Forum Topic - io-net Configuration for dual netwrok stacks: (3 Items)
I need to run 2 network stacks one is npm-tcpip.so for TCP/IP full stack and the other is  npm-pppmgr.so.
I need the first stack to be used with the netwrok port and the second for serail port. Please let me know the io-net
commands to add both of them.
RE: io-net Configuration for dual netwrok stacks
In short, you just do:
 # io-net -p tcpip -p pppmgr
 # io-net -i 1 -d <ether> -p tcpip prefix=/full
You run pppd as normal to establish TCPIP link via serial port. And if
you want to access the full stack, you simply add "SOCK=/full" before
you command. Like:
  # SOCK=/full dhcp.client
  # SOCK=/full ping qnx.com
  # SOCK=/full ftp ftp.qnx.com
-xtang
> From: ravi varma [mailto:community-noreply@qnx.com]
> Sent: August 13, 2008 4:34 PM
> To: ionetmig-networking
> Subject: io-net Configuration for dual netwrok stacks
stack and
for serail
> port. Please let me know the io-net commands to add both of them.
> io-net migration
> http://community.qnx.com/sf/go/post11760
Re: RE: io-net Configuration for dual netwrok stacks
Hi Xtang Thanks for your reply
i am working on PPC platform, so by default i need netwrok port for my TFTP connection, and so i am using the following
io-net command
io-net -vvvv -dmpc85xx mac=<mac_addr>,verbose=4,phy_incr=4 -ptcpip
waitfor /dev/io-net/en1 4
what i did is after downlaoding the BSP image, i used the command line(given by you) for laoding PPP stack.
io-net -i 1 -p tcpip -p pppmgr
I am able to see the PPP protocol stack running on my machine now.
What are the commnads for mounting and unmouting PPP stack through program.
Now i want to communciate PPP over serail link, and dont have pppd facility in target.
Let me know the way to do the same with socket program , or else is there any way to capture packets after PPP stack and
 then transmit the same through serail link.
Ravi
> you command. Like:
> -xtang
> stack and
> for serail
> > io-net migration
