Re: tcpip : blown stack handling 0x102
10/29/2014 9:57 AM
post112220
On Wed, Oct 29, 2014 at 09:50:54AM -0400, atish bhowmick wrote:
> I get this crash only on ARM platform , no such crash on x86 . Is the default io-pkt stacksize different for these
platforms ?
No.
> when i launched io-pkt on ARM with stacksize=16k , crash didnt occur .
As expected. You're using too much stack. You should try to keep the
stacksize option as low as possible since this value gets multiplied
by the number of coroutines (pseudo-threads) in use.
You should run io-pkt under the debugger and look at stack usage. Look at the 'call
__stackavail()' command in gdb.
