my io-pkt-v4 driver overwrites the en0 interface in ifconfig
02/05/2014 11:47 AM
post108616
I am currently writing an ethernet driver which basically works fine.
Before loading my driver, I already have an smsc9500 ethernet driver loaded which is displayed as en0 in ifconfig.
The problem is that as soon as I load my driver via io-pkt-v4, en0 disappears from ifconfig and my interface is shown
instead.
The smsc driver is still working, but I just can't see it in ifconfig anymore.
As soon as I kill io-pkt-v4 for the new driver, en0 appears again.
Is there a kind of index or something else I am missing?
Clemens
Re: my io-pkt-v4 driver overwrites the en0 interface in ifconfig
02/05/2014 11:54 AM
post108618
Are you running 2 instances of io-pkt? If so, then the second instance
should be started with ³-ptcpip prefix=/alt² command line argument. To
interact with the second instance of io-pkt, you need to prefix all
commands with ³SOCK=/alt ifconfig в etc.
On 2014/2/5, 11:47 AM, "Clemens Fischer" <community-noreply@qnx.com> wrote:
>Hi,
>disappears from ifconfig and my interface is shown instead.
>anymore.
>Thanks,
>Clemens
>Technology
>http://community.qnx.com/sf/go/post108616
>technology-networking-unsubscribe@community.qnx.com
02/05/2014 2:58 PM
post108626
If you want them in the same io-pkt:
# mount -T io-pkt /fullpath/to/your_driver.so
Running two instances may be easier for debugging initially.
> >Hi,
> >anymore.
> >Thanks,
> >Clemens
> >Technology
> Technology
> http://community.qnx.com/sf/go/post108618
> To cancel your subscription to this discussion, please e-mail technology-networking-unsubscribe@community.qnx.com
02/07/2014 4:54 AM
post108660
I have chosen the mount version and it works fine.
Thanks guys for the fast and helpful resonse.
Clemens
> > >Hi,
> > >anymore.
> > >Thanks,
> > >Clemens
> > >Technology
> > Technology
02/11/2014 5:50 AM
post108712
I am still facing an issue with the mount version.
Mounting the driver works fine and the interface is visible with ifconfig.
As soon as I try to associate an IP-Address with the device, ifconfig hangs and does not return.
It also seems as if the other active ethernet connections are disconnected, as I can't connect to the target through
qconn anymore.
I have tracked down the issue to the init function of the driver and this instruction:
ifp->if_flags_tx |= IFF_RUNNING;
I took this instruction from the speedo implementation. I assume it enables transmission?
When I remove this, mount works and I can assign an IP-address just fine, but I can't transmit any data.
When using a second io-pkt-v4 instance I don't face this issue.
Any ideas?
Clemens
> Regards,
> Clemens
> > > >Hi,
> > > >anymore.
> > > >Thanks,
> > > >Clemens
> > > >Technology
> > > Technology
02/11/2014 8:31 AM
post108714
You say this is an io-pkt driver and yet it is coming up as en0, are you actually passing in "en" on the dev_attach()
call? You need to pass in a string that is unique for your driver, typically a 2 or 3 letter abbreviation for the type
of hardware your driver controls. The string "en" is used by the shim driver for io-net drivers running within io-pkt.
02/11/2014 8:43 AM
post108715
No, I am loading a driver for a smsc chip which comes up as en0.
In addition I am loading a second self written driver via mount which comes up with a user defined three character
string which I have defined.
The problem now is that when I load the self written driver via mount, assigning an ip with ifconfig fails. Ifconfig
just does not return.
If I load my driver with io-pkt-v4, i.e. not mounting it, assigning an ip with ifconfig works fine.
> actually passing in "en" on the dev_attach() call? You need to pass in a
> for the type of hardware your driver controls. The string "en" is used by the
02/11/2014 8:45 AM
post108716
Ah sorry for the misunderstanding.
When it locks up, CTRL-Z the ifconfig and use dumper to grab a core of io-pkt. The backtrace usually has a good clue as
to what is going on.
