Phrelay Offset in OS Container
07/01/2009 2:39 PM
post32929
Hello All,
This problem exists under QNX 6.4.1 on an X86 system. The hardware for the client and the server were identical, so I
don't believe it can be a problem with the incompatibility between the two machines.
I'm working on a program that has to display an image acquired from a camera and draw a line down the center. This works
perfectly.
A second requirement for this program is that it has to display the image on a second QNX computer, so I felt the
easiest way to do this is to run phrelay through inetd and use phditto with the -n /dev/photon so I can connect to the
running instance of photon. Again, no problems with getting the phrelay/phditto connection going. I can see the screen
and control everything.
However, the image which is contained in an OS container is shifted down and to the right, but the container is not
changed. The very funny thing is that the amount that it is shifted seem to be exactly the distance from the top left
of the dialog (0,0) to the top left of the os container. It's as if this offset is applied through photon The line that
I draw down the center is shifted as well, depending on where the line is drawn in the code. The offending function
seems to be PgDrawPhImage, if the line is drawn before this function is called, then the line is shifted with the image.
If it is called after the PgDrawPhImage is called, it is drawn on the center of the os container, but the image is
still shifted. For fun I tried to change the position of the OS container to the top left of the dialog, and there was
no shift on the image through the remote connection. Both image locations were now the same.
Attached is a sample program that should compile on any system. Inside of the tar are two screenshots that show the
program running locally and through phrelay.
I have tested everything I can think of and I'm convinced it is a bug in phrelay or phditto
Thanks for your time,
Kevin Raymond
ps. This was originally posted under the momentics community support forum, but I think it is better suited for this
forum. Sorry for double-posting
