Re: Specifying Gateway and DNS server for target with static IP address
06/08/2009 9:55 AM
post31080
route add default <gateway ip>
will set the gateway
and
/etc/resolv.conf
contains the domain name and dns servers
Glenn Schmottlach wrote:
> I'm stumped and hoping someone can quickly answer this question. Typically I run dhcp.client on my target to
dynamically get an IP address and the associated Gateway and DNS addresses are automatically assigned from the DHCP
server. Now, I have a target with a statically assigned IP address but it's not clear to me how I manually assign the
Gateway and DNS addresses. I know what these addresses should be but I don't know where to configure it manually on QNX
(which dhcp.client seems to do perfectly). Can anyone offer a suggestion?
> Thanks . . .
> http://community.qnx.com/sf/go/post31079
cburgess@qnx.com
address
06/08/2009 9:57 AM
post31081
address
> Thanks . . .
# route add default <gateway>
Put the DNS entries in /etc/resolv.conf or the CS_RESOLVE confstr.
See the entry for /etc/resolv.conf under 'r' in the utilities
reference.
address
06/08/2009 10:07 AM
post31085
address
To manually assign a Gateway, you do:
# route add default <gateway ip>
To specify DNS address, the easiest is to do:
# setconf CS_RESOLVE nameserver_<you dns ip>
-xtang
> Typically I run dhcp.client on my target to dynamically get an IP
> assigned from the DHCP server. Now, I have a target with a statically
> don't know where to configure it manually on QNX (which dhcp.client
> Thanks . . .
