Re: unable to init devnp-shim.so: unknown error
12/17/2008 9:28 AM
post18816
On Wed, Dec 17, 2008 at 08:37:41AM -0500, Peter Fischer wrote:
> Hello.
> I recently upgraded from 6.3.2 to 6.4.0 and i have to use io-pkt instead of io-net. I use a Freescale MPC5200 Lite
Board and the most recent BSP.
> Using io-net i used following line and everything worked fine:
> io-net -dmpc5200 mac=xxxxxxxxx,verbose -ptcpip
> Now with io-pkt, this is the line:
> io-pkt-v4-hc -d shim "lib/dll/devn-mpc5200.so" -v -ptcpip mac=xxxxxxxxxx
> I entered the full address of the library because i thought that might help, i also tried without the path.
> The libraries that i need are included (devnp-shim.so and devn-mpc5200.so).
> During the boot, this is the message that i get:
> If I use this command:
> io-pkt-v4-hc -dmpc5200 -v -ptcpip mac=xxxxxxxxxx
> The error message changes to:
> unable to init devn-mpc5200.so: unknown error
> Does anybody know a solution?
> What further information do you need?
Try this:
io-pkt-v4-hc -dmpc5200 mac=xxxxxxxxxx
