Programmatic creation of VLAN using ioctl - Not working as it should
08/01/2008 10:18 PM
post11377
I tried to programmatically add and delete VLAN group by using the following ioctl calls. Doesn't work as intended. I
then checked the ifconfig sourcecode and it looks like for QNX we have to use ioctl_socket instead of ioctl. I checked
the code I wrote with ioctl and ioctl_packet. No problems during compilation or running but the results are completely
different. Things are setup correct with ioctl_socket but not so with ioctl.
My questions:
1. For QNX, should I be making a general rule to use ioctl_socket instead of ioctl?
2. Are there plans to make it a standard ioctl interface instead of ioctl_socket? Can someone explain me the reason why
the interface definition was changed instead of changing the implementation within ioctl?
Santosh
Re: Programmatic creation of VLAN using ioctl - Not working as it should
08/02/2008 1:21 PM
post11387
About mid way through this forum thread is a good description of the ioctl usage with io-pkt.
http://community.qnx.com/sf/discussion/do/listPosts/projects.networking/discussion.drivers.topc1801
The short answer is that because you can't pass pointers around with the ioctl in a message passing OS, you have to
wrapper the ioctl calls in your application.
You'll probably still have some questions after reading the post, but that's a good place to start.
Robert.
08/18/2008 10:31 AM
post11951
There is a PR internally to make some of the common ioctls
that use embedded pointers more 'intuituve'. Since they
need special case handling there may always be some that
need to be addressed on a per instance basis.
08/19/2008 9:13 PM
post12058
Hi There,
Things seemed to be working with VLAN creation but for some reason, it stopped working for me and I'd like to get some
urgent help on this.
I am using io-pkt (I think revision 400) a little old but I have applied some changes to io-pkt to support one feature
currently available in RFC2292 only. Everything else seems to be working fine excepting that I cannot create VLAN groups
. I would like to add that it used to work a while back but not any more. The difference is that currently I am
packaging io-pkt into a BSP and previously I used to run it out of compact flash. Im assuming that shouldnt make a
difference.
Anyway, the exact problem is that the VLAN interface gets created, but in the following creation, ifconfig does a get of
the interface and that fails.
Following the stack trace upon executing ifconfig vlan4 create vlan 256 vlanif en4:
Thread [2] (Suspended)
9 vlan_ioctl() /media/sda2/workspace/mv/ne/thirdparty/Networking/trunk/sys/net/if_vlan.c:610 0x48081ca8
8 in_control() /media/sda2/workspace/mv/ne/thirdparty/Networking/trunk/sys/netinet/in.c:587 0x48085ae8
7 udp_usrreq() /media/sda2/workspace/mv/ne/thirdparty/Networking/trunk/sys/netinet/udp_usrreq.c:1282 0x480eb160
6 compat_ifioctl() /media/sda2/workspace/mv/ne/thirdparty/Networking/trunk/sys/compat/common/uipc_syscalls_43.c:620
0x480fda24
5 ifioctl() /media/sda2/workspace/mv/ne/thirdparty/Networking/trunk/sys/net/if.c:2160 0x480618b4
4 soo_ioctl() /media/sda2/workspace/mv/ne/thirdparty/Networking/trunk/sys/kern/sys_socket.c:182 0x480d3b8c
3 tcpip_devctl() /media/sda2/workspace/mv/ne/thirdparty/Networking/trunk/sys/msg.c:1567 0x480ad6c8
2 startproc() /media/sda2/workspace/mv/ne/thirdparty/Networking/trunk/sys/proc.c:703 0x480ba3e8
The exact area where the problem is discovered is:
memset(&vlr, 0, sizeof(vlr));
if (ifv->ifv_p != NULL) {
snprintf(vlr.vlr_parent, sizeof(vlr.vlr_parent), "%s",
ifv->ifv_p->if_xname);
vlr.vlr_tag = ifv->ifv_tag;
#ifndef __QNXNTO__
error = copyout(&vlr, ifr->ifr_data, sizeof(vlr));
#else
error = copyout(&vlr, data + sizeof(*ifr), sizeof(vlr));
The contents of ifv is:
ifv 0x48563a00
ifv_u {...}
ifv_p 0x00000000
ifv_mib {...}
ifv_mc_listhead {...}
ifv_list {...}
ifv_flags 0
ifv_alloc 0x485639e0
and quite obviously, the code returns with a BAD Address error. I dont know what happened to the data passed in the
ioctl, seems like it never got to this point. How can I proceed to debug this?
Another issue is that during creation of vlan interface, the interface flags are set to IFF_BROADCAST | IFF_SIMPLEX |
IFF_MULTICAST. Beats me as to why it is defaulted to SIMPLEX. Any idea? This is in the vlan_clone_create() function in
sys/net/if_vlan.c
Thank you in Advance.
-Santosh
> ioctl calls. Doesn't work as intended. I then checked the ifconfig sourcecode
> checked the code I wrote with ioctl and ioctl_packet. No problems during
> compilation or running but the results are completely different. Things are
> My questions:
> ioctl?
> ioctl_socket? Can someone explain me the reason why the interface definition
> Thanks,
> Santosh
08/20/2008 1:16 AM
post12062
More update on this. Apparently, I see this problem when I package io-pkt into our BSP but if I keep all binaries inside
the stage directory and create an environment around it then the vlan configuration works just fine.
Looks like an environment issue. Is there a specific environment setting I need to create? Im running only io-pkt and so
I start iopkt off and then mount all io-net network drivers followed by any other protocol I need like qnet etc...
Any advise of help would be much appreciated.
Santosh
> Hi There,
> working for me and I'd like to get some urgent help on this.
> changes to io-pkt to support one feature currently available in RFC2292 only.
> groups. I would like to add that it used to work a while back but not any more
> . The difference is that currently I am packaging io-pkt into a BSP and
> make a difference.
> following creation, ifconfig does a get of the interface and that fails.
> en4:
> sys/compat/common/uipc_syscalls_43.c:620 0x480fda24
> #ifndef __QNXNTO__
> #else
> ifv 0x48563a00
> ifv_u {...}
> ifv_p 0x00000000
> ifv_mib {...}
> ifv_list {...}
> ifv_flags 0
> what happened to the data passed in the ioctl, seems like it never got to this
> are set to IFF_BROADCAST | IFF_SIMPLEX | IFF_MULTICAST. Beats me as to why it
> in sys/net/if_vlan.c
> -Santosh
> > Hi,
> > ioctl calls. Doesn't work as intended. I then...
RE: Programmatic creation of VLAN using ioctl - Not working as it should
08/20/2008 3:41 PM
post12122
Hi Santosh:
It sounds like you're not including all of the binaries and/or
libraries that you need in your BSP and are ending up with a binary
compatibility issue. How do you create your BSP? Do you use mkifs to
create an image?
Robert.
From: Santosh Kumar [mailto:community-noreply@qnx.com]
Sent: Wednesday, August 20, 2008 1:17 AM
To: ionetmig-networking
Subject: Re: Programmatic creation of VLAN using ioctl - Not working as
it should
io-pkt into our BSP but if I keep all binaries inside the stage
I need to create? Im running only io-pkt and so I start iopkt off and
Santosh
> Hi There,
stopped
applied some
RFC2292 only.
create VLAN
any more
and
shouldnt
> make a difference.
in the
fails.
256 vlanif
> en4:
> 9 vlan_ioctl()
> 8 in_control()
> 7 udp_usrreq()
> 6 compat_ifioctl()
> 5 ifioctl()
> 4 soo_ioctl()
> 3 tcpip_devctl()
> 2 startproc()
> #ifndef __QNXNTO__
> #else
> ifv 0x48563a00
> ifv_u {...}
> ifv_p 0x00000000
> ifv_mib {...}
> ifv_list {...}
> ifv_flags 0
know
to this
> Another issue is that...
Re: RE: Programmatic creation of VLAN using ioctl - Not working as it should
08/20/2008 4:10 PM
post12127
Hi Robert,
Yes I use mkifs. I just copied over the socket, crypto ssl and shim libraries. I left everything else out.
Binaries I include many utilities and io-pkt-v4.
What are the needed elements?
Santosh
> Hi Santosh:
> create an image?
> Robert.
> it should
> Thanks,
> Santosh
> > Hi There,
> stopped
> applied some
> RFC2292 only.
> create VLAN
> any more
> and
> shouldnt
> > make a difference.
> in the
> fails.
> 256 vlanif
> > en4:
> > 9 vlan_ioctl()
> > 8 in_control()
> > 7 udp_usrreq()
> > 6 compat_ifioctl()
> > 5 ifioctl()
> > 4 soo_ioctl()
> > 3 tcpip_devctl()
> > 2 startproc()
RE: RE: Programmatic creation of VLAN using ioctl - Not working as it should
08/20/2008 4:14 PM
post12128
If you can send me a copy of your build file, I can let you know what
needs to be updated. Essentially, all utilities and libraries that are
in the stating area produced by the build must be updated. Is it
possible that your particular problem is with the ifconfig utility?
Robert.
Sent: Wednesday, August 20, 2008 4:10 PM
Subject: Re: RE: Programmatic creation of VLAN using ioctl - Not working
as it should
Hi Robert,
Santosh
> Hi Santosh:
> create an image?
> Robert.
as
> it should
setting
> Thanks,
> Santosh
> > Hi There,
it
> stopped
> applied some
> RFC2292 only.
> create VLAN
not
> any more
> and
> shouldnt
> > make a difference.
but
> in the
> fails.
> 256 vlanif
> > en4:
> > 9 vlan_ioctl()
> > 8 in_control()
> > 7 udp_usrreq()
> > 6 compat_ifioctl()
> > 5 ifioctl()
> > 4 soo_ioctl()
> > 3...
Re: RE: RE: Programmatic creation of VLAN using ioctl - Not working as it should
08/20/2008 4:19 PM
post12129
Attached is a copy of my build file. Im certainly not using all of the libraries in the staging area. That might be the
case and you might be right that its the ifconfig which might be misbehaving due to improper environment.
Should I plugin all the binaries and libraries into ifs from the staging area? Anyway let me know.
Santosh
> Robert.
> as it should
> Hi Robert,
> Thanks,
> Santosh
> > Hi Santosh:
> > create an image?
> > Robert.
> as
> > it should
> > Hi,
> setting
> > Thanks,
> > Santosh
> > > Hi There,
> it
> > stopped
> > applied some
> > RFC2292 only.
> > create VLAN
> not
> > any more
> > and
> > shouldnt
> > > make a difference.
> but
> > in the
> > fails.
> > 256 vlanif
> > > en4:
> > > 9...
08/20/2008 4:48 PM
post12130
Santosh,
You should use every binaries from the staging area to keep compatibility.
One byte different in data will cause very serious confusion to io-*.
RE: RE: RE: Programmatic creation of VLAN using ioctl - Not working as it should
08/20/2008 4:48 PM
post12131
Hi Santosh:
Any binary / networking library that you use needs to come from
the staging area. You also have to be very careful about including both
io-net and io-pkt in the same target. Io-net and io-pkt utilities (e.g.
ifconfig) are incompatible.
I can't remember for sure, but does io-pkt-v4 include vlan support or is
it only in io-pkt-v4-hc?
Unfortunately, that's an IDE build file as opposed to a nice clean
command line build file, but here's what I think needs to be done to use
io-pkt:
Remove io-net.
Remove npm-tcpip.so
Remove npm-qnet.so
Remove nfm-bpf.so
These files need to come from the appropriate io-pkt staging area:
Maybe they are, but the fact that the build path us "" for them while
it's a "/home...etc" path for io-pkt-v4 makes me wonder. My guess would
be that the search path results in io-net utilities getting used instead
of io-pkt.
tcpdump
nicinfo
inetd
if_up
ftpd
dhcp.client
traceroute
sockstat
ping
openssl
netstat
ftp
arp
sysctl
route
pfctl
ifconfig
libssl.so.1
libssl.so
libcrypto.so.1
libcrypto.so
libsocket.so.2
libsocket.so
I think that's all of them....
Robert.
Sent: Wednesday, August 20, 2008 4:20 PM
Subject: Re: RE: RE: Programmatic creation of VLAN using ioctl - Not
libraries in the staging area. That might be the case and you might be
environment.
Santosh
are
> Robert.
working
> as it should
> Hi Robert,
> Thanks,
> Santosh
> > Hi Santosh:
to
> > create an image?
> > Robert.
> as
> > it should
> > Hi,
> setting
and
I
Re: RE: RE: RE: Programmatic creation of VLAN using ioctl - Not working as it should
08/20/2008 5:42 PM
post12142
Im sorry, the project.bld is a little confusing because, it contains the debug configuration. Sorry about that. I added
the npm and io-net so that Im able to debug io-pkt. I think I removed it for the real one.
But you are right, I see " " for absolute path's in the IDE, which I was concerned but thought it handled things. I have
a separate project in my BSP where I copy all the files from the release build of trunk and then BSP picks all binaries
from that project.
I will make another clean build of bsp, fix all the path issues and try again. Maybe this time it would work. Will let
you know.
Santosh
> Hi Santosh:
> io-pkt:
> Remove io-net.
> Remove npm-tcpip.so
> Remove npm-qnet.so
> Remove nfm-bpf.so
> of io-pkt.
> tcpdump
> nicinfo
> inetd
> if_up
> ftpd
> dhcp.client
> traceroute
> sockstat
> ping
> openssl
> netstat
> ftp
> arp
> sysctl
> route
> pfctl
> ifconfig
> libssl.so.1
> libssl.so
> libcrypto.so.1
> libcrypto.so
> libsocket.so.2
> libsocket.so
> Robert.
> environment.
> Thanks,
> Santosh
> are
> > Robert.
> working
> > as it should
> > Hi Robert,
> > Thanks,
> > Santosh
> > > Hi Santosh:
> > > libraries that you need in your BSP and are...
RE: RE: RE: RE: Programmatic creation of VLAN using ioctl - Not working as it should
08/20/2008 5:44 PM
post12143
You can also do a "use -i" on the binary in question and that will tell
you where it was built once you get it on your target.
Good luck! :>
Robert.
Sent: Wednesday, August 20, 2008 5:42 PM
Subject: Re: RE: RE: RE: Programmatic creation of VLAN using ioctl - Not
debug configuration. Sorry about that. I added the npm and io-net so
concerned but thought it handled things. I have a separate project in my
BSP picks all binaries from that project.
again. Maybe this time it would work. Will let you know.
Santosh
> Hi Santosh:
both
(e.g.
is
use
> io-pkt:
> Remove io-net.
> Remove npm-tcpip.so
> Remove npm-qnet.so
> Remove nfm-bpf.so
would
instead
> of io-pkt.
> tcpdump
> nicinfo
> inetd
> if_up
> ftpd
> dhcp.client
> traceroute
> sockstat
> ping
> openssl
> netstat
> ftp
> arp
> sysctl
> route
> pfctl
> ifconfig
> libssl.so.1
> libssl.so
> libcrypto.so.1
> libcrypto.so
> libsocket.so.2
> libsocket.so
> Robert.
> environment.
staging
> Thanks,
> Santosh
what
> are
> > Robert.
> working
> > as it should
> > Hi Robert,
> > Yes I use mkifs. I just copied over the socket, crypto ssl and...
Re: RE: RE: RE: RE: Programmatic creation of VLAN using ioctl - Not working as it should
08/20/2008 7:51 PM
post12151
Robert,
Thanks. The problem is resolved. I feel silly now. Apparently, during startup, we had a whole bunch of applications
starting off after the bootup was successful. This compact flash image contained its own libsockt and overwrote the
LD_LIBRARY_PATH and that made ifconfig and other utilities behave strangely. I got rid of this directory on CF and
restarted....and everything worked like a charm. Cant believe, I Wasted almost 2 days over this seemingly trivial issue.
Thanks for your help.
-Santosh
> Good luck! :>
> Robert.
> Thanks,
> Santosh
> > Hi Santosh:
> both
> (e.g.
> is
> use
> > io-pkt:
> > Remove io-net.
> > Remove npm-tcpip.so
> > Remove npm-qnet.so
> > Remove nfm-bpf.so
> would
> instead
> > of io-pkt.
> > tcpdump
> > nicinfo
> > inetd
> > if_up
> > ftpd
> > dhcp.client
> > traceroute
> > sockstat
> > ping
> > openssl
> > netstat
> > ftp
> > arp
> > sysctl
> > route
> > pfctl
> > ifconfig
> > libssl.so.1
> > libssl.so
> > libcrypto.so.1
> > libcrypto.so
> > libsocket.so.2
> > libsocket.so
> > Robert.
> > right that its the ifconfig which...
RE: RE: RE: RE: RE: Programmatic creation of VLAN using ioctl - Not working as it should
08/21/2008 10:34 AM
post12197
Don't you love those sort of problems? :-> Nice to know that we were on
the right track though!
Robert.
Sent: Wednesday, August 20, 2008 7:51 PM
Subject: Re: RE: RE: RE: RE: Programmatic creation of VLAN using ioctl -
Robert,
startup, we had a whole bunch of applications starting off after the
libsockt and overwrote the LD_LIBRARY_PATH and that made ifconfig and
-Santosh
tell
> Good luck! :>
> Robert.
Not
the
was
my
then
try
> Thanks,
> Santosh
> > Hi Santosh:
> both
> (e.g.
or
> is
> use
> > io-pkt:
> > Remove io-net.
> > Remove npm-tcpip.so
> > Remove npm-qnet.so
> > Remove nfm-bpf.so
while
> would
> instead
> > of io-pkt.
> > tcpdump
> > nicinfo
> > inetd
> > if_up
> > ftpd
> > dhcp.client
> > traceroute
> > sockstat
> > ping
> > openssl
> > netstat
> > ftp
> > arp
> > sysctl
> > route
> > pfctl
> > ifconfig
> > libssl.so.1
> > libssl.so
> > libcrypto.so.1
> > libcrypto.so
> > libsocket.so.2
> > libsocket.so
> > Robert.
> > Sent: Wednesday, August...
Re: RE: RE: RE: RE: RE: Programmatic creation of VLAN using ioctl - Not working as it should
08/21/2008 11:11 AM
post12203
If libsocket makes things messed up then I will suggest we change libsocket.so major version to 3, it does make sense
and won't let it happen. All new tools requested to rebuild then
RE: RE: RE: RE: RE: RE: Programmatic creation of VLAN using ioctl - Not working as it should
08/21/2008 12:15 PM
post12207
Hi Yao:
The new libsocket is fully backwards compatible with the old
libsocket interface (i.e. you can use the new libsocket with io-net), so
there's no need to increment the library version number. It's only if
we break or change an existing API that the versioning has to change.
R.
Sent: Thursday, August 21, 2008 11:12 AM
Subject: Re: RE: RE: RE: RE: RE: Programmatic creation of VLAN using
libsocket.so major version to 3, it does make sense and won't let it
io-net migration
http://community.qnx.com/sf/go/post12203
