Forum Topic - ping6 -h option seems to fail:
Does the ping6 -h option work?  Here's an example of a test I did:
# ping6 -h2 fe80::201:9cff:fe00:477
PING6(56=40+8+8 bytes) fe80::201:9cff:fe00:477%en0 -->
16 bytes from fe80::201:9cff:fe00:477%en0, icmp_seq=0 hlim=64 time=0 ms
16 bytes from fe80::201:9cff:fe00:477%en0, icmp_seq=1 hlim=64 time=0 ms
16 bytes from fe80::201:9cff:fe00:477%en0, icmp_seq=2 hlim=64 time=0 ms
16 bytes from fe80::201:9cff:fe00:477%en0, icmp_seq=3 hlim=64 time=0 ms
16 bytes from fe80::201:9cff:fe00:477%en0, icmp_seq=4 hlim=64 time=0 ms
16 bytes from fe80::201:9cff:fe00:477%en0, icmp_seq=5 hlim=64 time=0 ms
--- fe80::201:9cff:fe00:477 ping6 statistics ---
6 packets transmitted, 6 packets received, 0.0% packet loss
round-trip min/avg/max = 0/0/0 ms
   variance = 0 ms^2
Process 856116 (ping6) terminated SIGINT code=0 by process 856116
value=0.
Should the hlim not =2 instead of =64??
Cheers,
maurice
Maurice Gibbs
Software Designer
CommTest WaveReady BU
JDS Uniphase Corp.
613.843.2326
Re: ping6 -h option seems to fail
Hi Maurice,
I just tested it and the -h (hop limit) option to ping6 works for me. In
a wireshark capture I see the echo requests sent have the hop limit I
specify.
The output from ping6 prints the *replies*. Hence, it's just saying that
the replies had the hop limit 64 which is usually the default (per
MIBs). You can change it using sysctl on the variable net.inet6.ip6.hlim.
Hope this helps!
/P
Thanks Patrik.
I didn't realize that nuance in the RFC.  I'll play around with the sysctl as well to see if it helps me narrow down the
 real issue I am chasing.
Cheers,
maurice
