Forum Topic - Ethernet MTU on VLAN interface:
Hi
I noticed that VLAN interface derives its mtu attribute from the parent interface (say en0) but uses a value that is 4
less than that of parent interface.
So, if mtu for en0 is 1500
      vlanX on en0 will have mtu 1496.
Also, stack does not allow user to set the mtu value at vlanX to be more than 1496 so that difference of 4 byte always
stays. Neither does stack allow mtu of en0 to be more than 1500.
This causes issues when an IP peer with MTU set to 1500 sends fragmented packets to this interface vlanX.
Theoratically, I do not understand the reasoning for having this difference of 4 bytes. MTU at IP layer (1500 for
ethernet) is IP header + IP payload. It should make no difference to stack if the size of Ethernet header is 14 bytes or
 18 bytes as that should not be part of MTU anyways.
Please help in understanding this behavior of QNX stack and also any workaround that is possible to use MTU size of 1500
 on a VLAN interface.
Regards
VG
Re: Ethernet MTU on VLAN interface
This is expected and not unique to QNX.
The 802.1Q encapsulation requires four more bytes which are then not
available for payload (IP or whatever).
To change the MTU of the VLAN interface I believe you'll have to set the
parent interface's MTU to be bigger.
See e.g. http://netbsd.gw.com/cgi-bin/man-cgi?vlan+4
/P
On 10-09-28 02:17 PM, Vineet Garg wrote:
> Hi
> interface (say en0) but uses a value that is 4 less than that of parent
> interface.
> than 1496 so that difference of 4 byte always stays. Neither does stack
> difference of 4 bytes. MTU at IP layer (1500 for ethernet) is IP header
> Ethernet header is 14 bytes or 18 bytes as that should not be part of
> MTU anyways.
> workaround that is possible to use MTU size of 1500 on a VLAN interface.
> Regards
> VG
> Technology
> http://community.qnx.com/sf/go/post68865
hi patrik
in my case system is not allowing to set mtu of parent interface to more
than 1500 bytes thus leading to problems as even in article pointed to by
you.
 To be compatible with other IEEE 802.1Q devices, the *vlan* interface sup-
     ports a 1500 byte MTU, which means that the parent interface will have to
     handle packets that are 4 bytes larger than the original Ethernet stan-
     dard
Is this behavior dependent on underlying network driver or is a
property of operating system? I have devn-ixp2351 as network driver in
my case.
 Since article provides a list of network drivers that support
increased mtu size, does it mean that ifconfig sends a devctl to
network driver to check if given mtu value is supported or not? In
that case I can modify my network driver to accept even higher mtu.
On Wed, Sep 29, 2010 at 1:18 AM, Patrik Lahti <community-noreply@qnx.com>wrote:
> /P
> > Hi
> > interface.
> > MTU anyways.
> > Regards
> > VG
> > Technology
> Technology
> http://community.qnx.com/sf/go/post68893
Then the driver or the medium itself don't allow frames larger than 1514
bytes. With the regular Ethernet header there's only 1500 bytes of
payload left, with the and Q-header there is simply not more than 1496
bytes left...
I've never seen the devn-ixp2351 driver. It might be hard coded to 1500
bytes MTU. You'd have to ask whoever wrote it, maybe in the driver forum?
PS. The article isn't QNX product documentation, it's on a website which
isn't controlled nor endorsed by QNX.
/P
On 10-09-28 11:46 PM, Vineet Garg wrote:
> hi patrik
> you.
> dard
> my case.
>  > /P
>  > > Hi
>  > > interface.
> more
> fragmented
>  > > MTU anyways.
> interface.
>  > > Regards
>  > > VG
>  > > _______________________________________________
>  > > Technology
>  > Technology
Hi Patrik
I have the source for network driver (devn-ixp2351) and know it reasonably
well. I checked today and it does not receive any devctl checking for the
MTU size...hmm..maybe I should check again.
However, leaving that aside, do you think it is correct for maximum MTU to
be 1496 if 802.1Q is enabled and this is valid for most systems?
In that case we need to consider updating requirements for our system.
VG
On Wed, Sep 29, 2010 at 6:56 PM, Patrik Lahti <community-noreply@qnx.com>wrote:
> bytes left...
> /P
> > hi patrik
> > you.
> sup-
> > dard
> > my case.
> the
> >  > /P
> >  > > Hi
> parent
> parent
> >  > > interface.
> > more
> stack
> > fragmented
> header
> >  > > + IP payload....
Check for ioctl() of SIOCSIFMTU? It might need to be Jumbo capable to go
beyond 1500...
In order to interop you've got to have the same MTU...
On 10-09-29 01:34 PM, Vineet Garg wrote:
> Hi Patrik
> VG
>  > bytes left...
>  > /P
>  > > hi patrik
> more
> to by
>  > > you.
>  > sup-
> have to
>  > > dard
>  > > my case.
>  > the
>  > > > /P
>  > > > > Hi
>  > parent
>  > parent
>  > > > > interface.
>  > > > > Also,...
So, i have found out the reason for the upper limit on MTU at parent interface. Driver sends maximum MTU and minimum MTU
 in interface advertisements it sends to stack during startup.
Changing the max MTU in advertisement allowed to set MTU of en0 to 1504 bytes using ifconfig..
thanks patrik for your help here...
Regards
VG
