07/24/2009 11:09 AM
post34520
Dear all,
I am a beginner in using QNX. I would like to use pcap.h to capture MAC packets. I am using bellow code to read all the
network devices. Code complies without any error. However, when I want to build the project it gives me below error. I
would be very thankful if someone helps me.
Description Resource Path Location Type
make[2]: *** [C:/ide-4.6-workspace/packetcapture2/x86/o-g/packetcapture2_g] Error 1 packetcapture2 line 0 C/C++ Problem
make[2]: *** [C:/ide-4.6-workspace/packetcapture2/x86/o/packetcapture2] Error 1 packetcapture2 line 0 C/C++ Problem
packetcapture2.c: undefined reference to `pcap_findalldevs' packetcapture2 line 0 C/C++ Problem
packetcapture2.c: undefined reference to `pcap_freealldevs' packetcapture2 line 0 C/C++ Problem
undefined reference to `pcap_findalldevs' packetcapture2.c packetcapture2 line 15 C/C++ Problem
undefined reference to `pcap_freealldevs' packetcapture2.c packetcapture2 line 38 C/C++ Problem
My code
#include <stdlib.h>
#include <stdio.h>
#include "pcap.h"
pcap_if_t *alldevs;
pcap_if_t *d;
int i=0;
char errbuf[PCAP_ERRBUF_SIZE];
printf("Welcome to the QNX Momentics IDE\n");
/* Retrieve the device list from the local machine */
if (pcap_findalldevs(&alldevs, errbuf) == -1)
fprintf(stderr,"Error in pcap_findalldevs_ex: %s\n", errbuf);
exit(1);
/* Print the list */
for(d= alldevs; d != NULL; d= d->next)
printf("%d. %s", ++i, d->name);
if (d->description)
printf(" (%s)\n", d->description);
else
printf(" (No description available)\n");
if (i == 0)
printf("\nNo interfaces found! Make sure WinPcap is installed.\n");
return;
/* We don't need any more the device list. Free it */
pcap_freealldevs(alldevs);
return EXIT_SUCCESS;
07/24/2009 11:12 AM
post34521
On Fri, Jul 24, 2009 at 11:09:39AM -0400, Mohammad Dadashzadeh wrote:
> Dear all,
the network devices. Code complies without any error. However, when I want to build the project it gives me below error
. I would be very thankful if someone helps me.
Problem
You need to link against libpcap.
07/24/2009 11:13 AM
post34522
07/24/2009 11:26 AM
post34524
thanks for yor reply
the link does not work
Mohammad
07/24/2009 11:24 AM
post34523
> > Dear all,
> packets. I am using bellow code to read all the network devices. Code complies
> below error. I would be very thankful if someone helps me.
> Regards,
> -seanb
You mean I have to add libpcap in Project\linker\Extra library\pcap
I did that it gives me more error.
undefined reference to `ether_hostton' packetcapture2 line 0 C/C++ Problem
undefined reference to `freeaddrinfo' packetcapture2 line 0 C/C++ Problem
undefined reference to `freeifaddrs' packetcapture2 line 0 C/C++ Problem
undefined reference to `getaddrinfo' packetcapture2 line 0 C/C++ Problem
undefined reference to `gethostbyname' packetcapture2 line 0 C/C++ Problem
undefined reference to `getifaddrs' packetcapture2 line 0 C/C++ Problem
undefined reference to `getnetbyname' packetcapture2 line 0 C/C++ Problem
undefined reference to `getprotobyname' packetcapture2 line 0 C/C++ Problem
undefined reference to `getservbyname' packetcapture2 line 0 C/C++ Problem
undefined reference to `ioctl_socket' packetcapture2 line 0 C/C++ Problem
undefined reference to `socket' packetcapture2 line 0 C/C++ Problem
C:/QNX641/target/qnx6/x86/usr/lib\libpcap.a(pcap-bpf.o): more undefined references to `ioctl_socket' follow
07/24/2009 11:27 AM
post34525
I guess so. However the ide lets you do it :)
Problem
These are in libsocket.
07/24/2009 12:02 PM
post34529
Thak you for your help. this helped to solve the problem. Now I am using pcap_loop to capture packets. The project
compiles and builds but during debugging when I run pcap_loop function the program stops and shows
No source available for "pcap_loop() "
my code
#include <stdlib.h>
#include <stdio.h>
#include "pcap.h"
/* prototype of the packet handler */
void packet_handler(u_char *param, const struct pcap_pkthdr *header, const u_char *pkt_data);
pcap_if_t *alldevs;
pcap_if_t *d;
int inum;
int i=0;
pcap_t *adhandle;
/* Retrieve the device list on the local machine */
fprintf(stderr,"Error in pcap_findalldevs: %s\n", errbuf);
exit(1);
for(d=alldevs; d; d=d->next)
if (d->description)
else
if(i==0)
return -1;
printf("Enter the interface number (1-%d):",i);
//scanf("%d", &inum);
inum=1;
if(inum < 1 || inum > i)
printf("\nInterface number out of range.\n");
/* Free the device list */
return -1;
/* Jump to the selected adapter */
for(d=alldevs, i=0; i< inum-1 ;d=d->next, i++);
/* Open the device */
adhandle=pcap_open_live(d->name, 65536, 1, 20, errbuf);
if (adhandle=NULL)
fprintf(stderr,"\nUnable to open the adapter. %s is not supported by WinPcap\n", d->name);
return -1;
//printf("\nlistening on %s...\n", d->description);
/* At this point, we don't need any more the device list. Free it */
/* start the capture */
pcap_loop(adhandle, 0, packet_handler, NULL);
/* Callback function invoked by libpcap for every incoming packet */
struct tm *ltime;
char timestr[16];
time_t local_tv_sec;
/* convert the timestamp to readable format */
local_tv_sec = header->ts.tv_sec;
ltime=localtime(&local_tv_sec);
strftime( timestr, sizeof timestr, "%H:%M:%S", ltime);
printf("%s,%.6d len:%d\n", timestr, header->ts.tv_usec, header->len);
07/24/2009 12:20 PM
post34532
Congratulations, you've now moved onto a tools issue :)
I'd check that you've compiled a debug variant and
maybe ask for help in the tools project.
> my code
> #include <stdlib.h>
> #include <stdio.h>
> #include "pcap.h"
> pcap_if_t *alldevs;
> pcap_if_t *d;
> int inum;
> int i=0;
> pcap_t *adhandle;
> exit(1);
> if (d->description)
> else
> if(i==0)
> return -1;
> inum=1;
> return -1;
> if (adhandle=NULL)
> return -1;
> struct tm *ltime;
> char timestr[16];
> io-net migration
> http://community.qnx.com/sf/go/post34529
07/24/2009 2:24 PM
post34549
I attached the project file maybe you find the problem. I also posted the problem under build section.
Mohammad
07/24/2009 2:29 PM
post34550
This isn't really a networking issue, rather a debugging one.
IIRC you're using the ide? Maybe try in the ide group:
http://community.qnx.com/sf/projects/ide
07/24/2009 12:19 PM
post34531
> Problem
> references to `ioctl_socket' follow packetcapture2 line 0 C/C++ Problem
> -seanb
Re: using pcap.h
my code
#include <stdlib.h>
#include <stdio.h>
#include "pcap.h"
pcap_if_t *alldevs;
pcap_if_t *d;
int inum;
int i=0;
pcap_t *adhandle;
exit(1);
if (d->description)
else
if(i==0)
return -1;
inum=1;
return -1;
if (adhandle=NULL)
return -1;
