Forum Topic - ftpd: DNS lookup & anonymous lookup: (14 Items)
When I connect to the QNX ftp server it takes 20 seconds before I get the login prompt.  Looking at the network trace I
see it is trying to look up the client's DNS name.  Looking at the ftp documentation and code I see now way to turn this
 off.  Is there a way to turn this off?
We are moving to qnx but need the option of being backward compatible with our old systems.  One of the things we need
to support is ftp login to a guest account without a user name, and no password prompt.    Looking at the documentation
& code I see this isn't a current option.  When I try it I get the error:
"500 'USER ':command not understood".
Wanting to see how much of a change it would be to support this I tried changing cmdtab[] in file ftpcmd.y to list USER
as a ZSTR1, but I still get the same error and don't make it to the user() in ftpd.c (where other changes would be
needed).  Is there some other location that needs to be changed to let the request make it to user() in ftpd.c?  Is
there any plan to add a configuration parameter to allow an empty user name login?
Re: ftpd: DNS lookup & anonymous lookup
> login prompt.  Looking at the network trace I see it is trying to look up the
>  turn this off.  Is there a way to turn this off?
Make sure /etc/resolv.conf is empty.
RE: ftpd: DNS lookup & anonymous lookup
Hi Jared:
Before I dig in, is this with the io-net network stack or io-pkt?  Ftpd
for io-pkt is a completely new port so the behaviour of the two may be
different.
I suspect that it's io-pkt given that you're looking at the source.  I
think that what needs to get done is that "no user / no password"
results in "anonymous : anonymous"  since you MUST have a user name of
some sort in order to make sure that access permissions get assigned
correctly.
	Robert.
Sent: Wednesday, July 02, 2008 4:51 PM
To: technology-networking
Subject: ftpd: DNS lookup & anonymous lookup
the login prompt.  Looking at the network trace I see it is trying to
code I see now way to turn this off.  Is there a way to turn this off?
with our old systems.  One of the things we need to support is ftp login
Looking at the documentation & code I see this isn't a current option.
changing cmdtab[] in file ftpcmd.y to list USER as a ZSTR1, but I still
other changes would be needed).  Is there some other location that needs
to be changed to let the request make it to user() in ftpd.c?  Is there
login?
Technology
http://community.qnx.com/sf/go/post9961
Re: RE: ftpd: DNS lookup & anonymous lookup
I am using io-pkt.
Having the code map "no user / no password" to "anonymous : anonymous" without the password prompt would work great.  I
do realize we to need to map it to a user for access permissions.
I see it is trying to look up the client's DNS name.  Looking at the ftp documentation and code I see now way to turn
I added a -n option to ftpd to prevent this.  Still thinking
about the other issue.
Enjoy.
The -n works great.
Have you come up with any way to have no_username login as anonymous with an anonymous password (without the password
request)?
No chance of adding an option to the client side?  Most FTP clients seem
to support the "-a" (or -A option for windows) for anonymous login which
seems to be the "standard" way of not having to pass in a username /
password....
	Robert.
Sent: Monday, July 14, 2008 12:53 PM
Subject: Re: ftpd: DNS lookup & anonymous lookup
The -n works great.
with an anonymous password (without the password request)?
Technology
http://community.qnx.com/sf/go/post10478
We don't control the ftp client our users are using.
For multiple reasons our next generation product needs to backward compatible.  Our current system will handle the case
where they don't supply a user name.
case where they don't supply a user name.
Which client exibits this behaviour?
I have been using the DOS/Windows ftp client for my testing.
Jared
Can you post a sample session showing this behaviour.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
d:\dev>ftp 172.30.16.100
Connected to 172.30.16.100.
220 ZBR-79071 Version V53.16.4ZP28 ready.
User (172.30.16.100:(none)):
230 User logged in.
ftp> bye
221 Service closing control connection. Bye...
d:\dev>ftp 172.30.16.101
Connected to 172.30.16.101.
220 Desker FTP server (QNXNTO-ftpd 20070723) ready.
User (172.30.16.101:(none)):
500 'USER ': command not understood.
Login failed.
ftp> bye
221 Thank you for using the FTP service on Desker.
Above are the two systems.  The top (.100) is our current system.  The bottom (.101) is the QNX system.  You will notice
 that the QNX login failed, so I wouldn't be able to do anything in there.  If you want a network trace I can get that
for you as well.
In DOS at the User prompt I was just hitting <enter>.
Jared
RE: RE: ftpd: DNS lookup & anonymous lookup
I've been looking at the same path as you.  You would have thought that
it would have been as simple as changing from a STR1 to ZSTR1 in
ftpcmpd.y (and possibly adding in a little bit of support code around
the USER / PASS entries).  This definitely helps since it gets you
through yylex, but there's still something buried in yyparse that's
resulting in a "parse error" now.  Don't you love auto-generated code?
	I'll keep digging for a bit longer to try and see where it's
going off the rails.
	Robert.
Sent: Monday, July 14, 2008 2:23 PM
Subject: Re: RE: ftpd: DNS lookup & anonymous lookup
compatible.  Our current system will handle the case where they don't
supply a user name.
Technology
http://community.qnx.com/sf/go/post10488
OK... We have a solution...
In ftpcmd.y, line 1866
	case CMD:
		hasyyerrored = 0;
+		if (strncasecmp(cmdp,"USER \r\n",7) == 0) {
+			strcpy(cmdp, "USER anonymous\r\n");
		if ((cp = strchr(cmdp, '\r'))) {
Add in the three lines as above and an empty user name maps to
"anonymous".  Turns out that ftpd already has the hooks to deal with an
empty password, so that's all it takes.  I don't know if this is in
compliance with the RFC, so we won't be pulling it into our GA code
base, but it's a pretty simple change.
	Robert.
supply a user name.
Technology
