Forum Topic - io-net comsumes all cpu time: (23 Items)
I am running 6.3.2 on a non-smp x86 box with 2 network cards both RealTek 8139 chips each on a different subnet.
I have two processes each with multiple threads.  Process 1 uses the first network interface and process 2 uses the
second network interface.  Both processes are reading and writing data over their respective interfaces fairly heavily.
Running just one process (either one) io-net never consumes even 5% of cpu time.  Running both processes io-net consumes
 more and more over about 15 minutes until the system quits responding.
Any thoughts?  Is this a problem with io-net or with the driver or ???  Next steps to debug the problem?
Thanx
Tim
RE: io-net comsumes all cpu time
Hi Tim:
	How is io-net started (command line options)?  Is it possible to
put in different network cards and see if the same sort of behaviour is
seen?  What speed of CPU are you using?  Are the links gigabit or 100
Mbps?  How does the CPU usage of your individual applications compare?
Are they interacting with each other in any way (e.g. through socket
calls)?  If you do a pidin -p io-net mem does the memory usage increase
with both apps running?
	(Lots of questions...)
	Robert.
Sent: Wednesday, July 02, 2008 12:15 PM
To: technology-networking
Subject: io-net comsumes all cpu time
first network interface and process 2 uses the second network interface.
cpu time.  Running both processes io-net consumes more and more over
Thanx
Tim
Technology
http://community.qnx.com/sf/go/post9941
Io-net is started by diskboot (using the x86 runtime kit) though I see
the same results when I start it with io-net -drtl -ptcpip.  I have not
tried two instances of io-net yet.
I will have to get some new cards to try that.  I assume that you are
looking for different chip sets?
The links are currently both 100m though I have seen this with gigabit
connections on a different machine (which I don't have access to at the
moment).
I run hogs -n -%5 with pid 1 and io-net showing up until only io-net
appears.  My applications never show (that is never consume > 5%).  They
can do some communication using QNX messages MsgSend/MsgReceive but the
traffic is little if any most of the time.
There is no memory increase.
Tim
Sent: Wednesday, July 02, 2008 9:21 AM
Subject: RE: io-net comsumes all cpu time
Hi Tim:
	Robert.
Thanx
Tim
Technology
Technology
http://community.qnx.com/sf/go/post9942
Hi Tim:
	I can really only see two possibilities at this point.  1)
There's a bug in the driver 2) "something" is happening on the network
that causes the linksto increase to max capacity.  With 100Mbps links, I
wouldn't expect even two links to consume all CPU if you've got a fast
CPU.  I'd guess that what could be happening is that the one of receive
threads on the drivers is getting put into short term CPU starvation by
the other thread and "something bad" is happening as the driver deals
with the queuing of the packets.
Dave Bott pointed out to me that some fixes have been checked into the
driver since it was last released that may be related.  I've attached a
private "experimental" x86 build from my sandbox (that I haven't tested
since I don't have the hardware...  notice all the provisos I put in
here :->) that would be worthwhile trying out.
Let me know if it changes the behaviour at all...
   Robert.
Sent: Wednesday, July 02, 2008 12:48 PM
moment).
Tim
Hi Tim:
	Robert.
Thanx
Tim
Technology
Technology
Technology
http://community.qnx.com/sf/go/post9945
Attachment: Text devn-rtl.so 61.25 KB
Rob Craig wrote:
> "something" is happening on the network that causes the
> links to increase to max capacity
Network loop?  Broadcast storm?  I've caused a few of these
here in my time  :-)
Wireshark/ethereal might help.
aboyd
Thanx I will try it out.  I forgot to mention I am currently testing on
an 1.1 gHz box so definitely not fast by x86 standards.  The normal
system I work with is a core 2 duo 1.5 gHz.  I've seen the symptoms on
both machines.
I'll let you know what happens.
Thanx
Tim
Sent: Wednesday, July 02, 2008 10:47 AM
Hi Tim:
   Robert.
moment).
Tim
Hi Tim:
	Robert.
Next steps to debug the...
I tried the new driver, but had the same problem.
Thanx
Tim
Hi Tim:
   Robert.
moment).
Tim
Hi Tim:
	Robert.
Re: io-net comsumes all cpu time
> network interface and process 2 uses the second network interface.  Both
>  heavily.
> time.  Running both processes io-net consumes more and more over about 15
> Thanx
> Tim
Hi Tim,
Let me bet that this won't occure if You use Trinity M7 respectively Trinity M6.
Can You try this ?
I believe this is a libc bug regarding select().
M6 or M7 You can find here:
http://community.qnx.com/sf/sfmain/do/home
Ofcourse I might be completely wrong. :-)
Hope this helps.
Jeevan
You know, Jeevan, that's a very good point.  This one keeps popping up
in reference to io-net CPU usage growing over time.
Tim: You aren't calling select anywhere with a zero timeout anywhere in
your application are you?
Our PR for this says:
"select()/poll() with a timeout setting of 0 causes delays/ memory leak"
	Robert.
Sent: Wednesday, July 02, 2008 5:15 PM
Subject: Re: io-net comsumes all cpu time
RealTek 8139
first
Both
interfaces fairly
>  heavily.
cpu
15
Next
> Thanx
> Tim
Hi Tim,
Trinity M6.
Can You try this ?
Hope this helps.
Jeevan
Technology
http://community.qnx.com/sf/go/post9964
Yes, I do.  I assume you mean with a NULL timeval struct for the timeout
value.  I don't create a timeval with a 0 timeout, but I do call
select() with a NULL timeout param.
Where are you getting this notice?
Thanx
Tim
Sent: Wednesday, July 02, 2008 2:39 PM
	Robert.
RealTek 8139
first
Both
interfaces fairly
>  heavily.
cpu
15
Next
> Thanx
> Tim
Hi Tim,
Trinity M6.
Can You try this ?
Hope this helps.
Jeevan
Technology
Technology
http://community.qnx.com/sf/go/post9965
This comes from a bug in our libc implementation which will be released
with 6.4.0.  Not sure that I understand the question about the notice
This would be one of those areas where going through the standard
support channels to get a patched libc may be the way to go...
	Robert.
Sent: Wednesday, July 02, 2008 5:42 PM
Thanx
Tim
	Robert.
RealTek 8139
first
Both
interfaces fairly
>  heavily.
cpu
15
Next
> Thanx
> Tim
Hi Tim,
Trinity M6.
Can You try this ?
Hope this helps.
Jeevan
Technology
Technology
Technology
http://community.qnx.com/sf/go/post9966
By notice I meant the bug report or "known issues" or wherever the
explanation of the problem.
I can enter a support ticket - is there a known patch for this?  Will
support know what I'm talking about or will they want to reproduce the
problem before they help me?
Thanx
Tim
Sent: Wednesday, July 02, 2008 2:46 PM
	Robert.
Thanx
Tim
	Robert.
RealTek 8139
first
Both
interfaces fairly
>  heavily.
cpu
15
Next
> Thanx
> Tim
Hi Tim,
Trinity M6.
Can You try this ?
Hope this helps.
Jeevan
Technology
Technology
Technology
Technology
http://community.qnx.com/sf/go/post9968
The main PR is 39687 (there were a number of duplicates generated
feeding off of this one).  That should be all that's needed.  I suspect
that a patch already exists.  The support guys should be able to figure
out where it is.  Feel free to drop my name in the conversation if they
think that it has to be reproduced and they'll bug me about it if they
need to...
	Robert
Sent: Wednesday, July 02, 2008 5:51 PM
Thanx
Tim
	Robert.
Thanx
Tim
	Robert.
RealTek 8139
first
Both
interfaces fairly
>  heavily.
cpu
15
Next
> Thanx
> Tim
Hi Tim,
Trinity M6.
Can You try this ?
Hope this...
I appreciate your help!
Thanx
Tim
Sent: Wednesday, July 02, 2008 3:00 PM
need to...
	Robert
Thanx
Tim
	Robert.
Thanx
Tim
	Robert.
RealTek 8139
first
Both
interfaces fairly
>  heavily.
cpu
15
Next
> Thanx
> Tim
Hi Tim,
Trinity M6.
Can You try this ?
Hope this...
> Thanx
> Tim
The bug in question was with a 0 timeout (a non blocking
select()) and IIRC the CPU got billed to the client not
io-pkt / io-net.
I think a test case may be required.
It doesn't sound like I have that scenario in my code.  I can try some
variations though and see if it makes any difference.
Thanx
Tim
Sent: Wednesday, July 02, 2008 3:39 PM
timeout
> Thanx
> Tim
io-pkt / io-net.
Technology
http://community.qnx.com/sf/go/post9976
I got a patch to libc for the select() problem and things are working
great!!!  While I wasn't calling select() with a 0 timeout, a 3rd party
library was.
Thanx everyone for your help!
Tim
timeout
> Thanx
> Tim
io-pkt / io-net.
Technology
Those darned 3rd party apps! :->>
Very glad to hear that this sorted out your problem!
	Robert.
Sent: Tuesday, July 08, 2008 5:20 PM
library was.
Tim
timeout
> Thanx
> Tim
io-pkt / io-net.
Technology
Technology
http://community.qnx.com/sf/go/post10206
Re: RE: io-net comsumes all cpu time
> library was.
> Tim
Hello everyone,
Where could I get this libc patch for QNX 6.3.2? I believe I´m facing the same error. io-net consuming a lot of CPU
over time.
Thanks in advance
Rodrigo Madruga
RE: RE: io-net comsumes all cpu time
Hi Rodrigo:
	I believe that this is one of the things that you have to get through our standard tech support channels.
		Robert.
From: Rodrigo Madruga [mailto:community-noreply@qnx.com]
Sent: Tuesday, December 02, 2008 11:02 AM
Subject: Re: RE: io-net comsumes all cpu time
> party library was.
> Tim
Hello everyone,
over time.
Thanks in advance
Rodrigo Madruga
Technology
http://community.qnx.com/sf/go/post17750
Sean,
is there a way to get also that patch for a 6.3.2 customer?
Best Regards
Armin Steinhoff
> library was.
> Tim
> From: Sean Boudreau [mailto:seanb@qnx.com]
> timeout
> > Thanx
> > Tim
> io-pkt / io-net.
> -seanb
> Technology
On Sun, Dec 21, 2008 at 05:34:35AM -0500, Armin Steinhoff wrote:
> Sean,
> Best Regards
> Armin Steinhoff
Probably, but I think you'd have to talk to your sales rep.
This is one of these things that you have to request through the
"normal" support channels.
	Robert.
From: Sean Boudreau [mailto:community-noreply@qnx.com]
Sent: Sunday, December 21, 2008 8:21 AM
> Sean,
> Best Regards
> Armin Steinhoff
Technology
http://community.qnx.com/sf/go/post19106
