Forum Topic - coid leakage: (3 Items)
coid leakage
There's probably a better forum for talking about the dispatch library code, but since I found the problem while trying
to build an unloadable LSM, I'll report it here.
The dispatch_destroy() code does not free the select->ctrl->coid.  Thus, after some number of cycles of  select_attach()
/select_detach()/dispatch_destroy(), select_attach() fails with EMFILE.
I added a ConnectDetach in dispatch_destroy(), and that solved my immediate problem.  I guess you could argue both ways
about select_detach() noticing that the coid was no longer needed and and dealing with it at that point, but it seems
like it should be dealt with at least in dispatch_destroy.
Murf
Re: coid leakage
Thanks John.  I'll raise a PR to look into this.  BTW this would have been better serviced in the core-os forums, but
that's ok.
Colin
trying to build an unloadable LSM, I'll report it here.
select_attach()/select_detach()/dispatch_destroy(), select_attach() fails with EMFILE.
ways about select_detach() noticing that the coid was no longer needed and and dealing with it at that point, but it
seems like it should be dealt with at least in dispatch_destroy.
> Murf
> io-net migration
> http://community.qnx.com/sf/go/post17134
cburgess@qnx.com
Re: coid leakage
FYI it's PR63218, if you ever need to query the status of this one.
> Murf
> io-net migration
cburgess@qnx.com
