Very specific questions on data returned by sysctl
01/20/2011 9:20 AM
post82500
I would like to know about information in the RTM_NETMASK field returned by calls to sysctl. Since I do not have access
to the source code I can't determine this myself. I would appreciate insight from anyone who has access to it.
When I retrieve the routing table (NET_RT_DUMP), the net mask field of each entry that provides one has a sa_family type
of 255. If I treat this field like an AF_INET family (2) I get the correct network mask. What is the significance of
the 255 value?
When I retrieve the interface list (NET_RT_IFLIST), some of the net mask entries have a sa_family type of AF_UNSPEC (0).
The sysctl call returns a list of 'struct if_msghdr' fields, each followed by one or more 'struct ifa_msghdr' fields.
The if_msghdr field describes the interface giving the name and MAC address in the RTA_IFP field. Following this entry
is an ifa_msghdr field. The RTA_IFA field repeats the interface description. The ifm_flags field is zero. The
RTA_NETMASK field is the AF_UNSPEC family. In my tests, this field has an sa_len of 11 bytes. Is there any
significance to these data?
Following this mystery ifa_msghdr field are more ifa_msghdr fields describing the IP addresses assigned to the interface
. The first field describes the default IP address. Its RTA_NETMASK family type is AF_UNSPEC, but if I treat it as
AF_INET, I get the correct net mask. Any remaining ifa_msghdr fields are IP aliases and the RTA_NETMASK fields are
AF_INET. Why is this field AF_UNSPEC and can I use it to distinguish it as the default IP address?
