Forum Topic - Conditional SSI expression with slinger webserver:
I try show individual HTML text depending on the system variable SYSTEM_NAME. Therefore I use an expression like <!--#if
 "SERVER_NAME" hasstring "S" printbreak "<P>Test." -->
Problem is that the name SERVER_NAME seems to be interpreted as a string itself. I would rather have the content of the
environment variable SYSTEM_NAME compared to my test string. Omitting " " won't help. Any suggestions?
Re: Conditional SSI expression with slinger webserver
I believe you need to enclose with &&, as in  "&&SYSTEM_NAME&&".
However, I can't find an anything called SYSTEM_NAME in SSI. There is
SERVER_NAME but not SYSTEM_NAME AFAICT...
Anyways, hope this helps...
/P
Therefore I use an expression like<!--#if "SERVER_NAME" hasstring "S" printbreak "<P>Test." -->
the environment variable SYSTEM_NAME compared to my test string. Omitting " " won't help. Any suggestions?
> Technology
> http://community.qnx.com/sf/go/post54059
This works! And yes, I ment SERVER_NAME. Thanks!
Great to hear that it worked :-)
