09/10/2008 10:41 AM
post13155
On Wed, Sep 10, 2008 at 10:38:56AM -0400, Matthias Klein wrote:
> On QNX 6.3 I started io-net with the following commands:
> io-net -p tcpip forward -p qnet &
> waitfor /dev/io-net
> On QNX 6.4 I want to use the following commands:
> io-pkt-v4-hc -p tcpip forward -p qnet &
> waitfor /dev/io-net
> The problem is, that io-pkt doesn't create the io-net path.
> What path can I use with the waitfor command ?
/dev/socket which will also work for io-net with the tcpip stack
loaded in.
Or if you pass the 'prefix' option as in
# io-pkt -ptcpip prefix=/foo
/foo/dev/socket
