pkt to support one RFC 2292 feature.
Santosh
Re: Hung system while performing a ping flood on parent and its VLAN interface.
On Thu, Aug 21, 2008 at 03:39:46PM -0400, Santosh Kumar wrote:
Make sure you've done a shutdownhook_establish() in your
driver that detaches from the hardware (including interrupt).
Hi Sean,
Im sorry. Can you explain a little bit more? What does shutdownhook_establish do? How is it potentially related to this
problem?
Santosh
> > Hi,
> and its VLAN interfaces at the same time. When performing it individually,
> useful to provide. Please let me know.
> -seanb
On Thu, Aug 21, 2008 at 03:55:42PM -0400, Santosh Kumar wrote:
> Hi Sean,
this problem?
One scenario that can cause issues is when a network
driver is using a shared interrupt and io-pkt is
shutdown or faults and the hardware is not quieted.
In such a situation a NIC can leave an interrupt
asserted and the other manager that was sharing
the interrupt can spin.  You can check for shared
interrupts with 'pidin irq'.
Just a theory at this point...
Try shutdownhook_establish(), run a high prio shell,
try to avoid shared interrupts for now.
