Forum Topic - performance of io-pkt vs. io-net with the Broadcom driver: (13 Items)
Thought I would share some of my test results with the community:
I did some ttcp performance measurements on my 2 GHz dual core Dell laptop with the Broadcom driver for io-pkt which
AFAIR is a ported NetBSD driver, not a native io-pkt driver. I guess this is part of the explanation for the result?
I was using ttcp in transmit mode under Neutrino, on the other side there was a dual core + hyperthreading Windows XP
box (Pentium D).
Here's the output of ttcp on the NTO machine, with io-pkt:
# ./ttcp -s -t -n100000 -vv 192.168.51.173
ttcp-t: buflen=8192, nbuf=100000, align=16384/0, port=5001  tcp  -> 192.168.51.173
ttcp-t: socket
ttcp-t: connect
ttcp-t: 819200000 bytes in 23.19 real seconds = 34502.91 KB/sec +++
ttcp-t: 819200000 bytes in 0.54 CPU seconds = 1481481.48 KB/cpu sec
ttcp-t: 100000 I/O calls, msec/call = 0.24, calls/sec = 4312.86
ttcp-t: 0.4user 0.1sys 0:23real 2%
ttcp-t: buffer address 8058000
On the Windows side PCATTCP was used:
E:\PCATTCP>pcattcp -r -v
PCAUSA Test TCP Utility V2.01.01.08
TCP Receive Test
  Local Host  : multicore
  Listening...: On port 5001
  Accept      : TCP <- 192.168.51.116:65532
  Buffer Size : 8192; Alignment: 16384/0
  Receive Mode: Sinking (discarding) Data
  Statistics  : TCP <- 192.168.51.116:65532
819200000 bytes in 23.19 real seconds = 34502.09 KB/sec +++
numCalls: 134235; msec/call: 0.18; calls/sec: 5789.24
Hm.. 34 MB/s on a GigE line isn't an awful lot. And io-net is faster:
ttcp-t: socket
ttcp-t: connect
ttcp-t: 819200000 bytes in 16.99 real seconds = 47082.64 KB/sec +++
ttcp-t: 819200000 bytes in 0.56 CPU seconds = 1428571.43 KB/cpu sec
ttcp-t: 100000 I/O calls, msec/call = 0.17, calls/sec = 5885.33
ttcp-t: 0.4user 0.1sys 0:17real 3%
Windows side:
E:\PCATTCP>pcattcp.exe -r -v
TCP Receive Test
  Accept      : TCP <- 192.168.51.116:65534
  Statistics  : TCP <- 192.168.51.116:65534
819200000 bytes in 16.98 real seconds = 47100.38 KB/sec +++
numCalls: 155496; msec/call: 0.11; calls/sec: 9154.90
Re: performance of io-pkt vs. io-net with the Broadcom driver
Can you try receive?
RE: performance of io-pkt vs. io-net with the Broadcom driver
Hi Malte:
	I believe that you've hit a bug that we're actively looking into.
The performance of io-pkt when transmitting with buffer sizes > 4K is slower
than io-net (reference PR52704).
	Robert.
Sent: Friday, November 16, 2007 11:14 AM
To: technology-networking
Subject: performance of io-pkt vs. io-net with the Broadcom driver
with the Broadcom driver for io-pkt which AFAIR is a ported NetBSD driver,
result?
was a dual core + hyperthreading Windows XP box (Pentium D).
192.168.51.173
ttcp-t: socket
ttcp-t: connect
TCP Receive Test
192.168.51.173
ttcp-t: socket
ttcp-t: connect
Windows side:
TCP Receive Test
Technology
http://community.qnx.com/sf/go/post2692
Re: RE: performance of io-pkt vs. io-net with the Broadcom driver
I tried receive now. In both cases (io-net, io-pkt), the Windows command line looked like this:
E:\PCATTCP>pcattcp -t -n10000 192.168.51.116
On the Neutrino side, I put ttcp into receive mode.
io-net:
# ./ttcp -s -r
ttcp-r: buflen=8192, nbuf=2048, align=16384/0, port=5001  tcp
ttcp-r: socket
ttcp-r: accept from 192.168.51.173
ttcp-r: 81920000 bytes in 1.33 real seconds = 60341.06 KB/sec +++
ttcp-r: 35644 I/O calls, msec/call = 0.04, calls/sec = 26884.96
ttcp-r: 0.0user 0.0sys 0:01real 6%
io-pkt:
# ./ttcp -s -r
ttcp-r: socket
ttcp-r: 81920000 bytes in 1.92 real seconds = 41564.79 KB/sec +++
ttcp-r: 13813 I/O calls, msec/call = 0.14, calls/sec = 7176.68
ttcp-r: 0.0user 0.0sys 0:01real 0%
Hmmm...  Now we've got a huge measurement discrepancy...  I think that you've got the same laptop as I do (a D820).
I'm communicating with a dual core linux box with an Intel GigE card in it:
 ttcp -tsn10000 192.168.200.10
I'm having quite a bit of trouble getting the tigon3 driver to produce anything like the results that you're seeing...
What version of driver are you using and are you passing any special options to it?
With io-pkt:
# io-pkt-v4-hc -dbge -ptcpip
# ifconfig bge0 192.168.200.10
# ./ttcp -rsv
tcp-r: socket
tcp-r: accept from 192.168.200.12
tcp-r: 819200000 bytes in 9.63 real seconds = 83077.81 KB/sec +++
tcp-r: 819200000 bytes in 0.13 CPU seconds = 6009750.82 KB/cpu sec
tcp-r: 138066 I/O calls, msec/call = 0.07, calls/sec = 14337.78
tcp-r: 0.0user 0.1sys 0:09real 1% 0i+0d 0maxrss 0+0pf 0+0csw
tcp-r: buffer address 0x8058000:w
which appears to be 2x faster than your io-pkt results.  Our setups are quite definitely different somewhere...
       Robert.
Hi Robert,
I re-tested, under Neutrino using io-pkt and
ttcp -s -r
I guess the difference is the default buffer size on the sender side. I am using Windows XP with the pcattcp program,
like this:
E:\PCATTCP>pcattcp -t -n20000 192.168.51.116
TCP Transmit Test
  Transmit    : TCP -> 192.168.51.116:5001
  TCP_NODELAY : DISABLED (0)
  Connect     : Connected to 192.168.51.116:5001
  Send Mode   : Send Pattern; Number of Buffers: 20000
  Statistics  : TCP -> 192.168.51.116:5001
163840000 bytes in 3.56 real seconds = 44905.98 KB/sec +++
numCalls: 20000; msec/call: 0.18; calls/sec: 5613.25
Note the 8192 buffer. When I instead start it with a 65535 buffer, like this:
E:\PCATTCP>pcattcp -t -l65535 -n10000 192.168.51.116
TCP Transmit Test
  Buffer Size : 65535; Alignment: 16384/0
  Send Mode   : Send Pattern; Number of Buffers: 10000
655350000 bytes in 7.58 real seconds = 84453.71 KB/sec +++
numCalls: 10000; msec/call: 0.78; calls/sec: 1319.61
Could you try to specify an 8k buffer on your Linux sender? Our results should be very similar then.
- Malte
Hi Malte:
  Doesn't look like it's buffer size...  Here's the output from my linux ttcp session with io-pkt running on the laptop
rcraig@network-performance1:~$ ./ttcp  -tsn10000 192.168.200.10
ttcp-t: buflen=8192, nbuf=10000, align=16384/0, port=5001  tcp  -> 192.168.200.10
ttcp-t: socket
ttcp-t: connect
ttcp-t: 81920000 bytes in 0.98 real seconds = 81400.58 KB/sec +++
ttcp-t: 10000 I/O calls, msec/call = 0.10, calls/sec = 10175.07
ttcp-t: 0.0user 0.0sys 0:00real 2% 0i+0d 0maxrss 0+3pf 1107+1csw
And (for comparison's sake, use large buffers and TCP_NO_DELAY option)
On the Neutrino side the command is:  ttcp -D -b65535 -l65535 -rsv
On the Linux side:
rcraig@network-performance1:~$ ./ttcp -b65535 -l65535 -D -tsn10000 192.168.200.10
ttcp-t: buflen=65535, nbuf=10000, align=16384/0, port=5001, sockbufsize=65535  tcp  -> 192.168.200.10
ttcp-t: socket
ttcp-t: sndbuf
ttcp-t: nodelay
ttcp-t: connect
ttcp-t: 655350000 bytes in 5.59 real seconds = 114419.64 KB/sec +++
ttcp-t: 10000 I/O calls, msec/call = 0.57, calls/sec = 1787.83
ttcp-t: 0.0user 0.4sys 0:05real 8% 0i+0d 0maxrss 0+16pf 11009+23csw
which is pretty darn close to line rate...
   On the Neutrino side, the Ethernet HW is reported as VID=0x14e4 and DID=1600 (BCM5752).
You know, the OTHER possibility is that there's something about the windows TTCP application that's skewing things a bit
.  It's possible that the reduced throughput that you're seeing with io-pkt is achieved using considerably less CPU than
 io-net.
So the real measure would be Throughput / CPU.
I'm still not seeing anywhere near the io-net numbers with the tigon3 driver that you are for some reason...
When I did benchmarks of io-pkt vs io-net, I tried to monitor CPU usage. Sometimes io-pkt would use less CPU than io-net
.  This varied on a run by run basis, sometimes it would use 70% CPU and you could run it again and get 100%.
Also, the OS on the other machine makes a difference. For example, I got different benchmarks when I tested io-pkt vs io
-net than when I tested io-pkt vs Linux. The differences were mostly in CPU utilization, such that I divided the result
by the percent of CPU used I usually got consistent results.
Gilles
I would like to support you guys in testing performance, but whenever I try to start ttcp
I get:
ttcp-r: nbuf=1024, buflen=1024, port=2000
ttcp-r: socket
ttcp-r: bind: Address family not supported by protocol family
errno=247
Would you piont me to what I am doing wrong?
On Fri, Dec 07, 2007 at 02:54:11AM -0500, Marek W wrote:
> try to start ttcp
> I get:
> ttcp-r: socket
> errno=247
Your ttcp is old.  You're hitting this note from the
io-net compatibility page:
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/IoNet_migration
Protocol compatibility
    * bind() on an AF_INET socket now requires that the second argument
    * has its (struct sockaddr *)->af_family member be initialized to
    * AF_INET. Previously a value of 0 was accepted and assumed to be
    * this value.
> > Hi,
> > try to start ttcp
> > I get:
> > ttcp-r: socket
> > errno=247
I guess it's not old, just broken.  I built the ttcp
from pkgsrc which patches this issue.
>     * this value.
> -seanb
> > > Hi,
> > > try to start ttcp
> > > I get:
> > > ttcp-r: socket
> > > errno=247
> IoNet_migration
> >     * this value.
> > -seanb
Cool,
I have made (from NetBSD surce)
-	if (bind(fd, &sinme, sizeof(sinme)) < 0)
+	sinme.sin_family = AF_INET;
+	if (bind(fd, (struct sockaddr *)&sinme, sizeof(sinme)) < 0)
 		err("bind");
works fine now
