Forum Topic - ifconfig pause: (3 Items)
ifconfig pause
I'm trying io-pkt on a Dell Latitude D820 laptop running Neutrino natively in dual core mode. It's got a Broadcom GigE
interface which works with io-net.
With io-pkt, I use the bge driver. Doing an
ifconfig bge0 192.168.51.116
was leading to a pause of roughly 1-2 seconds before the prompt returned. With the old io-net, an ifconfig did not
introduce such a pause.
Is this expected behaviour? What is happening in this (very long, from a CPU speed point of view, although the CPU
utilize graph did not go up) time? Many QNX Neutrino users care a lot about boot time being as quickly as possible and
can not afford a 1-2 seconds pause.
Any feedback will be greatly appreciated.
Cheers,
Malte
Re: ifconfig pause
On Fri, Nov 16, 2007 at 10:27:08AM -0500, Malte Mundt wrote:
> natively in dual core mode. It's got a Broadcom GigE interface which
> works with io-net.
> returned. With the old io-net, an ifconfig did not introduce such a
> pause.
> CPU speed point of view, although the CPU utilize graph did not go up)
> quickly as possible and can not afford a 1-2 seconds pause.
In io-net 'ifconfig up / down' didn't actually enable /
disable the hardware (it set a flag in the stack marking it
as down but the hardware was still hot).  When you assign an
address it also does the equivalent of 'ifconfig up' so I
suspect it's probably during the hardware init phase with
this particular driver.
Re: ifconfig pause
Wow, that was a quick reply! And what you say makes complete sense. So for users who are concerned about boot speed,
just using an '&' symbol to initialize in the background will be ok, I guess? Is there an equivalent for
waitfor /dev/io-net/en0
in io-pkt?
In older buildfiles I also saw
waitfor /dev/socket
Which one makes sense in combination with a
ifconfig bge0 192.168.51.116 &  (<- starting it in the background)
do_something_that_does_not_need_network
waitfor... ?
do_something_that_needs_network
Cheers,
Malte
