Forum Topic - Deterministic ethernet frame transmision: (10 Items)
Hi all,
I have a project where I need to transmit ethernet frames very deterministic, every 200us +/- 10%.
I have tried using a bpf device which transmits packets via io-pkt. I call the write function from a pulse event timer
(at priority 200) that is set to fire every 2 tics (I have set the tick rate to 100us).
I have made some measurents on this, which shows that I get a mean time between frames transmitions of very close to
200us, but I also see that the max time between frames is around 250us and the minimum time is around 150us, which is
not quite good enough for my application.
I have tried with other combinations of tick rate and tics per pulse event, but I cannot find a combination that
performs better than the 100us/2 tics combination.
My HW is a 600 MHz MPC8377 processor with integrated ethernet controllers.
Does any one have an idea where this jitter comes from, and how I can minimize it?
Wold it be posible to transmit frames from a interrupt routine?
(I have a 200us HW interrupt to the processor)
Best Regards
Rasmus
Re: Deterministic ethernet frame transmision
On 25/02/10 02:56 AM, Rasmus Nielsen wrote:
> Hi all,
You should first of all check the docs to see what precision you can
expect from a pulse event timer you're using.
PS. I think somebody was asking a similar question in the one  of the
networking forums earlier. You may be able to search it out again.
Probably, you've got to be careful what you do inside an ISR though.
You'd probably want to load your app into io-pkt as an lsm. That way
you're also "closer" to the actual transmitting code, i.e. you eliminate
the step from app to io-pkt. See wiki about lsms and the code has
examples how do write an lsm, e.g. autoip, nraw, qnet.
/P
RE: Deterministic ethernet frame transmision
Have you looked at a kernel trace yet?  You should find
out what other interrupts are firing in the system, and
what other (eg high priority) processes might be pre-empting
you.
Also, ensure that periodic MDI PHY probing in your
ethernet driver is turned off.  It should be by default,
but if it is occurring, it can cause these sorts of problems.
Also, ensure in the driver devctl that when an application
collects statistics (eg shelf) that it does not do an unnecessary
amount of processing with the mutex held.  IIRC the speedo
driver had a PR about this a while back.
I wouldn't jump headfirst into putting everything in the
ISR until you have exhausted all of the above.  It might
be something simple.
Historical note:  when I was young and foolish, I wrote
the entire QNX 4.0 arcnet driver in thousands of lines
of assembly.  In the quest for wire rate, it did far more
than it really needed to in the isr!
aboyd
Re: RE: Deterministic ethernet frame transmision
Hi Andrew
You mentioned about kernel traces here.
Can you please let me know how to enable these traces and where to look for them in QNX 6.3.0?
Regards
Vineet
RE: RE: Deterministic ethernet frame transmision
Re: RE: RE: Deterministic ethernet frame transmision
Hi Andrew
Thanks for the link about tracelogger.
Just a quick question,
the link talks about instrumented kernel. Is there a way to get some level of kernel traces in non-instrumented build?
Regards
VG
RE: RE: RE: Deterministic ethernet frame transmision
No, you need to run the instrumented kernel to get the traces.
aboyd  www.PoweredByQNX.com/movies/headon.wmv
hello,
I was able to run procnto-instr today and observed the output using
tracelogger/traceprint utlity as mentioned in documentation.
However, the output was pretty cryptic with lots of numbers in there,
possibly addresses of instructions being executed.
Is there a concept of debug symbols in QNX which help making a better sense
out of kernel traces?
Regards
Vineet
On Fri, Jul 2, 2010 at 8:36 PM, Andrew Boyd <community-noreply@qnx.com>wrote:
> Technology
> http://community.qnx.com/sf/go/post58334
You can use the IDE to look at the .kev. There is usually a lot of
events so you need to first filter out what you don't need...
On 10-07-07 03:06 PM, Vineet Garg wrote:
> hello,
> Regards
> Vineet
> On Fri, Jul 2, 2010 at 8:36 PM, Andrew Boyd<community-noreply@qnx.com>wrote:
>> Technology
> Technology
> http://community.qnx.com/sf/go/post58869
Use Momentic`s system profiler.
-----Message d'origine-----
De : Vineet Garg [mailto:community-noreply@qnx.com]
Envoyé : 7 juillet 2010 15:07
À : technology-networking
Objet : Re: RE: RE: Deterministic ethernet frame transmision
hello,
Regards
Vineet
> Technology
Technology
