09/16/2009 1:43 PM
post38092
Surely I should just be able to perform a 'make' without specifying
command line options? How does the build server work?
Thanks, Hugh.
From: Sean Boudreau [mailto:community-noreply@qnx.com]
Sent: Wednesday, September 16, 2009 1:20 PM
To: general-networking
Subject: Re: io-pkt-v4 cores
On Tue, Sep 15, 2009 at 10:06:50AM -0400, Peter Weber wrote:
> io-pkt-v4 from 6.4.1 distribution cored on an OMAP3530 with driver
devn-asix.so and devnp-shim.so.
> args are:
> io-pkt-v4 -dasix -ptcpip
gdb doesn't seem to think there's any dll's loaded
in that core. Is it reproducible? Can you upload
another core?
General
http://community.qnx.com/sf/go/post38087
09/17/2009 5:08 AM
post38136
Some additional information:
The EHCI usb port is used. EHCI is supported in the bsp-ntotrunk-ti-omap3530-evm-beagle-1.0.0-200909140928.zip bsp. The
AXIS USB dongle works if connected to the EHCI port directly. The dump occurs if the ASIX is conntected to a USB-hub and
the hub to the EHCI port.
This sounds like PR 67298 "devn-asix does not support a usb dongle/hub".
Sönke
# usb -vvv
USB 0 (EHCI) v1.10, v1.01 DDK, v1.01 HCD
Control, Interrupt, Bulk(SG), Isoch(Stream), Low speed, High speed
Device Address : 1
Upstream Host Controller : 0
Upstream Device Address : 0
Upstream Port : 1
Upstream Port Speed : High
Vendor : 0x05e3
Product : 0x0606 (USB2.0 Hub)
Device Release : r7.02
USB Spec Release : v2.00
Serial Number : N/A
Class : 0x09 (Hub)
Subclass : 0x00
Protocol : 0x01
Max PacketSize0 : 64
Languages : 0x0409 (English)
Current Frame : 966 (1024 bytes)
Hub Number Ports : 4
Hub Characteristics : 0x00e0 (Ganged power, Global over-current)
Hub Power On->Good : 100 ms
Hub Power Requirements : 100 mA
Configurations : 1
Configuration : 1
Attributes : 0xe0 (Self-powered, Remote-wakeup)
Max Power : 100 mA
Interfaces : 1
Interface : 0 / 0
Class : 0x09 (Hub)
Subclass : 0x00
Protocol : 0x00
Endpoints : Control + 1
Endpoint : 0
Attributes : Control
Max Packet Size: 64
Endpoint : 1
Attributes : Interrupt/IN
Max Packet Size: 1
Interval : 12 ms
Device Address : 2
Upstream Device Address : 1
Upstream Port : 1
Vendor : 0x2001 (D-Link Corporation)
Product : 0x3c05 (DUB-E100)
Device Release : r0.01
Serial Number : 000001
Class : 0xff (Vendor-specific)
Subclass : 0xff
Protocol : 0x00
Current Frame : 1113 (1024 bytes)
Configurations : 1
Configuration : 1 (0)
Attributes : 0x80 (Bus-powered)
Max Power : 250 mA
Interfaces : 1
Interface : 0 / 0 (0)
Subclass : 0xff
Protocol : 0x00
Endpoints : Control + 3
Endpoint : 0
Max Packet Size: 64
Endpoint : 1
Max Packet Size: 8
Interval : 11 ms
Endpoint : 2
Attributes : Bulk/IN
Max Packet Size: 512
Endpoint : 3
Attributes : Bulk/OUT
