Forum Topic - How to install Slinger web server?: (10 Items)
Hello all-
QNX newbie here, so please pardon this post if I'm missing something obious.
Ins Neutrino 6.4.1, the software installer is no longer included. How does one go about installing the Slinger web
server if it was not initially installed when the system was set up?
I've tried searching for the source (in order to do a configure->make->make install) but can't seem to locate that
anywhere. It's not in pkgsrc, either.
Thanks in advance,
Dave
Re: How to install Slinger web server?
No need to do the configure dance.
Slinger is installed at /usr/sbin/slinger on a default PC install of
QNX. It is also available under $QNX_TARGET.
Docs including examples are here:
http://www.qnx.com/developers/docs/6.4.1/neutrino/utilities/s/slinger.html
http://www.qnx.com/developers/docs/6.4.1/neutrino/user_guide/embedded_web_server.html
Hope this helps,
/P
On 21/04/10 03:40 PM, David Rea wrote:
> Hello all-
> Thanks in advance,
> Dave
> Technology
> http://community.qnx.com/sf/go/post52309
Thank you Patrik - My curiosity is how Slinger is installed if it was not initially included when the OS was installed.
Is this even possible? Is Slinger simply included with all QNX installations?
Dave
RE: How to install Slinger web server?
> From: David Rea [mailto:community-noreply@qnx.com]
> Sent: Wednesday, April 21, 2010 3:58 PM
> To: technology-networking
> Subject: Re: How to install Slinger web server?
> not initially included when the OS was installed. Is this even
> possible?
Yes it is.
> Thanks,
> Dave
> Technology
> http://community.qnx.com/sf/go/post52320
Dave,
you seem to come from a Linux world where you install many things from
sources.
In QNX you get a binary of every utility listed in the documentation.
This helps you prevent versioning issues.
If you have a CD install of QNX on an x86 box then you have slinger
under /usr/sbin.
If you are making your own custom system then you need to copy the
binary from your development machine (HOST)'s
${QNX_TARGET}/cpu_arch/usr/sbin to your target boards /usr/sbin.
QNX_TARGET is something like /QNX641/target/qnx6 and cpu_arch is x86,
armle, sh, etc.
  Mate
Sent: April 22, 2010 4:58 AM
not initially included when the OS was installed. Is this even possible?
Dave
Technology
slinger is included with the OS
> Sent: Wednesday, April 21, 2010 3:40 PM
> Subject: How to install Slinger web server?
> Hello all-
> obious.
> does one go about installing the Slinger web server if it was not
> >make install) but can't seem to locate that anywhere. It's not in
> pkgsrc, either.
> Thanks in advance,
> Dave
> Technology
Re: RE: How to install Slinger web server?
Thank you all for the replies!
Dave
OK, thanks again guys...
Now, another quick question - is there an easy way to have QNX automatically launch Slinger as a background process on
each bootup? I can write a shell script to set the environment variables and launch the server binary, but what would
launch that script?
Dave
If you're using a PC install, then /etc/rc.d/rc.local, but could also
use the startup script if you're making an IFS yourself.
http://www.qnx.com/developers/docs/6.4.1/neutrino/building/building_nto.html#CONFIG
I've always thought that the QNX documentation is really good, have a
look at the guides here:
http://www.qnx.com/developers/docs/6.4.1/momentics/bookset.html
/P
launch that script?
> Thanks,
> Dave
> Technology
> http://community.qnx.com/sf/go/post52812
Thank you Patrik - I've been doing some searching but hadn't come up with the pages you linked yet - I appreciate your
help!!
Dave
