Re: lsm-nraw.so on different tcp/ip stacks
09/10/2009 3:05 PM
post37783
On Thu, Sep 10, 2009 at 02:49:35PM -0400, Martin Dorigatti wrote:
> Dear all,
> I installed three tcp/ip stacks which work quite fine.
> The first is under /dev, the two additional are /sock1 and /sock2
> Now I try to load the lsm-nraw.so using
> mount -Ttcpip -oprefix=/sock1 lsm-nraw.so
> however, I filters packets on /sock2.
> I also tried
> SOCK=/sock1 mount -Ttcpip -oprefix=/sock1 lsm-nraw.so
> with the same result.
> Looks like the the lsm is mounted to the last io-pkt loaded.
> How can I mount the lsm modules to a specific stack/io-pkt?
With io-pkt you can do:
# io-pkt -i1 ...
# mount -T io-pkt1 ....
