Re: how to change Ethernet interface on logical Lan 1 (en1) to
en2!!!
08/14/2009 9:15 AM
post35992
en2!!!
On Fri, Aug 14, 2009 at 08:51:04AM -0400, zhang shilei wrote:
> I have two Ethernet interfaces,so in QNX system I have two logical Lan name,en1 and en2. but how can I change each
other.
They're populated in the order they're specified or scanned.
If they're two different drivers (devnp-x, devnp-y), just
start them on the command line or mount them in the desired
order. If they're chipsets handled by the same driver there
may be a driver specific arg to bind it to a particular
instance. For example,
io-pkt -d devnp-x pci=0 -d devnp-x pci=1
io-pkt -d devnp-x did=x -d devnp-x did=y
You can also try the 'lan=x' option
io-pkt -d devnp-x did=x,lan=a -d devnp-x did=y,lan=b
Check the docs for the driver in question.
