Forum Topic - Unable to Connect to AP with WPA2 and Not Broadcasting SSID:
I have an access point that is configured to be "hidden", that is not broadcasting an SSID, and has WPA2 encryption.
While I have wpa_supplicant running, if I reconfigure the AP to broadcast the SSID my system then connects as expected.
Has anybody else had any luck accessing "Hidden" APs with or without encryption.
-Matt
Re: Unable to Connect to AP with WPA2 and Not Broadcasting SSID
> encryption.
Yes.
Add 'scan_ssid=1' to the network block in question in your
wpa_supplicant.conf.
Thank you much, and presto it works.
