Forum Topic - difference between io-pkt-v4 and io-pkt-v4-hc when encryption not used:
Customer is using io-pkt-v4-hc -p tcpip forward
My understanding is that they are not needing any of these:
IPv6
Crypto / IPSec
802.11 a/b/g WiFi
Bridging
GRE / GRF
Multicast routing
Multipoint PPP
Also, the target need not forward packets from one interface to another; only communication between two local processes
is required over the loopback device.
If they run only "io-pkt-v4" instead of "io-pkt-v4-hc -p tcpip forward" what will be the difference be in CPU usage, if
any, however minimal?
thanks
asherk
Re: difference between io-pkt-v4 and io-pkt-v4-hc when encryption not used
> IPv6
> Crypto / IPSec
> 802.11 a/b/g WiFi
> Bridging
> GRE / GRF
> Multicast routing
> Multipoint PPP
processes is required over the loopback device.
if any, however minimal?
There shouldn't be any difference in cpu usage.
