IPv6 Link-Local addresses have (possible) scope id embedded inside of them.
07/30/2008 11:38 AM
post11243
On QNX 6.3.2, with the io-pkt-v6-hc network driver installed, running the command ifconfig results in:
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
en0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
address: 00:01:f0:80:03:0b
inet 137.19.61.100 netmask 0xfffffe00 broadcast 137.19.61.255
inet6 fe80::201:f0ff:fe80:30b%en0 prefixlen 64 scopeid 0x2
bc0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ssid TST-EMBD1 nwkey 65536:"",0x6912a386e68d04f539c9ce2894d67063,0xfe374224480605fc4803f370fe34c69c,""
powersave off
bssid 00:1c:f0:9c:14:6b chan 6
address: 00:21:86:3e:83:aa
media: IEEE802.11 autoselect (OFDM54 mode 11g)
status: active
inet6 fe80::221:86ff:fe3e:83aa%bc0 prefixlen 64 scopeid 0x3
Here, we can clearly see the interface and link-local addresses of all 3 adapters available on the machine. In following
code segment, I gather the interface information using the getifaddrs() method, which populates a ifaddrs struct.
char test[INET6_ADDRSTRLEN];
memset(test, 0, INET6_ADDRSTRLEN);
struct ifaddrs *ifap;
struct ifaddrs *cur = NULL;
if (getifaddrs(&ifap) < 0)
perror("unable to retrieve interface information");
return -1;
for (cur = ifap; cur != NULL; cur = cur->ifa_next)
//go for the first ipv6 address you find?
//really we want the first "global" scope address...
if (cur->ifa_addr->sa_family == AF_INET6)
struct sockaddr_in6 *addr = (struct sockaddr_in6 *)cur->ifa_addr;
inet_ntop(AF_INET6, &addr->sin6_addr, test, INET6_ADDRSTRLEN);
fprintf(stderr, "looking at the address: %s\n", test);
freeifaddrs(ifap);
This code outputs the following:
looking at the address: ::1
looking at the address: fe80:1::1
looking at the address: fe80:2::201:f0ff:fe80:30b
looking at the address: fe80:3::221:86ff:fe3e:83aa
We can see the IPv6 link-local addresses for the adapters, but each has, what appears to be, the scope id of the address
embedded in string. This results in an invalid link-local address. I am unaware of any error in my source, after
reviewing several examples, and need to know if I am overlooking something.
Re: IPv6 Link-Local addresses have (possible) scope id embedded inside of them.
08/01/2008 2:51 PM
post11357
> powersave off
> status: active
following code segment, I gather the interface information using the getifaddrs() method, which populates a ifaddrs
struct.
> return -1;
> freeifaddrs(ifap);
address embedded in string. This results in an invalid link-local address. I am unaware of any error in my source, after
Yes, getifaddrs() is returning out the 'kernel' representation
of scoped addresses which stores the scope in the 3rd and 4th
byte. The following modified example based on ifconfig converts
it to the draft-ietf-ipngwg-scopedaddr-format-00.txt format.
See also this page:
http://www.freebsd.org/doc/en/books/developers-handbook/ipv6.html
#include <sys/socket.h>
#include <netinet/in.h>
#include <netdb.h>
#include <ifaddrs.h>
#include <stdio.h>
void in6_fillscopeid(struct sockaddr_in6 *);
int
main(void)
int ret;
char hbuf[NI_MAXHOST];
return -1;
in6_fillscopeid(addr);
if ((ret =...
08/01/2008 5:56 PM
post11375
Thanks sean, never came across that representation in my research of the sockaddr_in6 struct.
