Peer-to-peer connection (WiFi Direct)
09/13/2012 4:04 PM
post95572
We are trying to run some tests on peer-to-peer connection using WiFi direct protocol on TI WL1281Q. Unfortunately we
cannot get other devices to see our board. We have following questions.
1. After running io-pkt-v4-hc, we got the following interfaces: lo0, tiw_drv0, tiw_sta0, tiw_sap0, tiw_p2pdev0,
tiw_p2pgrp0, tiw_ibss0. Is tiw_p2pdev0 for p2p device and tiw_p2pgrp0 for group owner? Can we run these interfaces
simultaneously? If so, can we use same IP address?
2. We received wpa_supplicant, P2P_supplicant, and wpa_cli binaries from QNX. What is the different from P2P_supplicant
and wpa_supplicant? We got an error when we tried to run wpa_supplicant with p2p.conf. P2P_supplicant with p2p.conf
works better. However, we got an error when we tried to run with wpa_cli which requires wpa_supplicant process to be
run . After rename P2P_supplicant to wpa_supplicant and rerun the process as wpa_supplicant, we do not get the error
message. However, wpa_cli does not give any p2p options such as p2p_find.
Do we need p2p_cli binaries? Or do we need enable P2P_CONFIG in P2P_supplicant source code? Could you please check on
this issue and let us know?
Thank you.
