strange behavior of using pcap.h
07/28/2009 10:51 AM
post34722
Dear All,
Fortunately I was able to use pcap.h to capture packet in QNX. I am using below command to open a session
/* Open the session in promiscuous mode */
handle = pcap_open_live(dev, 65536, 1, 1000, errbuf);
I am also using below commands to capture and store packets
for(i=0;i<32000;i++)
packet=pcap_next(handle, &header);
local_tv_sec = header.ts.tv_sec;
ltime=localtime(&local_tv_sec);
strftime( timestr, sizeof(timestr), "%H:%M:%S", ltime);
fprintf(stream1,"%s,%.6d len:%d\n", timestr, header.ts.tv_usec, header.len);
I have a testing device which sends two packets per 250usec. Therefore, I am expecting to capture packets in the same
trend.
By the way, two network cards are connected to my QNX target machine and I am using one of them only for data capturing
from tester.
let's see some part of the captured data. Instead of getting two packets every 250usec I am getting 64 to 65 packets
every 8389 usec. Is there anything wrong with the settings or netwrok driver in QNX. I tested the same network card in
windows XP embedded with winpcap and it was working very well. I would be very thankful if you help me.
10:23:11,599566 len:121
10:23:11,607955 len:121
10:23:11,607955...
RE: strange behavior of using pcap.h
07/28/2009 10:54 AM
post34723
> I am getting 64 to 65 packets every 8389 usec.
I think the system time which localtime() is
fetching is only being updated every 10ms timer
tick.
I think you want a better timestamp - try
clockcycles() or something like that.
aboyd
Re: strange behavior of using pcap.h
07/28/2009 11:03 AM
post34730
On Tue, Jul 28, 2009 at 10:51:19AM -0400, Mohammad Dadashzadeh wrote:
> Dear All,
That's the clockrate in io-pkt:
# sysctl kern.clockrate
kern.clockrate: tick = 8403, hz = 119
07/28/2009 11:14 AM
post34731
07/28/2009 11:15 AM
post34732
On Tue, Jul 28, 2009 at 11:14:11AM -0400, Mohammad Dadashzadeh wrote:
> can I change it?
It would involve a re-compile.
07/28/2009 11:18 AM
post34734
Sorry I did not get it,
Recompile of what, Could you please let me know How I can do it?
Mohammad
07/28/2009 11:23 AM
post34735
You'd need to check out the source from the networking
repo and follow the instructions here:
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/Source_Guide
The defines that control this are in io-pkt/sys/sys/time_bsd.h
(look for __QNXNTO__)
07/28/2009 12:25 PM
post34743
Could I do this in evaluation version where I have QNX Momentics IDE Version 4.6.0?
Mohammad
07/28/2009 12:48 PM
post34746
> .6.0?
> Mohammad
Should I have website downloader to download all the files.
http://community.qnx.com/svn/repos/coreos_pub/trunk/
Mohammad
07/28/2009 1:01 PM
post34748
when I use my user name in this command it does not work?
svn checkout --username <username> http://community.qnx.com/svn/repos/coreos_pub/trunk
Mohammad
07/28/2009 1:03 PM
post34750
> Mohammad
it shows :
PRPOFIND request failed on .......
........... 405 method Not allowed
07/28/2009 5:13 PM
post34759
I am trying to recompile the source based on below document
http://community.qnx.com/sf/sfmain/do/downloadAttachment/projects.core_os/wiki/BuildKernelWithIDE?id=atch1253
at the end when I run it says:
/cygdrive/c/QNX641/workspace not a directory
07/29/2009 9:59 AM
post34790
I'm not sure that applies to the networking source...
I've never tried building under the IDE but a
straight 'make' as described here should work.
07/29/2009 10:30 AM
post34796
> Source_Guide
> Regards,
> -seanb
Should I do this in QNX machine or in development machine I am really confused.
Should I rebuild the entire OS or just Networking core.
svn command works in QNX machine not in development machine.
Mohammad
07/29/2009 10:35 AM
post34798
> > Source_Guide
> > Regards,
> > -seanb
The development machine (note a QNX machine can also
be a development machine). For this particular issue
only the io-pkt binary need to be touched but it's
often easier to build the entire networking tree as
described in the above link.
07/29/2009 11:07 AM
post34803
in order to change the 8.39 msec to 32 usec
this is the default
* 2^23ns = 2^23ns * (1000ms / 10^9ns) = 8.39ms = 119.209Hz
#define NTO_TSHIFT 23
#define NTO_HZ 119
#define NTO_mHZ 119209
I am going to change it to
* 2^15ns = 2^15ns * (1000ms / 10^9ns) = 32.77us = 30517.578Hz
#define NTO_TSHIFT 15
#define NTO_HZ 30517
#define NTO_mHZ 30517578
and then compile,
is this correct?
Mohammad
07/29/2009 11:12 AM
post34804
that is correct but probably it won't work as many places are assuming 1 HZ is 8ms but now it is not. but you could try.
07/29/2009 11:48 AM
post34809
On an X86 (at least), the clock interrupts happen at a rate close to one per millisecond, so you can never achieve a
pcap timestamp resolution better than about one millisecond.
If what you're after is better resolution, it might be easier to just build your own bpf.c.
Murf
07/29/2009 11:51 AM
post34810
> millisecond, so you can never achieve a pcap timestamp resolution better than
> your own bpf.c.
> Murf
From where should I start to learn how to write my own bpf.c file. I was getting very good resolution in win XP using
winpcap.
Mohammad
07/29/2009 11:58 AM
post34813
Take a look at sys/net/bpf.c in the networking trunk. I believe it sets the timestamp via a call to microtime, which is
in sys/currenttime.c, which calsl mtime in the same file), which get the current time, then maks off a bunch of the
least significant digits.
I may be way off base here, and this might just lead you into another round of "what's going on here?", but I'd sure
take a look at the other possibilities before I tried to rebuild all of io-pkt with a rather fundamental change --- but
that's just me.
Murf
07/29/2009 12:46 PM
post34817
is in sys/currenttime.c, which calsl mtime in the same file), which get the current time, then maks off a bunch of the
that's just me.
It seems to boil down to pcap_open_live() taking a timeout
the smallest value of which boils down to HZ in the stack
(stack rounds up to that value). A value of zero means wait
until the buffer's full. There's a BIOCIMMEDIATE bpf ioctl
that would probably help here but libpcap currently only
uses it for AIX.
Soo... The easier 'fix' would be to set BIOCIMMEDIATE in
pcap_open_live() if the timeout is less than a tick which
you can get from sysctl() / sysctlbyname().
07/29/2009 1:03 PM
post34819
Sean, are we talking about the resolution of the timestamps, or how often pcap satisfies a read request?
Murf
07/29/2009 1:11 PM
post34821
I guess I probably didn't reply on the proper leaf
on the thread. I'm talking about the delay in
replying to the read(). I can't see that the timestamp
here is used for anything but you're right in that
it's not all that granular.
07/29/2009 2:12 PM
post34829
> Regards,
> -seanb
I think I may have missed the whole point of this thread! I thought the concern was for the lack of granularity, as
evidenced by the printed timestamps.
Murf
07/29/2009 1:12 PM
post34822
in which file I can change BIOCIMMEDIATE ?
Mohammad
07/29/2009 2:48 PM
post34836
Please try this libpcap. By default it should
work the same way, if you pass a negative timeout
to pcap_open_live() you should get immediate mode.
If you can verify both I'll check it in.
07/29/2009 3:06 PM
post34838
> Regards,
> -seanb
Should copy libpcap.a into the target machine or Momentics IDE or both?
07/29/2009 3:13 PM
post34839
> > Regards,
> > -seanb
Just link against it via your favourite method. It's not
needed at runtime as it's a static variant. I'm trying to
'bring the mountain to Mohammad' but as I'm not at your
build environment I can't be more specific than that :)
07/29/2009 3:14 PM
post34840
> > Regards,
> > -seanb
BTW that was an x86 static variant.
07/29/2009 3:20 PM
post34841
> > > Regards,
> > > -seanb
> -seanb
Unfortunately I do not understand "BTW that was an x86 static variant"
Could you please explain more?
I copied into C:\QNX641\target\qnx6\x86\usr\lib but code can not ve compiled. It shows many error.
Mohammad
07/29/2009 3:22 PM
post34842
> > > > Regards,
> > > > -seanb
> > -seanb
What are the errors?
07/29/2009 3:36 PM
post34844
> > > > > Regards,
> > > > > -seanb
> > > -seanb
> -seanb
Description Resource Path Location Type
make[2]: *** [C:/ide-4.6-workspace/newPacketcap/x86/o-g/newPacketcap_g] Error 1 newPacketcap line 0 C/C++ Problem
make[2]: *** [C:/ide-4.6-workspace/newPacketcap/x86/o/newPacketcap] Error 1 newPacketcap line 0 C/C++ Problem
newPacketcap.c: undefined reference to `pcap_close' newPacketcap line 0 C/C++ Problem
newPacketcap.c: undefined reference to `pcap_findalldevs' newPacketcap line 0 C/C++ Problem
newPacketcap.c: undefined reference to `pcap_freealldevs' newPacketcap line 0 C/C++ Problem
newPacketcap.c: undefined reference to `pcap_lookupdev' newPacketcap line 0 C/C++ Problem
newPacketcap.c: undefined reference to `pcap_lookupnet' newPacketcap line 0 C/C++ Problem
newPacketcap.c: undefined reference to `pcap_next' newPacketcap line 0 C/C++ Problem
newPacketcap.c: undefined reference to `pcap_open_live' newPacketcap line 0 C/C++ Problem
undefined reference to `pcap_close' newPacketcap.c newPacketcap line 109 C/C++ Problem
undefined reference to `pcap_findalldevs' newPacketcap.c newPacketcap line 32 C/C++ Problem
undefined reference to `pcap_freealldevs' newPacketcap.c newPacketcap line 65 C/C++ Problem
undefined reference to `pcap_lookupdev' newPacketcap.c newPacketcap line 75 C/C++ Problem
undefined reference to `pcap_lookupnet' newPacketcap.c newPacketcap line 82 C/C++ Problem
undefined reference to `pcap_next' newPacketcap.c newPacketcap line 100 C/C++ Problem
undefined reference to `pcap_open_live' newPacketcap.c newPacketcap line 88 C/C++ Problem
07/29/2009 3:40 PM
post34845
Hmm, try this one.
07/29/2009 3:46 PM
post34848
> Hmm, try this one.
> -seanb
I tried , no error but I am getting 64-65 packets every 8.3 msec.
Mohammad
07/29/2009 3:49 PM
post34849
> > Hmm, try this one.
> > -seanb
You changed the timeout to a negative value?
07/29/2009 3:53 PM
post34850
> > > Hmm, try this one.
> > > -seanb
> -seanb
yes handle = pcap_open_live(dev, 1000, 1, -1, errbuf);
#include <pcap.h>
#include <stdio.h>
#include <string.h>
#include <time.h>
#include <sys/netmgr.h>
#include <sys/neutrino.h>
int main(int argc, char *argv[])
pcap_t *handle; /* Session handle */
char *dev; /* The device to sniff on */
pcap_if_t *alldevs;
pcap_if_t *d;
char errbuf[PCAP_ERRBUF_SIZE]; /* Error string */
struct bpf_program fp; /* The compiled filter */
bpf_u_int32 mask; /* Our netmask */
bpf_u_int32 net; /* Our IP */
struct pcap_pkthdr header; /* The header that pcap gives us */
const u_char *packet; /* The actual packet */
time_t local_tv_sec;
struct tm *ltime;
int i=0;
char timestr[16];
int inum;
FILE *stream1;
//const u_char *packet;
/* Retrieve the device list on the local machine */
if (pcap_findalldevs(&alldevs, errbuf) == -1)
fprintf(stderr,"Error in pcap_findalldevs: %s\n", errbuf);
exit(1);
stream1=fopen("test2.txt","w");
/* Print the list */
for(d=alldevs; d; d=d->next)
printf("%d. %s", ++i, d->name);
if (d->description)
printf(" (%s)\n", d->description);
else
printf(" (No description available)\n");
if(i==0)
printf("\nNo interfaces found! Make sure WinPcap is installed.\n");
return -1;
printf("Enter the interface number (1-%d):",i);
//scanf("%d", &inum);
inum=1;
if(inum < 1 || inum > i)
printf("\nInterface number out of range.\n");
/* Free the device list */
pcap_freealldevs(alldevs);
return -1;
/* Jump to the selected adapter */
for(d=alldevs, i=0; i< inum-1 ;d=d->next, i++);
/* Define the device */
dev = pcap_lookupdev(errbuf);
strcpy(dev,"wm0");
if (dev == NULL) {
fprintf(stderr, "Couldn't find default device: %s\n", errbuf);
return(2);
/* Find the properties for the device */
if (pcap_lookupnet(dev, &net, &mask, errbuf) == -1) {
fprintf(stderr, "Couldn't get netmask for device %s: %s\n", dev, errbuf);
net = 0;
mask = 0;
if (handle == NULL) {
fprintf(stderr, "Couldn't open device %s: %s\n", errbuf);
return(2);
/* Grab a packet */
//packet = pcap_next(handle, &header);
/* Print its length */
//printf("Jacked a packet with length of [%d]\n", header.len);
/* And close the session */
pcap_close(handle);
fclose(stream1);
printf("\n done");
return(0);
07/29/2009 4:14 PM
post34855
> > > > Hmm, try this one.
> > > > -seanb
> > -seanb
Whatever I put as to_ms, there is no change in interval of reading packets.
Mohammad
07/29/2009 11:55 AM
post34812
> From: John Murphy [mailto:community-noreply@qnx.com]
> Sent: Wednesday, July 29, 2009 11:48 AM
> To: ionetmig-networking
> Subject: Re: strange behavior of using pcap.h
> one per millisecond, so you can never achieve a pcap timestamp
Sure you can with ClockCycles()
> Murf
> io-net migration
> http://community.qnx.com/sf/go/post34809
Re: RE: strange behavior of using pcap.h
07/29/2009 12:01 PM
post34815
Exactly! But that's a bit different than monkeying with constants that affect all of the networking code.
Murf
07/29/2009 12:36 PM
post34816
in mtime it is using tick not microsecond so I think you can modify it to use microsecond then you should be able to get
microsecond precision.
if mtime is not local then you should be able to preload to override it but it is static.
07/29/2009 1:13 PM
post34823
Where is mtime? how can I change it?
07/30/2009 11:44 AM
post34926
0805ca45 <mtime>:
805ca45: 55 push %ebp
805ca46: 89 e5 mov %esp,%ebp
805ca48: 83 ec 28 sub $0x28,%esp
805ca4b: 89 5d f4 mov %ebx,-0xc(%ebp)
805ca4e: 89 75 f8 mov %esi,-0x8(%ebp)
805ca51: 89 7d fc mov %edi,-0x4(%ebp)
805ca54: 89 cf mov %ecx,%edi
805ca56: 85 d2 test %edx,%edx
805ca58: 0f 94 c0 sete %al
805ca5b: 0f b6 c0 movzbl %al,%eax
805ca5e: 89 04 24 mov %eax,(%esp)
805ca61: e8 a0 fe ff ff call 805c906 <currtime_nto>
805ca66: 89 c3 mov %eax,%ebx
805ca68: 81 e3 00 00 80 ff and $0xff800000,%ebx
805ca6e: 89 d6 mov %edx,%esi
805ca70: 8b 15 4c 63 0c 08 mov 0x80c634c,%edx
805ca76: 31 f2 xor %esi,%edx
805ca78: a1 48 63 0c 08 mov 0x80c6348,%eax
805ca7d: 31 d8 xor %ebx,%eax
805ca7f: 09 c2 or %eax,%edx
805ca81: 74 6a je 805caed <mtime+0xa8>
0805ca45 <mtime>:
Here curtick = cur & ~((1 << NTO_TSHIFT) -1); so it is rounding to tick.
You can change it to curtick = cur & ~(1024-1) then you will get microsend precision not tick any more.
so hack io-pkt-*(you don't need to recompile) and find the address
and change 00 00 80 ff to 0xfffffc00(00 fc ff ff)
static void
mtime(int get, int up, struct timeval *tv)
static uint64_t mtlast;
static struct timeval mt_tv;
uint64_t cur, curtick;
* See comments in <sys/timevar.h>. 'get' variants
* are allowed to return a less precise result.
cur = currtime_nto(!up);
if (1 /* get */) {
* Try to only do the 64 bit division every tick.
* Makes microtime() not so micro...
if (mtlast != curtick) {
mtlast = curtick;
mt_tv.tv_sec = mtlast / 1000000000;
mt_tv.tv_usec = (mtlast % 1000000000) / 1000;
else {
mtlast = curtick;
mt_tv.tv_sec = cur / 1000000000;
mt_tv.tv_usec = (cur % 1000000000) / 1000;
07/30/2009 12:25 PM
post34935
Or change the 'if (1 /* get */)' to 'if (get)'.
> static void
> if (1 /* get */) {
> mtlast = curtick;
> else {
> mtlast = curtick;
> io-net migration
> http://community.qnx.com/sf/go/post34926
07/30/2009 12:45 PM
post34939
Where can I find this mtime function to modify it?
Mohammad
07/30/2009 12:34 PM
post34936
> 0805ca45 <mtime>:
> 0805ca45 <mtime>:
> static void
> if (1 /* get */) {
> mtlast = curtick;
07/30/2009 12:58 PM
post34942
> > 0805ca45 <mtime>:
> > 0805ca45 <mtime>:
> > static void
07/30/2009 1:13 PM
post34944
Should I sreach my QNX nto machine or development machine. In which file should I exactly search
Mohammad
07/30/2009 1:32 PM
post34949
> Regards,
> Mohammad
If you mean source code then take a look the source tree: trunk/sys/current_time.c or tags/GA/6.4.0/sys...
if you mean binary, I refer io-pkt-v4. On you development machine, ntox86-objdump -d $QNX_TARGET/x86/sbin/io-pkt-v4 to
find <mtime>: If you can do this on your nto machine(target?) it would be better.
07/30/2009 2:21 PM
post34955
What software can open the file so I can edit it.
Mohammad
07/30/2009 2:31 PM
post34957
I am using xvi32 to open the file it finds one mtime but the codes around it is completely different than what you
mentioned above. I attached the file. Could you please modify this and send it for me.
Mohammad
07/30/2009 2:53 PM
post34959
there are two more similar files
io-pkt-v4-hc
io-pkt-v6-hc
I could not find below in these files
0805ca45 <mtime>:
0805ca45 <mtime>:
07/30/2009 3:11 PM
post34960
it is hacked then run this on your qnx target.
run "pidin arg|grep io-pkt*" on your target find which io-pkt you are using and make sure you are replace it with this
io-pkt-v4 not others.
keep a copy!
07/30/2009 3:28 PM
post34962
when I run pidin arg|grep io-pkt* it responses
114708 io-pkt-v4-hc -ptcpip
1220648 io-pkt*
now am I using io-pkt-v4-hc?
if yes, should I replace hacked version (io-pkt-v4) with (io-pkt-v4-hc) or with io-pkt-hc
or should we hack io-pkt-v4-hc
Mohammad
07/30/2009 4:38 PM
post34965
I learned how to hack io-pkt-v4-hc now the accuracy is 1msec, I am getting 8 packets per 1 msec
How can I reduce that to 100usec or less
Mohammad
07/31/2009 9:30 AM
post35016
I would like to get packets one by one. What should I do?
Mohammad
07/31/2009 10:01 AM
post35026
> Mohammad
take a look at source of pcap_open_live, in pcap_open_live there is code for AIX how to call if (ioctl(p->fd,
BIOCIMMEDIATE, &v) < 0) {
snprintf(ebuf, PCAP_ERRBUF_SIZE, "BIOCIMMEDIATE: %s",
pcap_strerror(errno));
goto bad;
you need to find out how to get fd.
another way probably you are ok now: still hack io-pkt-v4-hc,
if (d->bd_immediate || d->bd_state == BPF_TIMED_OUT)
* Immediate mode is set, or the read timeout has
* already expired during a select call. A packet
* arrived, so the reader should be woken up.
bpf_wakeup(d);
disassembly io-pkt-v4-hc's catchpacket, change d->bd_immediate to 1 then you will always get packet one by one.
default it won't be set in pcap_open_alive as it is fox AIX.
* Move the packet data from interface memory (pkt) into the
* store buffer. Return 1 if it's time to wakeup a listener (buffer full),
* otherwise 0. "copy" is the routine called to do the actual data
* transfer. memcpy is passed in to copy contiguous chunks, while
* bpf_mcpy is passed in to copy mbuf chains. In the latter case,
* pkt is really an mbuf.
static void
catchpacket(struct bpf_d *d, u_char *pkt, u_int pktlen, u_int snaplen,
void *(*cpfn)(void *, const void *, size_t), struct timeval *tv)
struct bpf_hdr *hp;
int totlen, curlen;
int hdrlen = d->bd_bif->bif_hdrlen;
++d->bd_ccount;
++bpf_gstats.bs_capt;
* Figure out how many bytes to move. If the packet is
* greater or equal to the snapshot length, transfer that
* much. Otherwise, transfer the whole packet (unless
* we hit the buffer size limit).
totlen = hdrlen + min(snaplen, pktlen);
if (totlen > d->bd_bufsize)
totlen = d->bd_bufsize;
* Round up the end of the previous packet to the next longword.
curlen = BPF_WORDALIGN(d->bd_slen);
if (curlen + totlen > d->bd_bufsize) {
* This packet will overflow the storage buffer.
* Rotate the buffers if we can, then wakeup any
* pending reads.
if (d->bd_fbuf == 0) {
* We haven't completed the previous read yet,
* so drop the packet.
++d->bd_dcount;
++bpf_gstats.bs_drop;
return;
ROTATE_BUFFERS(d);
bpf_wakeup(d);
curlen = 0;
* Append the bpf header.
hp = (struct bpf_hdr *)(d->bd_sbuf + curlen);
hp->bh_tstamp = *tv;
hp->bh_datalen = pktlen;
hp->bh_hdrlen = hdrlen;
* Copy the packet data into the store buffer and update its length.
(*cpfn)((u_char *)hp + hdrlen, pkt, (hp->bh_caplen = totlen - hdrlen));
d->bd_slen = curlen + totlen;
* Call bpf_wakeup after bd_slen has been updated so that kevent(2)
* will cause filt_bpfread() to be called with it adjusted.
bpf_wakeup(d);
I suggest you read source as it is not difficult. that is why open source is popular and we publish source code.
07/31/2009 10:13 AM
post35029
So the easiest way is to disassemble io-pkt-v4-hc's catchpacket, change d->bd_immediate to 1 then I will always get
packet one by one.
How can I disassemble io-pkt-v4-hc. Is there any software which can do the job for me.
I am attaching my io-pkt-v4-hc. Could you do me a favor and change d->bd_immediate to 1. I think after this I am done
and I can verify QNX for may application.
Regards
Mohammad
07/31/2009 11:27 AM
post35060
> > Mohammad
> goto bad;
> bpf_wakeup(d);
You can get the fd with pcap_fileno(), but I'm not convinced
anymore that he want's to get packets one at a time. I think
he's worried about the timestamp...
07/31/2009 10:12 AM
post35028
> Mohammad
Sean sent you a libpcap.a that lets you enable immediate mode. That
should be all you need.
Murf
07/31/2009 10:41 AM
post35043
> > Mohammad
I think that's the confusion in this thread. I think Mohammad's
under the impression that the timestamp in the packet is when
he's actually getting it. I'm not convinced anyore that the wait
on the read() is the concern. If the timestamp on the packet
is the primary sticking point the attached diff will get the
resolution of the system clock which by default is 1ms. The
system clock can then be changed with ClockPeriod() but I suspect
32us will be too much overhead.
| Attachment: |
diff
409 bytes
07/31/2009 10:46 AM
post35044
In this case I have to recompile io-pkt, am I write, I am not familiar with this procedure, any way to hack io-pkt-v4-hc
why this is not optional in QNX, so user can determine what they want.
Mohammad
07/31/2009 11:02 AM
post35050
> > Mohammad
> Murf
I did that, didn't work, even when I reboot my target machine it can not connect to net anymore.
Mohammad
07/31/2009 11:18 AM
post35055
> > > Mohammad
> > Murf
> Mohammad
Don't panic.
give me your source code(to make sure I can compile) and I can finish all for you. that will save all of us time.
07/31/2009 11:19 AM
post35056
> From: Yao Zhao [mailto:community-noreply@qnx.com]
> Sent: Friday, July 31, 2009 11:19 AM
> > > > Mohammad
> That
> > > Murf
> not
> > Mohammad
> Don't panic.
I also have some source code that need fixing, can I send it to you?
> io-net migration
> http://community.qnx.com/sf/go/post35055
07/31/2009 11:23 AM
post35058
I just installed QNX few days ago and I have not changed anything, I think the source is untouched and available in the
QNX website. Am I right?
Thanks alot,
Mohammad
07/31/2009 11:40 AM
post35063
> > > > Mohammad
> > > Murf
> > Mohammad
> Don't panic.
Source code of packet capturing, it is attached.
07/31/2009 11:24 AM
post35059
>>> Mohammad
>> Murf
> Mohammad
I compiled the code you published on this thread and linked it with
Sean's libpcap and it worked fine. I don't think we understand what you
mean by "not working".
Murf
07/31/2009 11:28 AM
post35061
> >>> Mohammad
> >> Murf
> > Mohammad
> Murf
I replaced linpcap.a which Sean sent with all libpcap.a files in my development and target machine. I recompiled and
built the project yet I am getting 8 packets every 1 ms while the packets are transmitted two every 250 usec.
Mohammad
07/31/2009 11:36 AM
post35062
> > >>> Mohammad
> > >> Murf
> > > Mohammad
> > Murf
> development and target machine. I recompiled and built the project yet I am
> usec.
> Regards,
> Mohammad
this is part of captured packets, compared to the packets shown in the first post I am getting 1 msec resolution. If I
use Wireshark, it captures two packets almost every 250 msec.
Mohammad
11:35:29,160460 len:121
11:35:29,161459 len:121
11:35:29,162460 len:121
11:35:29,163459 len:121
11:35:29,164460 len:121
07/31/2009 11:40 AM
post35064
> > >>> Mohammad
> > >> Murf
> > > Mohammad
> > Murf
> usec.
> Regards,
> Mohammad
You don't need to replace libpcap.a on target, it is only needed when you linking.
Post the io-pkt-v4-hc you modified here and output of your application, if you modified correctly it should be stamped
with microsecond, not millisecond.
in bpf_deliver it will only call microtime once in a packet loop so that is another guess.
Murf: can you get different timestamp for flood packets?
07/31/2009 11:45 AM
post35065
> > > >>> Mohammad
> > > >> Murf
> not
> > > > Mohammad
> > > Murf
> > usec.
> > Regards,
> > Mohammad
> linking.
> modified correctly it should be stamped with microsecond, not millisecond.
> another guess.
I do not know how to change d->bd_immediate to 1 in io-pkt-v4-hc. I attached my io-pkt-v4-hc
Mohammad
07/31/2009 11:51 AM
post35069
I get timestamps with the normal 8 us. resolution, as expected. The
changes that were suggested for mtime will produce ms., not us.,
resolution, since the hardware clock interrupts (approximately) once per
millisecond.
Murf
07/31/2009 12:01 PM
post35070
> millisecond.
> Murf
You should get 8ms resolution not 8us. as the tick.
Murf is right I forgot qtime is updated by timer so curtime_nto won't get better than 1 ms.
you should write a small program to call ClockPeriod to change system clock to smaller, like 250us. then run your app.
07/31/2009 12:13 PM
post35073
>> millisecond.
>> Murf
Yea, of course I meant 8ms., not 8us.! Even when I reread messages two
or three times before I hit the send button, I still make mistakes.
Guess I need a smarter "spell" checker....
Murf
07/31/2009 12:14 PM
post35074
> > millisecond.
> > Murf
> better than 1 ms.
Well done. It worked. I really appreciate. I am going to summarize the discussion and make it more useful for anyone who
may face the same problem. Just one thing I wanna confirm, was replacing libpcap.a necessary or not.
Best Regards,
Mohammad
12:12:13,165995 len:121
12:12:13,166206 len:121
12:12:13,166336 len:121
12:12:13,166538 len:121
12:12:13,166547 len:121
12:12:13,166769 len:121
12:12:13,166990 len:121
12:12:13,167211 len:121
12:12:13,167322 len:121
12:12:13,167543 len:121
12:12:13,167773 len:121
12:12:13,167985 len:121
12:12:13,168004 len:121
12:12:13,168217 len:121
12:12:13,168327 len:121
12:12:13,168539 len:121
12:12:13,168548 len:121
12:12:13,168770 len:121
12:12:13,168991 len:121
12:12:13,169212 len:121
12:12:13,169323 len:121
12:12:13,169534 len:121
12:12:13,169544 len:121
12:12:13,169765 len:121
12:12:13,169986 len:121
07/31/2009 12:40 PM
post35076
> > > millisecond.
> > > Murf
> > better than 1 ms.
> to
> discussion and make it more useful for anyone who may face the same problem.
> Best Regards,
> Mohammad
libpcap.a modification is not related to your timestamp problem so no.
07/31/2009 12:49 PM
post35077
> > Best Regards,
> > Mohammad
The final I have in mind likely will require a new stack
and libpcap.
07/31/2009 11:47 AM
post35066
>>>>> Mohammad
>>>> Murf
>>> Mohammad
>> Murf
> Regards,
> Mohammad
Sean's change was to enable immediate mode in BPF, and had nothing to do
with timestamps. You are seeing all the packets that get transmitted,
and, as has been explained several times in this thread, the resolution
of the timestamps you see on those packets is limited by the resolution
of the system clock. If you really think you need greater resolution on
the timestamps, it might be better to design you own packet capture
system, rather than make fundamental changes to the operating system,
especially by hacking the binaries.
By the way, please understand that I am in no way associated with QNX
other than being a happy user with about 30 years of experience in
packet sniffing --- and a little too much time on my hands this week.
Murf
07/31/2009 11:51 AM
post35068
I would really appreciate your help and support.
