01/03/2008 12:16 PM
post4036
Hi all,
We have recently started a project based on io-pkt infrastructure, how ever we've observed following symptoms
regarding network stack, I'd appreciate if anyone could shed some light on where this problem might come from? (network
stack setup/configuration or build)
#1 . ping test with bigger buffer (ping out / ping in has same symptom ):
[/]# ping -c 100 -s 4432 172.16.1.48
PING 172.16.1.48 (172.16.1.48): 4432 data bytes
4440 bytes from 172.16.1.48: icmp_seq=0 ttl=128 time=9 ms
4440 bytes from 172.16.1.48: icmp_seq=1 ttl=128 time=9 ms
4440 bytes from 172.16.1.48: icmp_seq=2 ttl=128 time=8 ms
4440 bytes from 172.16.1.48: icmp_seq=3 ttl=128 time=8 ms
4440 bytes from 172.16.1.48: icmp_seq=4 ttl=128 time=725 ms
----172.16.1.48 PING Statistics----
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 8/151/725 ms variance = 102977 ms^2
[/]# ping -c 100 -s 4433 172.16.1.48
PING 172.16.1.48 (172.16.1.48): 4433 data bytes
100 packets transmitted, 0 packets received, 100% packet loss
ping test with bigger buffer is OK within LAN , not cross LAN, and same behavior happens to both wired and wireless
interfaces (wireless interface using wpa_supplicant provided on the board to associate with AP in an open mode) , so I
suspect that there is an buffer issue at layer that is higher than layer2 (tcp/ip possible);
[/etc]# ifconfig
ath0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ssid AcmeWifi
powersave off
bssid 00:03:52:e0:46:f0 chan 7
address: 00:06:80:00:a1:ed
media: IEEE802.11 autoselect (OFDM12 mode 11g)
status: active
inet 192.168.10.87 netmask 0xffffff00 broadcast 192.168.10.255
en0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
address: 00:55:44:33:22:11
inet 172.16.3.54 netmask 0xffff0000 broadcast 172.16.255.255
============= Ethernet interface en0 ==============
[/etc]# ping -s 5000 172.16.3.1
PING 172.16.3.1 (172.16.3.1): 5000 data bytes
5008 bytes from 172.16.3.1: icmp_seq=0 ttl=64 time=11 ms
5008 bytes from 172.16.3.1: icmp_seq=1 ttl=64 time=12 ms
----172.16.3.1 PING Statistics----
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 11/11/12 ms variance = 23 ms^2
[/etc]# ping -s 5000 172.16.1.48
PING 172.16.1.48 (172.16.1.48): 5000 data bytes
221 packets transmitted, 0 packets received, 100% packet loss
[/etc]# ping 172.16.1.48
PING 172.16.1.48 (172.16.1.48): 56 data bytes
64 bytes from 172.16.1.48: icmp_seq=0 ttl=128 time=1 ms
64 bytes from 172.16.1.48: icmp_seq=1 ttl=128 time=1 ms
round-trip min/avg/max = 1/1/1 ms variance = 0 ms^2
============== wireless interface ath0 =========
/etc]# ifconfig en0 down
[/etc]# ifconfig
ssid Devicescape-Guest
powersave off
bssid 00:14:c2:a5:4c:41 chan 10
media: IEEE802.11 autoselect (OFDM54 mode 11g)
status: active
inet 192.168.30.10 netmask 0xffffff00 broadcast 192.168.30.255
en0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
[/etc]# ping...
Re: network buffer issues
01/05/2008 8:59 AM
post4066
On Thu, Jan 03, 2008 at 12:16:07PM -0500, Shannon Gu wrote:
> Hi all,
Something must have changed between the two runs. It's hard
to say with the providfed info but it may be a routing issue.
Make sure 172.16.1.48 has a route back to you.
> [/etc]# ifconfig
> ssid AcmeWifi
> powersave off
> status: active
> 2 packets transmitted, 2 packets...
01/07/2008 1:59 PM
post4099
Yes 172.16.1.48 has a route back, but expeirence the same size issues to the target.
Another observation is that the packet size is destination dependent, for every host I pinged, each one fixes at certain
buffer size like shreshhold, some at couple of kilo bytes, some at several, I have not seen any one exeeded 10 Kb ...
Thanks a lot for your prompt response!
Shannon
RE: network buffer issues
01/07/2008 2:11 PM
post4101
Is the router between the subnet not letting larger ICMP packets through?
Is the truncation tied to a subnet or to particular hosts on the subnet?
Is it possible to put a sniffer on one of the other hosts to see if the
packets are being truncated? Are the other hosts all running the same OS?
Does the reverse path (pinging from the host to QNX work)?
Problem here is that we can't really tell where things are falling apart. It
would seem (:->) that if everything on the same subnet is working with large
packets then the QNX side of things is working properly. What you really
need to do is follow the larger packets through the network and try and see
where they're getting lost or discarded.
Robert.
Sent: Monday, January 07, 2008 1:59 PM
To: ionetmig-networking
Subject: Re: network buffer issues
target.
every host I pinged, each one fixes at certain buffer size like shreshhold,
exeeded 10 Kb ...
Shannon
io-net migration
http://community.qnx.com/sf/go/post4099
01/07/2008 4:08 PM
post4107
> > #2. wpa_supplicnt in PSK mode stopped and network on board is basically
> crashed:
> > a. wpa_supplicant stopped during 4-way handshake after receiving Key;
> sniffer shows that the client(the board) never response to key exchange;
> > b. AP shows that WPA pairwise key handshake timed out ( no reply was
> received for the first massage)
> > c. On board , the shell still working, except ifconfig command hangs; but it
> is able to quit after inputting Ctrl-C;
> > d. supplicant involves pcap lib when using security mode to transfer packets
> while in open mode does not;
> > So if I put a stop at calling pcap_inject before let it continue, then
> network system on board wont crash, the program will go on and on, the
> buffered packets will be eventually sent out;
> > but this is only at a slow speed, if I hit the continue right away then
> the system will hang right away, just like what a~c described; the result is
> that the board will never get authenticated with any AP as it always times out
> Some more detailed info on how to reproduce this would be
> appreciated: config files etc.
1. wpa_supplicant command is :
[/]#wpa_supplicant -Dbsd -iath0 -c/etc/shxy.conf -ddd
2. [/]# cat etc/shxy.conf
ctrl_interface=/var/run/wpa_supplicant
network={
disabled=0
ssid="tomato-DLS"
proto=WPA2
key_mgmt=WPA-PSK
psk="secureDLS"
3. I attached some reference files here:
-- An Ethereal file that captured all the related packets;
-- A wpa_supplicant log file; (next post)
Thanks a lot,
Shannon
01/07/2008 4:10 PM
post4108
> crashed:
This is to attach the log file
Shannon
01/08/2008 4:12 PM
post4131
Hi Shannon:
I've got someone looking into this to see if we can reproduce it.
Sorry for not getting back to you sooner. Most people have been away for
the last couple of weeks on Christmas break.
Robert.
Sent: Monday, January 07, 2008 4:11 PM
> crashed:
Shannon
io-net migration
http://community.qnx.com/sf/go/post4108
Re: RE: network buffer issues
01/09/2008 1:44 PM
post4153
Hi, I have tried to reproduce the problem (WPA2 4-way handshake) but I can't reproduce it here. I have tried to
associate to an access point with the short preamble ability (as the one you are using has this ability) and also
another access point without the short preamble ability. Also besides the io-pkt-v4-hc (that is what you are running), I
have also tried another flavor like io-pkt-v6. They all work fine.
So I think it would be better to solve/understand the following two suspectable points. I also listed my wpa conf file
at the end and attached my log of accessing an WPA2+psk access point. Hope it be helpful.
1) the ifconfig got blocked (although ^C can make it free). I can't see it on my side either. Can you check the pidin to
see what is the status of the io-pkt? I noticed in you very first email, there is a script, (?) bt_detect? where you
have one io-net and two io-pkt instance running? If you intended to run more than one instances of io-net and/or io-pkt,
you have to use the prefix option, otherwise, neither of them work as expected. Anyway, please use pidin to see if any
suspectable point. I think we'd better to solve it first (ifconfig blocks) and go further onto such as wpa2.
==== the section in your script ?? ===============
/usr/sbin/random
#/proc/boot/io-net -ptcpip -ppppmgr &
/proc/boot/waitfor /dev/random 4
#/sbin/io-pkt-v4-hc random -ptcpip -pppmgr &
/platform/bin/wd &
/platform/bin/pm &
/platform/bin/doc &
/platform/bin/adi &
/proc/boot/waitfor /dev/pm/wifi/controls/enable 4
/sbin/pci-lge5200b
/proc/boot/waitfor /dev/pci 4
/sbin/io-pkt-v4-hc random -dath -ptcpip -pppmgr &
2) I noticed there is more than 1 second between the broadcast and the first message sending to your access point. It
might indicate a problem of difficulty of accessing your access point. You may run "ifconfig ath0 scan" to see if you
can get the list of wireless devices around you and please check if the signal of your access point is too weak. Also
please check your access configuration settings and make sure it is correct. (I blindly suspect the signal is too weak
on your side and if it is the case, move closer to your access point and try again ...)
I list below the wpa.conf that I am using and the attached is the log file that the io-pkt+ath successfully associated
to my access point (Linksys Wireless-G WRT54GS).
=== my wpa2.conf ===
ctrl_interface_group=0
update_config=1
ap_scan=1
network={
ssid="linksys"
# proto=RSN
proto=WPA2
key_mgmt=WPA-PSK
# pairwise=CCMP TKIP
# group=CCMP TKIP
psk="LINKSYSWPAKEY"
| Attachment: |
mylog
10.41 KB
01/09/2008 8:33 PM
post4164
Hi Robert,
I think I need to give more background of this project. The nature of it is to port our wpa_supplicant to QNX platform
on top of io-pkt stack.
The hardware and the kernel come with it are from our customer; these network issues has been found on this particular
target, therefore I dont think they can be reproduced on a different type of target.
The network subnet envrionment is pretty standard, and works fine with all other devices that has been connected with --
including different type board/cpu/wireless driver, for example, we have put a PPC board running QNX 6 with io-net
network stack and a Broadcom chip on the same subnet, it can shoot big buffer packets no problem at all (up to the limit
65K); so I wouldn't suspect the subnet too much, (let me know if this makes sense).
I have requested our customer to reproduce the problem on same configuration target, but I have not gotten results back;
I suspect the problem is related to network configuration while building the kernel or some memory issues specific to
this board -- any advice regarding this perspective? Or have you encountered similar problems before?
Thanks a lot,
Shannon
01/10/2008 7:43 AM
post4168
Dear team
I'm LGE engineer. I performed same test by using h/w which are same with the one Shannon used for his test.
And found that the board stop running during wpa_supplicant execution.
Following is my configuration and I'm attaching execution log.
[/etc]# cat shxy.conf
ctrl_interface=/usr/sbin/wpa_supplicant
network={
disabled=0
ssid="FCP_dooeui"
proto=WPA
key_mgmt=WPA-PSK
psk="secureDLS"
[/etc]#
[/]# ifconfig ath0 ssid FCP_dooeui
[/]# ifconfig ath0 192.168.1.50 netmask 255.255.255.0
[/]# route add default 192.168.1.245
add net default: gateway 192.168.1.245
[/]# wpa_supplicant -Dbsd -iath0 -c/etc/shxy.conf -ddd
RE: RE: network buffer issues
01/10/2008 10:31 AM
post4177
Hi Shannon:
I'm guessing when you say "kernel" you actually mean "networking stack"?
The OS kernel should just be the standard shipping version of procnto for
your platform.
Just to summarize:
1) Pings of large packets are failing when the destination is outside of the
subnet. This happens on the custom hardware platform that you're using with
the LGE version of the Atheros driver.
Is that correct?
Do large packet pings within the subnet work on this platform?
If you have a PCI slot on the platform, can you try a wired card in
the platform and see if the behaviour changes?
Are there any other applications running on this board other than
that required for networking? Maybe there's some sort of interaction
problem occurring...
2) A different PPC platform running QNX with io-net and a Broadcom chip
works as expected.
Is this a BCM43xx WiFi chip?
Can you run io-pkt instead of io-net (you can still use the io-net
driver... Just make sure that you include devnp-shim.so in your image as
well as the io-net devn driver).
Do you have a PCI-based Atheros card that you can try in this
platform with io-pkt?
I'm trying to figure out whether we're dealing with a software issue, a
hardware platform issue or a hardware driver issue...
Thanks!
Robert.
Sent: Wednesday, January 09, 2008 8:33 PM
Subject: Re: RE: network buffer issues
Hi Robert,
to port our wpa_supplicant to QNX platform on top of io-pkt stack.
network issues has been found on this particular target, therefore I dont
other devices that has been connected with -- including different type
6 with io-net network stack and a Broadcom chip on the same subnet, it can
shoot big buffer packets no problem at all (up to the limit 65K); so I
kernel or some memory issues specific to this board -- any advice regarding
Thanks a lot,
Shannon
io-net migration
http://community.qnx.com/sf/go/post4164
Re: RE: RE: network buffer issues
01/11/2008 3:22 AM
post4209
I seems like found something.
Shannon, Please remove following 2 line in the /etc/boot.ksh
/usr/sbin/random
/vcp/dcm &
1. There is a known issue which happen when dcm & io-pkt are used together. LGE already reported this issue to QNX and
Andy Lalonde (QNX) is following up this issue. LGE had to remove this line when h/w is delivered to devicescape. Maybe
there was some mistake in LGE side.
2. I don't know why /usr/sbin/random make problem but when I commented out this line, wpa_supplicant halt issue seems
like to be fixed. I think, QNX team may have any idea on this.
Shannon, please test it and let me know if the problem is not yet fixed.
Good luck.
Dooeui
01/15/2008 2:21 AM
post4296
Regarding wpa_supplicant issue. Problem is fixed like follows. (Please ignore my previous post.. "random" should not be
removed)
#Before fix
/bin/mount -T io-pkt -o "/proc/boot/devn-mpc5200-lge1.so mac=001122334455" /lib/dll/devnp-shim.so
#after fix
/sbin/io-pkt-v4-hc random -dmpc5200-lge1 -ptcpip prefix=/alt
I seperate socket for ethernet driver and issue is fixed.
I have some questions to QNX team.
1. Is socket seperation only way to use ethernet driver and WiFi driver at the same time?
2. In above solution, "shim" driver seems like to be associated with ethernet driver. How is it determined? (There
are io-pkt for WiFi driver and io-pkt for ethernet but there is no explicit direction which one should be associated
with "shim" driver. Please let me know how can I specify this.
I'm keep testing big buffer issue. I'll post my test result soon.
Dooeui
RE: RE: RE: network buffer issues
01/15/2008 11:04 AM
post4312
Hello Dooeui:
There is indeed something peculiar going on there. By running two
separate instantiations of the stack, you're completely separating data flow
with the interfaces. We're not expecting there to be any interaction at all
between a wired and wireless driver with respect to the supplicant so we'll
try and reproduce that in-house. This could also be a driver issue...
With regards to the shim layer, this is required for an io-net style driver
binary. The shim layer converts the io-net interface presented by the older
style driver into the newer interface required by io-pkt.
The stack itself will automatically determine the driver type and load the
shim layer for you (as long as the directory that it's in is in the
LD_LIBRARY_PATH) without you having to specify it, so you should be able to
execute
mount -T io-pkt -o "mac=001122334455" /proc/boot/devn-mpc5200.lge1.so
without specifying the lib/dll/devnp-shim.so binary. Io-pkt style drivers
have a naming convention "devnp-????" while io-net style drivers are named
"devn-?????".
This is touched on in the following wiki page:
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/Driver
s_wiki_page
Hope that helps!
Robert.
Sent: Tuesday, January 15, 2008 2:22 AM
Subject: Re: RE: RE: network buffer issues
ignore my previous post.. "random" should not be removed)
#Before fix
#after fix
the same time?
ethernet driver. How is it determined? (There are io-pkt for WiFi driver and
associated with "shim" driver. Please let me know how can I specify this.
Dooeui
io-net migration
http://community.qnx.com/sf/go/post4296
Re: RE: RE: RE: network buffer issues
01/15/2008 9:22 PM
post4339
Dear Robert.
I appreciate your response.
What you mean is, without using two seperate stack, ath0 driver and en0 driver should work on same stack without any
collision? Am I correctly understand?
FYI, I tested same thing in Reference board. and the result was same.
Welcome to QNX Neutrino 6.3 on the Freescale Lite5200B/Media5200
Starting PCI driver
# /sbin/io-pkt-v4-hc random -d/lib/dll/devnp-ath.so
# /bin/mount -T io-pkt -o "mac=001122334455" /proc/boot/devn-mpc5200.so
# ifconfig
ath0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
ssid ""
powersave off
address: 00:0f:cb:fb:44:04
status: no network
As you can see, ath0 and en0 are loaded on the same stack but wpa_supplicant will be fail.
Please let me know if you find anything.
Best Regards,
Dooeui
RE: RE: RE: RE: network buffer issues
01/16/2008 10:38 AM
post4354
Hi Dooeui:
That's correct. Having the wired driver operating within the stack
shouldn't interfere with the wireless driver in any way, so there's either a
problem with one of the drivers or something strange is happening in the
stack.
I'll let you know what we find out.
Robert.
Sent: Tuesday, January 15, 2008 9:22 PM
Subject: Re: RE: RE: RE: network buffer issues
Dear Robert.
driver should work on same stack without any collision? Am I correctly
understand?
Starting PCI driver
# ifconfig
ssid ""
powersave off
status: no network
will be fail.
Best Regards,
Dooeui
io-net migration
http://community.qnx.com/sf/go/post4339
01/18/2008 9:23 PM
post4443
Hi Dooeui:
We've spent some time with the FCP hardware trying to reproduce the
supplicant problem and we couldn't get it to fail even with both drivers
loaded. Are you using the supplicant that comes with io-pkt? There have
also been some changes made to the source code since the first milestone
build so it would also be worthwhile trying out a newer version of io-pkt
(either the newer build posted or a built from head version).
Robert.
Dear Robert.
understand?
Starting PCI driver
# ifconfig
ssid ""
powersave off
status: no network
will be fail.
Best Regards,
Dooeui
io-net migration
Re: wpa_supplicant handshake
01/21/2008 1:09 AM
post4451
Dear QNX and Devicescape team.
As Robert suggested, I compiled the latest io-pkt libraries and test it.
And the issue is resolved.
Now I can share 1 stack for ath0 and en0 at the same time.
Regarding the ping issue. LGE got new WiFi h/w module from 3rd party h/w maker and the packet loss issue seems like to
be resolved.
I think, this issue is nothing to do with QNX.
Thanks for your support.
Best Regards,
Dooeui
RE: wpa_supplicant handshake
01/21/2008 12:56 PM
post4471
Hi Dooeui:
That's great news. Glad to hear that everything seems to be working
well for you now.
Robert.
Sent: Monday, January 21, 2008 1:09 AM
Subject: Re: wpa_supplicant handshake
maker and the packet loss issue seems like to be resolved.
Best Regards,
Dooeui
io-net migration
http://community.qnx.com/sf/go/post4451
Re: RE: wpa_supplicant handshake
02/12/2008 2:58 PM
post4958
Hi All,
I recently recieved the new hw/sw form Dooeui, as far as the wireless issue goes, it has been resolved. Althoug for the
ethernet port the big buffer ping issue still exists (the ethernet port is on the JMB debug board), as long as it does
not hinder our development, I wont bother.
My sincere thanks to Robert, Weijie and Dooeui for prompt response and eventually solving the problem!
Shannon
RE: RE: wpa_supplicant handshake
02/12/2008 3:19 PM
post4965
Hi Shannon:
Great to hear that you're up and running. The big ping issue is
still a bit worrisome and could well be a HW related issue. Let us know if
you need us to dig into that a bit more.
Robert.
Sent: Tuesday, February 12, 2008 2:59 PM
Subject: Re: RE: wpa_supplicant handshake
Hi All,
goes, it has been resolved. Althoug for the ethernet port the big buffer
long as it does not hinder our development, I wont bother.
Shannon
io-net migration
http://community.qnx.com/sf/go/post4958
Re: RE: RE: wpa_supplicant handshake
02/12/2008 4:30 PM
post4979
Sure, I will when I get chance.
Thanks a lot,
Shannon
