Forum Topic - io-pkt "losing" IRQs: (6 Items)
We have an open ticket in the support system regarding network crashes that we are experiencing at a customer site.
We have just upgraded to 6.41 in the hope that this would help, but it has failed to solve the problem (and has actually
 made it worse on one system).
This is a standard x86 Quad Core PC system running current 6.4.1 with the e1000 driver and three NICs (two on IRQ7, one
on IRQ11).
One thing that seems very curious is that after the crash, io-pkt has "lost" the IRQs that it had previously hooked. For
 example:
On a working system ("pidin irq" extract):
114707   1 sbin/io-pkt-v4-hc
 114707   2 sbin/io-pkt-v4-hc
		12                0    0 T-- @0x80b7334:0x812a060
		13              0x7    0 T-- @0xb82225bb:0x81539c0
		14              0xb    0 T-- @0xb82225bb:0x81c1180
 114707   3 sbin/io-pkt-v4-hc
 114707   4 sbin/io-pkt-v4-hc
 114707   5 sbin/io-pkt-v4-hc
 114707   6 sbin/io-pkt-v4-hc
 114707   7 sbin/io-pkt-v4-hc
 114707   8 sbin/io-pkt-v4-hc
On the same system, after it has failed:
               11                0    0 T-- @0x80b7334:0x812a060
 114707   9 sbin/io-pkt-v4-hc
This seems very weird to me. How can io-pkt have un-hooked the IRQs? What does this mean? By the way, there is nothing
in sloginfo.
I don't mean to circumvent the official support ticket (or imply that we're not getting a good response through that
mechanism. We are.) But this seems very weird and I wanted to share it with a wider audience it case anyone else might
have a useful comment/suggestion. And we are desperate since this is killing us in the field.
Any ideas/comments certainly welcomed.
Rob Rutherford
Ruzz TV
Re: io-pkt "losing" IRQs
It only looks like the ethernet driver unregister the interrupt. what is pidin -p io-pkt-v4-hc mem
Who crashes?
or run the driver with verbose=5 may see more in sloginfo.
yao
> failed to solve the problem (and has actually made it worse on one system).
> e1000 driver and three NICs (two on IRQ7, one on IRQ11).
> the IRQs that it had previously hooked. For example:
>  this mean? By the way, there is nothing in sloginfo.
> not getting a good response through that mechanism. We are.) But this seems
> might have a useful comment/suggestion. And we are desperate since this is
> Thanks,
> Rob Rutherford
> Ruzz TV
Please can you add the following lines to your build file, before the
diskboot line:
slogger -s128k
pci-bios -vvv
waitfor /dev/pci
Rebuild your boot image and reboot the machine. After the crash, please post
the output from 'pidin mem' as well as the sloginfo output.
Thanks, Hugh.
> Thanks,
> Rob Rutherford
> Ruzz TV
> Technology
> http://community.qnx.com/sf/go/post59414
Kanata, Ontario, Canada.
K2M 1W8
> diskboot line:
> slogger -s128k
> pci-bios -vvv
> waitfor /dev/pci
We haven't had a chance yet to capture this info with the requested changes to the boot image.
But I have attached a set of data that was captured from the previous crash yesterday, this includes "pidin mem" and "
pci -v". I will post the same set of data again as soon as I can following the next crash (only this time with the
modified boot image).
Thanks.
Attachment: Text felixdb1_logs.tgz 13 KB
Look at sloginfo, it seems qnet complains "No interfaces" any more, and pidin irq no e1000 interrupts any more. Probably
 e1000 unregister the interrupts under some conditions.
I guess that is a clue to debug.
> > diskboot line:
> > slogger -s128k
> > pci-bios -vvv
> > waitfor /dev/pci
>  the boot image.
> yesterday, this includes "pidin mem" and "pci -v". I will post the same set of
> Thanks.
The only things that come to mind are:
- io-pkt crashed and got restarted
- There's more than one instance running.
- the interface(s) got unloaded somehow.
Probably e1000 unregister the interrupts under some conditions.
> > > diskboot line:
> > > slogger -s128k
> > > pci-bios -vvv
> > > waitfor /dev/pci
> >  the boot image.
> > Thanks.
> Technology
> http://community.qnx.com/sf/go/post59514
