Forum Topic - Building pfil example: (1 Item)
I was trying to use the example given in the packet filtering section:
http://www.qnx.com/developers/docs/6.4.1/io-pkt_en/user_guide/filtering.html.
I need to build and test the functionality of this example, after which I will be using it to implement customized
functionality.
The above link does not document as how to build the example to create Loadable Shared Modules (lsm) and use it.
Kindly give the procedure to build the above example. If there are any sample examples to create lsm modules please
share so that I can try use the above example.
Thanks and Regards
Chandrashekhrar
Bangalore
India.
