Re: npm-rawcan ethernet driver
08/03/2009 10:54 AM
post35138
On Mon, Aug 03, 2009 at 12:04:53AM -0400, Brabhu Hansen wrote:
> Has any one tried using the ethernet over CAN for io-pkt?
> The existing code which i found is only for io-net. Can this be made run using shim library under ../sys/dev_qnx/shim?
or a complete porting of npm-rawcan is needed
I'm not familiar with npm-rawcan but 'npm' suggests it's
a protocol module, not a driver. The shim handles drivers
so it probably won't work without some porting effort.
