Forum Topic - Network disconnect/reconnect notification: (10 Items)
1) We are writing an application that would like to be notified when the network cable is disconnected or reconnected
(or link is lost/established).  Is there a way to get this notification?
2) Is there any way to get notification of when the IP address on an interface is assigned or changed?
3) We are also wondering what kind of code we need in our network applications to handle the case where the interface IP
 address is changed?  Either because we get a new DHCP address, or the network cable is unplugged from one network and
plugged into another.  If we don't need any code is there any explanation of what messages we get from the socket layer
in such a case.
Jared
Re: Network disconnect/reconnect notification
IP address is changed?  Either because we get a new DHCP address, or the network cable is unplugged from one network and
 in such a case.
You can use a routing socket. You can see code examples in 'route
monitor' command or 'if_up'.
HTH,
/P
Thank you.  I will take a look.
Jared
Should ifwatchd work with en0?
It doesn't seem to be.  We did “Ifwatchd –vi –n no_carrier.sh en0” and then pulled the network cable on the QNX PC
and a ARM QNX board.  We didn't see our script run (our script just does an echo message).
Any ideas of if there is a way to get this to work?
I would be a lot nicer then having to poll checking the status as is done in if_up.
Jared
> It doesn't seem to be.  We did ???Ifwatchd ???vi ???n no_carrier.sh en0??? and then pulled the network cable on the
QNX PC and a ARM QNX board.  We didn't see our script run (our script just does an echo message).
Which driver are you running?
That was a fast response!
We tried it on a Freescale MCI-MX 25 (arm board) and a BCM 5751 pkfbg (PC).
If you want more specific driver information can you tell me a quick way to get it.  I had my co-worker do a nicinfo to
get that.
Jared
to get that.
In general io-net drivers won't support this.
Native io-pkt drivers 'should'.
RE: Network disconnect/reconnect notification
IIRC it's the if_link_state_change(ifp,LINK_STATE_XXX)
function that needs to be called by the driver?
Someone should create a PR against the shim for
this so that it is known/documented.  It might
actually be possible to fix it in the shim.
aboyd
PR 70778.
This could depend on what driver you're using...
