Forum Topic - interface naming convention: (7 Items)
While testing io-pkt I noticed that the interfaces were rename from en0 to bge0 ( broadcom ).
I see a problem with this; it's common for system installed in the field to have the network card replace with a
different model for what ever reason.  It seems changing the network card model ( and driver ) will end up changing the
name of the interface. In our case this would break the system, requiring modification of configuration files.
How should this scenario be handle?
I'm just starting testing with io-pkt, maybe I'm missing something obvious ;-)
Re: interface naming convention
There's some mapping code in the stack that will map the
common ioctls: eg. en0 -> <first ethernet iface>
So that basics like 'ifconfig en0 <addr>' should work.  If
you set the qnx.kern.debug sysctl to >0 the stack will log
what it's mapping to the sloginfo.  This mapping can become
confusing if interfaces are unloaded / reloaded so there's
a 'enmap' option to disable it.
# io-pkt -ptcpip enmap=0
You can start with 'ifconfig -l' to see what interfaces are
available.
                                       >=6
>  bge0 ( broadcom ).
> to have the network card replace with a different model for what ever reason.
> the name of the interface. In our case this would break the system, requiring
>                                        >=6
Just changed this mapping somewhat.
The following will return the result of
the mapping so the qnx.kern.debug sysctl
is no more.
# nicinfo en0
# ifconfig en0
There is now a sysctl to toggle the mapping
as well as the command line arg.
Using QNX 6.5.0 with the i.MX51, it seems the enmap=0 option has no effect.
#io-pkt-v4-hc -d mx51 mac=00049F00EA2C -p tcpip enmap=0
#ifconfig
fec0: flags=802<BROADCAST,SIMPLEX> mtu 1500
        address: 00:04:9f:00:ea:2c
        media: Ethernet none
#slay o-pkt-v4-hc
#ifconfig
Seems to enumerate as fec0 regardless of enmap. Is this expected?
RE: interface naming convention
Hi Pat,
I think you misunderstand.
'fec0' is the published name for that driver. You'll always get the name(s) that the driver publishes.
The enmap option, as I understand it, enables/disables the use of 'en<X>' as a generic way to interact with NIC device
instances.
So, the question is - does 'ifconfig en0' work in both cases, or only without 'enmap=0'?
I could be wrong, but that's how I understood it...
Cheers
Dave
From: Patrick Shelly [mailto:community-noreply@qnx.com]
Sent: Tue 2/1/2011 8:31 AM
To: technology-networking
Subject: Re: interface naming convention
#ifconfig
#slay o-pkt-v4-hc
#ifconfig
Technology
http://community.qnx.com/sf/go/post82829
Attachment: Text winmail.dat 4.91 KB
Re: RE: interface naming convention
Thanks Dave. I was confusing the protocol option enmap=0 with the driver option name=en...
Cheers,
Pat
