help with custom io-pkt driver design / debug
07/15/2010 5:12 PM
post59597
We have custom io-pkt driver that interfaces with a proprietary network interface.
Network interface is managed by a QNX resource manager, so rather then interacting with the hardware directly, our io-
pkt driver must interface with the resource manager. This is a low-bandwidth connection, so throughput is not an issue.
Our current design spawns a thread (using pthread_create) in the io-pkt attach callback. This thread read-blocks on the
resource manager and when packets arrive, places them in a in-memory queue.
In the process_interrupt callback, we check this queue for packets and push them into the io-pkt stack.
Things work well most of the time, but sometimes the system locks up. System time appears to stop advancing, network
calls hang and we lose serial shell connectivity.
I suspect we are violating some rules in the process_interrupt callback and blocking/corrupting the system timer.
We use standard pthread_mutex calls to protect access to the in-memory queue between the rx thread and the process
interrupt callback.
Should we be usings the NW_SIGLOCK calls instead?
Is the process_interrupt() invoked in normal context or is it an interrupt or signal handler? What are the restrictions
on method usage in this context?
Dan Giorgis
