Open TCP ports on termination
04/16/2014 8:36 AM
post109933
I am developing under QNX 6.5.0 an embedded system with a minimal QNX install. Our application has a built in web
server listening on port 80 (its in a blocking accept() call). If the program terminates, either by a SIGTERM or crash,
a boot program will restart the program. When the program restarts, the bind() fails with EADDRINUSE. Whats more,
when dhcp.client gets an IP address, it call a custom dhcp-up program I wrote. This program opens a socket, connects to
http://localhost:80, and sends a specially crafted HTTP GET command to signal our application that it has an IP address
. If this happens when the TCP port is in this busy condition. the connect() is successful and so is the send(). But
the call to recv() blocks forever, locking up dhcp-up. I know I can make dhcp-up a little more robust to time out in
this condition, but I did not expect the connect() to pass.
I was under the impression that QNX automatically cleans up after a terminated program by releasing all its allocated
resources. Apparently this does not include in-use TCP ports. An internet search shows this to be a fairly common
problem with TCP/IP stacks and there are various tools available to reset the stack. So my question is, does QNX have a
mechanism to remedy this situation? I have tested killing io-pkt-v4, restarting it, and then remounting the Ethernet
drivers. This works, but I would like to know if there is something a little more elegant to fix this.
