Forum Topic - Unable to get routing with WAP Working: (15 Items)
I'm following the direction from here:  http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/
Wifi_tcpip_config_wiki_page
But I can not get the "routing" to work.
I am bringing up a 3G data connection and the nameservers are being added to /etc/resolv.conf
I then follow the directions above to start my wireless adapter as a hostap and I am able to attach to the the AP that I
 created.  But my data packets are not routed between the wireless client and the 3G network.
I am able to ping off of the router via the 3G network so I'm pretty sure that everything to the "Internet" side is
working just fine and I believe I have my dhcp.conf file setup correctly based on the examples.
Here is my pppd line:
pppd /dev/serusb1 defaultroute resconf require-ns noipdefault logstatus
Here is my "Network" portion of the dhcp.conf file:
subnet 192.168.253.0 netmask 255.255.255.0{
        range 192.168.253.100 192.168.253.110;
        option routers 192.168.253.1;
        option domain-name "my.net";
        option broadcast-address 192.168.253.255;
        option domain-name-servers 192.168.253.1;
        default-lease-time 600;
        max-lease-time 7200;
I have configured my wireless adapter with 192.168.253.1 as the IP address.
Thoughts?
Re: Unable to get routing with WAP Working
Hi Matt,
If you ping from the wireless client using an IP address (instead of a
name), does that work?
 From the dhcpd.conf it looks like you may have to setup a nameserver on
your router.
Cheers!
/P
Nope doesn't work by IP address either.
I tried removing the name-server entry from my dhcp.conf file and still noJoy.
I have tried the connection from 3 different clients as well.  With the same results.
Hi again,
What's the error message from the ping command?
Can the clients ping the router 192.168.253.1?
Can the clients ping the router's IP address on the "Internet" side
(router's PPP interface)?
Can you post output of the following commands taken on the router:
sysctl net.inet.ip.forwarding
netstat -rn
ifconfig
arp -na
And from client:
cat /etc/resolv.conf
netstat -rn
ifconfig
arp -na
I think you should keep the name server line in dhcp.conf, the question
is maybe what name server you should have in there. Are you running an
name server inside the router? If not, then the name server line should
change to point to the name server you're getting from the 3G network.
Cheers!
/P
Here is the information you requested.  I ran the command as you indicated in your last response, but I was to busy to
clean it up, trying to run between meetings and all.
I can not ping the external side of the PPP connection, 10.0.0.1 from any of my clients.  Right now the clients are a
DROID X and a MAC, the information was gathered from the MAC client and the QNX 641 target.
Sure hope this helps.
Attachment: Compressed file AP_Router_Output.zip 1.7 KB
Thanks for sending the info,
This looks suspicious:
rum0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
	ssid MYAP apbridge
I don't have a setup to try on at the moment, but IIRC that shouldn't
say apbridge when you're trying to run router...
/P
> indicated in your last response, but I was to busy to clean it up,
> any of my clients. Right now the clients are a DROID X and a MAC, the
> Technology
> http://community.qnx.com/sf/go/post73534
I wondered the same thing, but I configure the interface as follows:
ifconfig rum0 mediaopt hostap ssid "MYSSID" 192.168.253.1 netmask 255.255.255.0
So I'm not 100% sure why it says "Bridge"..
Maybe try 'ifconfig rum0 -apbridge' and see if that clears it?
(shot in the dark)
Got pretty busy at the end of the week so wasn't able to try this until just now.
ifconfig rum0 -apbridge Did not produce the desired defaults.
Based on my reading if I do the -apbridge then I need to use pf or something like that.  I have tried packet filtering
(NAT) as well to no success.  I"m beginning to wonder if there is a problem with the "rum" driver.
Ok I have tried with "Packet Filtering" (pf) to sort of "Reverse" the situation.
en0->rum0 with rum0 associated to an WiFi AP in the area.  Packets are routed just fine.
en0->ppp0 with ppp0 connected to a 3G network.  Packets are routed just fine.
The only issue I seem to have is rum0->ppp0 with the rum being a AP.
At this point I'm beginning to question the stability of:  devnp-rum.so.
Any thoughts.
You can use pf to make routing work out of apbridge, but the fundamental
problem seems to be the driver stuck in apbridge.
/P
> situation.
> routed just fine.
> Any thoughts.
> Technology
> http://community.qnx.com/sf/go/post73868
Please correct me if I am wrong here but if I was struck in "Bridge" mode then wouldn't I be getting addresses assigned
to me from the "Far" end?  Basically look like I was on the Far end network rather than the local network to my board?
Maybe I misunderstood but I thought you had a DHCP server running
directly on the rum0? (I'm saying, if it is in bridge mode but isn't
bridged to anything then there are no other interfaces which would come
into play)
> mode then wouldn't I be getting addresses assigned to me from the "Far"
> Technology
> http://community.qnx.com/sf/go/post73902
No I think we are on the same page.  I had a dhcp server running against rum0 but I also tried it w/o a server too.
My solution is to "Not" have a bridge, so I agree that -apbridge is correct, but just not working.
