Why doesn't the pfil filter module attach to the active ethernet driver?
01/14/2010 3:30 PM
post45256
Isn't the ethernet driver mounted first than the pfil filter module. If that is the case then why doesn't the pfil
filter module attach to the active ethernet driver by itself when mounted.
How can I explicitily attach a pfil filter module to already mounted ethernet driver? If I do it, I get an error saying
the resource is busy. And that is what even I was expecting. The ethernet driver is already mounted after startup.
Is it not true that pfil filter module has to be mounted only after the ethernet driver is loaded. Only then it makes
sense for data extraction on the stack.
Please correct me if I am wrong.
All I want to do is attach my pfil filter module to my devn-i82544.so driver module which is already mounted.
Vinod
